Where can I find a 48V Juiced bike controller?
Gotcha
Hi, I just received a standard Juiced bike from a friend who got a new bike. He said the controller doesn't work. I contacted Juiced and they don't make the 48V controller anymore so they can't send me one. They only make the 52V controller. Does anyone have an idea how I can get one from Juiced or someone else. I am also ok with installing third party controller if there is one compatible with the bike.
harryS
If you buy a third party controller, you need one that works with the LCD on the Juiced bike. He probably had his bike maker change the LCD firmware to prevent customers from doing that. Means you may have to replace both LCD/controller.
No big deal, 100-120 bucks should get you a controller/display, if you can find one that fits in whatever space you have. You can run most generic 48V controllers on 52V. The better ones might let you set the voltage in the display,
hoggdoc
The 52v controller should work just fine on your 48v bike. Just ask them if all the connectors and wiring layout are the same.
Timpo
which Juiced bike are you talking about?
Eunorau has some.. though you will likely need to replace the whole unit (display, cadence/torque censor, etc)
For direct drive motor
For geared hub motor
