2023 Gazelle Ultimate C8 HMB Review
Highlights
Technical Specs & Ratings
General
2023 |
Ultimate C8 HMB |
$3,199 |
Class 1 |
Step-Thru |
Suspension Type |
Front Suspension |
28.0 |
8 |
Hydraulic Disc |
Mid-Drive |
500 Wh |
500 Wh |
53.8 lbs / 24.43 kgs |
Frameset
Step-Thru |
53.8 |
Suspension Type |
Front Suspension |
40 |
Aluminium, Internal to Headset |
Ryde Dutch |
Schwalbe Energizer Plus, Puncture resistant |
Drivetrain
8 |
8-speed Shimano Nexus |
Yes |
Components
Adjustable Stem |
Aluminum, Slightly Curved Model |
Gazelle Aero leather, Luxury leather handlebar grips for a sophisticated feel and extra comfort |
Sprung |
Selle Royal Loire |
Hydraulic Disc |
Front: Shimano BR-MT200, 2 piston, 180mm Rotor | Rear:Shimano BR-MT200, 2 piston, 160mm Rotor |
Ebike Systems
Class 1 |
Mid-Drive |
Bosch Active Line Plus (50Nm) |
Bosch Purion LCD |
500 Wh |
500 Wh |
Bosch Li-ion Integrated into frame |
4 Ah |
Accessories
Axa Blue Line 50, LED headlamp, on/off switching via display |
Yes |
Gazelle Commuter, Aluminium |
More Details
Active |
United States, Canada, Europe |
2 Years Comprehensive, 10 Years Frame |
Aluminum |
Stainless Steel, Extra Strong |
46, 53, 57 |
Black |
Light Sienna, Petrol Blue |
Derailleur |
38 |
Nov-42 |
Battery |
60 |
Axa Imenso, Ring Lock With an Option for a Plug-in Cable to Attach Your Bike to a Fixed Object for Extra Protection Against Theft, ART ** certified |
Chaincase Description |
Plastic Chain Guard |
Ursus Mooi, Drop-down Rear Stand |
Yes |
75 |
Pedal Force Sensor, Rotation Sensor, Speed Sensor |
Amount of Support Levels |
4 |
Yes |
20 mph (32 kph) |
Video Reviews
Written Reviews
The Gazelle Ultimate C8 HMB has a stable and rigid frame with an integrated battery, which provides a low center of gravity to ensure stability when riding in an active position. The bike incorporates low-maintenance components including the Nexus 8 geared hub and the durable Gates carbon belt drive. This combination results in confident operation and smooth functionality, resulting in carefree cycling.
The Nexus 8 geared hub and Gates belt drive require little maintenance, making the Gazelle Ultimate C8 HMB an easy-to-use electric bike. The bike also features powerful Shimano BR-MT200, 2-piston disc brakes that provide excellent hydraulic stopping power. The front fork has an integrated front suspension, ensuring a smooth ride on rough terrain. Combining the bike's components provides a comfortable and enjoyable riding experience.
The cockpit features leather grips, which are ergonomic and comfortable, and Shimano's twist shifter to control the Nexus hub. The bike also comes with a kickstand, mudguards, and a rear carrier, making it a practical and versatile choice for commuting or touring.
Post a Comment for 2023 Gazelle Ultimate C8 HMB
Comment has been submitted successfully.
Comment is being held for moderation and will be posted after it has been reviewed
