Trek 2018 Bike - Powerfly FS9 LT
Ravi Kempaiah
Here is a teaser.
Focal point seems to be the integrated frame design. The verdict is clear. Customers appreciate an elegant design and something that doesn't look like an E-bike.
  • Bosch CX motor
  • FOX 36 E-bike optimized forks
  • SRAM E-block heavy duty cassette and SRAM Eagle chainring.
  • Rockshox dropper post
  • Powerful 2-piston hydraulics
  • 27.5 plus-sized tires
elyhim
This IS better. I'm wondering if it will be the same price though. It's different than the European 2018 Powerfly 9 though. Also - no knockblock on the teaser.
Love this bike!
Charles L.
Will be interesting to see more details about the weight, frame geometry, component specs and suspension travel. Nobby Nics and a Fox 36 make for a pretty good start though. Never thought I'd be looking at an e-mountain bike, but after taking my XM700+ on a few mild trails and seeing how it gobbles up the climbs, I'm intrigued :)
Larry Ganz
It would be nice if they could get it under 45lbs, and fit bottle cage bosses on the smaller sizes. I'm guessing they'll use the 160mm front fork version with 15mm axle, but who knows.
Over50
I was checking out the 2018 hardtail Powerfly and the specs say it is ready to be accessorized with fenders, rack and lights. But doesn't really give any details. Anyone think this bike could be turned into a viable commuter with integrated lights powered by the Bosch system (I'm assuming fenders and a cargo rack are do-able based on the specs)? I really like the integration of the battery and motor. Seems they've done a bit better with that integration than the Haibike Trekking 4.0. The latter though comes setup as a good commuter with the integrated lights and super moto-x tires:
Possible to get integrated lights on this model?
elyhim
Some of them are available now. Check the Trek US site and there are more flavors than the 5, 8 from last year. European markets got 12 new models. 12.. Trek USA also has now tree subject - Ebike Mountain. Regardless of elitist mtb local groups the popularity is growing.
Jeff Backes
You can add front and rear lights that are made for the Bosch system. Your local bike shop will have to "code" your system to enable the lights.
I have done this on 3 bikes so far, 2 only had the headlight and I added the tail lights and one was a Trek eMTB that came from the factory with no lights at all.
Good luck
jeff
e-boy
Good luck
jeff
Can you provide any further info or link re: integrating front and rear lights on a Trek eMTB ; ie. which model lights .
Thinking about getting the ePolice .
Nova Haibike
If I had a Bosch bike, I would go with the Supernova M99 series. That is what Trek specs on the Super Commuter+ 8S.
Ravi Kempaiah
The bike already comes with 800 lumen light. Just like the one that comes with Cross Rip+.
Check the attached photo.
