2023 Specialized Turbo Como SL 5.0 Review
Highlights
Technical Specs & Ratings
General
2023
Turbo Como SL 5.0
$2,799.99
Class 3
Mid-Step
8
Hydraulic Disc
Mid-Drive
240
320 Wh
320 Wh
44 lbs / 19.98 kgs
Drivetrain
8
Microshift SL-SCN08, 8-speed Alfine compatible
Crank: Custom alloy forged crankarms | Chainring: Gates Carbon Drive CDX 46T chainring, black | Chainguard: Integrated Chaincover
Shimano Alfine, 8-speed internal gear hub
Gates Carbon Drive CDX 22t sprocket, silver
Gates Carbon Drive CDX 122t belt, black
Components
PLW COMFORT INTEGRATED EXTRUSION STEM, INCLUDED W/HANDLEBAR
Specialized handlebar/stem combo, integrated cable routing
Body Geometry XC Contour
Specialized 2-bolt head, forged alloy, 5mm offset, micro-adjust, 34.9mm
34.9
Specialized Body Geometry Comfort Gel
Specialized Commuter w/ grip tape & reflectors
Hydraulic Disc
TRP Flow Set Control, hydraulic disc, metal-ceramic pads, flat-mount w/ 160mm CL-rotor
Ebike Systems
Class 3
Mid-Drive
Specialized SL 1.1, custom lightweight motor
240
Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth
Mission Control App, ANT+/Bluetooth
320 Wh
320 Wh
Specialized SL1-320, fully integrated, 320Wh
Custom charger, 48V System w/ SL system charger plug
More Details
United States, Canada, Europe, Australia, New Zealand, South America
Lifetime Frame (if registered), 2 Years Battery & Other
Specialized bolt-type, alloy, 38.6mm
Smoke / TransparentBrassy Yellow / TransparentBrushed Silver / Transparent
Specialized alloy front hub disc, sealed cartridge bearings, 12x110mm, Center Lock
Shimano Alfine, 8-speed internal gear hub, SG-S7001-8, 32H, Black
Custom Specialized wiring harness w/ chargeport
Specialized Como SL front-rack, max. 15kg load, incl. Como SL basket w/cargo-net
Specialized Center-Mount, 255mm
Simple bell
Video Reviews
Written Reviews
The Turbo Como SL 5.0 electric bike by Specialized is for urban commuting and leisure rides. Here are the key features of this electric bike:
Motor and Battery: The Turbo Como SL 5.0 has a Specialized SL 1.1 custom lightweight motor and a fully integrated 320Wh battery. The motor support is smooth and not too loud, providing an enjoyable riding experience.
Frame and Design: The bike features an E5 Aluminum frame with the motor mount in the bottom bracket, fully integrated downtube battery, internal cable routing, fender, and front rack mounts. The frame design allows for a comfortable and upright riding position, making it ideal for city commuting.
Performance Tracking and Connectivity: The bike comes with advanced performance tracking and seamless partner app integration. The all-new Specialized app takes cycling and connectivity to the next level, allowing riders to modify support via the app to suit their needs.
Ride Modes: The bike offers multiple ride modes, and the rider can modify the support level via the app. The bike charges in under 2 hours, making it convenient for daily use.
Components: The Turbo Como SL 5.0 features high-quality components such as TRP Flow Set Control hydraulic disc brakes, Gates Carbon Drive CDX belt and sprocket, and a Microshift 8-speed Alfine compatible shifter.
Comfort and Convenience: The bike is designed for comfort with features such as a Specialized Body Geometry Comfort Gel saddle, Specialized handlebar/stem combo with integrated cable routing, and a Specialized Como SL front-rack with a maximum 15kg load capacity.
Safety Features: The bike is equipped with Supernova E3 alloy housing taillight and Supernova Mini2 alloy housing headlight, providing excellent visibility and safety during rides.
Weight and Size: The Turbo Como SL 5.0 weighs 20.1kg (44 lb, 5 oz) and is available in different sizes to accommodate various riders.
Post a Comment for 2023 Specialized Turbo Como SL 5.0
