Total Weight:
58 lbs (26.3 kg)
Battery Weight:
7.3 lbs (3.31 kg)
Motor Weight:
5.7 lbs (2.58 kg)
Frame Material:
ADVANCE™ Hydroformed 6061 Aluminum Alloy
Frame Sizes:
16.5 in (41.91 cm)18.5 in (46.99 cm)21 in (53.34 cm)Geometry Measurements:
Small 16.5" Measurements: 16.5" Seat Tube Length, 22" Top Tube, 15" Reach, 27.5" Stand Over Height, 32" Minimum Saddle Height, 27" Width, 45" Wheelbase, 74.25" Length
Frame Types:
High-Step
Frame Colors:
Anthracite Satin Black
Frame Fork Details:
RST F1RST Air Suspension, 120mm Travel, Black Anodized 32mm Stanchions, Compression Clicker, Rebound Adjust, Boost 110mm Hub Spacing, 15mm Thru-Axle with 6mm Hex Bolt
Frame Rear Details:
142mm Hub Spacing, 12mm Thru-Axle with Quick Release
Attachment Points:
Rear Rack Bosses, Fender Bosses, 2 Bottle Cage Bosses, Headlight Mount on Stem
Gearing Details:
10
Speed 1x10 Shimano Deore with One-Way Clutch, 11-36 Tooth CassetteShifter Details:
Shimano Deore Triggers on Right (Optical Gear Display, Two-Way High Lever, Three-Shift Low Lever)
Cranks:
OHM Branded Custom Specced Crank Arms, Aluminum Alloy, 170mm to 175mm Length, 42 Narrow-Wide Tooth Chainring with Alloy Chain Guard, Shimano Hollowtech II Bottom Bracket, Hollow Spindle
Pedals:
Wellgo MG6 Magnesium Platform with Adjustable Pins
Headset:
FSA, Sealed Cartridge Bearings, Tapered 1-1/8"- 1-1/2"
Stem:
Promax DA230 Aluminum Alloy, 70mm / 80mm / 90 mm / 100mm Length, 6° Rise, 31.8mm Clamp Diameter with Custom Light Mount, Four 10mm Spacers, One 5mm Spacer
Handlebar:
Aluminum Alloy, Low-Rise, 670mm or 710mm Length, 25mm Rise, 7-Degree Backsweep
Brake Details:
Shimano MT420 Hydraulic Disc with 180mm Rotors, Quad Piston Calipers, Shimano Two-Finger Levers with Adjust Reach
Grips:
Ergon GP1, Ergonomic Rubber, Dual-Density, Locking, 130mm or 150mm Length
Saddle:
OHM Branded Ergon ST10 Gel, Chromoly Rails
Seat Post:
Aluminum Alloy, 25mm Offset, Single Bolt Clamp
Seat Post Length:
350 mm
Seat Post Diameter:
30.9 mm
Rims:
Alexrims MD35, Aluminum Alloy, Double Wall, 32 Hole, 35mm Width, Aluminum Eyelets
Spokes:
Stainless Steel, 14 Gauge, Black with Brass Nipples
Tire Brand:
Schwalbe Supermoto, 27.5" x 2.4" (62-584)
Wheel Sizes:
27.5 in (69.85cm)Tire Details:
30 to 55 PSI, 2.0 to 4.0 BAR, Reflective Sidewall Stripe, ADDIX Rubber Compound, Level 6 Double Defense Race Guard, 50kmh High Speed Pedelec Ready
Tube Details:
Schrader Valve
Accessories:
Pletscher ESGE Comp 40 Rear-Mount Kickstand, Knog Bell on Left, Custom OHM Racktime Light Cargo Carrier Rear Rack (25kg 55lb Max Weight, 10mm Tubing, Semi-Integrated Mount with 20% More Lateral Stability), Custom OHM Racktime Wingee Aluminum Alloy Tubular Fenders (70mm Width), Integrated Lezyne E-Bike Mini STVZO E65 Headlight (210 Lumens, 65 Lux, Alloy Casing), Integrated Lezyne E-Bike Super Bright STVZO E12 Rear Light (12 Lumens), Optional Kinekt Suspension Seatpost, Optional ABUS Bordo Lock
Other:
Locking Removable Downtube-Integrated Battery Pack with Plastic Shield, 2.2lb 42 Volt 5.6 Amp DARFON Charger, KMC X10 EPT MTB Chain, ABUS Amparo Locking Core and Key
TP
1 week agoLooks very much like the Trek Allant 7!
ReplyCourt
4 days agoYeah, both companies make good products and they do look similar! I suspect that as a design reaches its highest form, it may start to resemble other optimized designs… I see this with cars, where the body styles look similar and the difference becomes colors and supporting business practices like dealers and warranty.
Reply
