What's the best way to track rides with a Turbo Levo 2020?
lrn2bikepls
So I've got one of the newer turbo levo 2020s and I'm trying to track my rides. I'd like to be able to use my Garmin Edge 1030 to track everything along with Strava, since I like it's GPS accuracy, but it seems like that (even when it's connected to my bike) it is probably reporting the power output as both mine + bike put together?
It seems to do the right thing when I use the mission control app, but then my GPS is super inaccurate and I lose out on things like my heart rate strap.
How can I make it so it only reports *my* actual power output, instead of also combining it with the bike's motor? Is this even possible?
Thanks!
Stefan Mikes
Isn't it possible to connect the HR strap to the Levo via ANT+ over the Fake Channel? In what sense is the GPS inaccurate when you're using the Mission Control app?
lrn2bikepls
I'm not sure if it's possible to connect to heart strap to the Levo?
Inaccurate in that my phone GPS is far less precise than the Garmin head unit is. It also means I need to have my phone mounted to my handlebar and I'd rather not risk it falling off or getting damaged in a crash compared to a Garmin unit instead. My phone costs a hell of a lot more than the Edge does.
Stefan Mikes
Will that help?
lrn2bikepls
Will that help?
Not sure, I'll give it a shot and see what happens!
Stefan Mikes
If you don't have the TCD display, that is great to buy, too. Working with Garmin as well.
arnoldc
BLEvo is the app you want for your Levo, it was written for it. Connect IQ data fields are limited, just the battery and assist mode. You may want to use the Connect IQ app instead, since you have a 1030.
arnoldc
I wanted to buy this for my Creo SL ... but the data available is very very limited, not to mention the display is not flexible.
