The 2016 version of Emotion’s EVO City model offers a higher voltage battery pack (48 vs. 36), a more powerful zippy motor (500 watt vs. 360), an updated paint job and costs a bit more. This continues to be one of the best looking, most feature rich electric bike for tall people who want a capable city commuter. Easy Motion is well known for their ebikes that blend in and offer lots of “bicycle” features like 24 speeds here vs. just 7 to 10 on many competing models from other brands. You’re paying more for the style and accessories including fenders, an integrated cargo rack with bungee cords and LED lights that run off the same battery as the motor system (the front light actually runs off of a dynamo hub so that it can always be active regardless of battery fill) but the result is outstanding. With even more power and range than earlier models the 2016 model is very capable of moving taller heavier riders. You still get two drive modes, pedal assist and twist throttle, which let you maximize range and get a workout or opt for a sweat-free ride. And now, you can buy a Neoprene battery cover, Bluetooth module and GPS theft tracking system separately to dial in the experience. Each of these options add to the price and I wish the Bluetooth feature was built in because it requires replacing the LCD screen with a non-readout plastic chunk… and then you have to use your phone which will certainly drain its battery (especially with GPS modes) and there’s no charging port on the bike for a p hone to plug into.
Minor gripes aside, this is a bike that caters to a specific type of rider who has a specific body type. It can be uncomfortable to compromise on frame size… often requiring a DIY kit conversion or sacrifice on features. This e-bike provides everything you need and it looks great doing it. I love that the battery is removable for charging separately (perhaps up in the office if you commute to work) and I’m impressed with how well the cockpit works and how clean it is considering there are two sets of shifters and a bell. The display panel is intuitive and lets you adjust many settings by holding the up and down buttons simultaneously. There are still gripes here like the charging port on the chain stay being too close to the crank arms (vulnerable if you back the bike up while it’s plugged in) but minor improvements like the way the motor is wired in (the wires is protected behind the disc brake rotor and unique quick release arm) combined with the excellent two year upgradeable warranty are redeeming. Easy Motion has created a formula for great looking ebikes dating back to 2013 in the US and this EVO model only builds on that heritage. I do wish they had included bottle cage bosses on the seat tube because it seems like there is plenty of room there (maybe they were worried about frame strength?) and the TMM4 torque sensor software can deliver a laggy experience when you stop pedaling (the motor eases out instead of being more immediate) but the motor inhibitors on the brakes are near instant. You even get a little bell for signaling as you ride around town. Other areas where I feel the bike could be improved are with locking grips vs. the basic rubber ones that can spin and maybe a suspension seat post to further improve comfort. The skinny tires are efficient (and I love the reflective sidewalls) but they don’t offer as much comfort on long rides. The suspension fork locks out but I’d probably ride with it open and I love that both wheels have quick release in case you need to move the bike with your car or perform a quick flat fix on the way home from work. It’s a solid electric bike.
Pros:
- This bike is decidedly large and tall, it would be great fit for someone with long legs who feels cramped on other ebikes, it’s ideal for commuting, urban or city riding
- Beautiful clean aesthetic, the battery is completely integrated into the downtube and paint matched, all wires including shifter, brake and electrical are internally routed through the frame
- The rims, spokes and motor casing are all painted black to blend in, they look great and because the brakes are disc vs. caliper style the black paint on the rims won’t be marred over time
- The battery locks securely to the frame and doesn’t seem to rattle as much as older models, the pack may be charged on or off the frame for convenience and has a small LED readout built in so you can see how full it is off the bike
- Great accessory package for commuting including full length plastic fenders, chain guard, adjustable length kickstand, integrated LED lights and an oversized rear rack with pannier blockers and bungee cords
- The cockpit handlebar area of the bike is very clean and organized despite having trigger shifters on the left and right, I think the Emotion display helps a lot (and I like that it’s removable)
- Reinforced sloping top tube delivers strength and stiffness for great handling off-road but lowers the stand over height making the bike easier to mount and handle when stopped
- Unique ratcheting quick release systems on the rear wheel and torque arm (where the hub motor is), makes changing flats and doing maintenance easier… just be careful to align properly and not over-tighten since it uses a TMM4 torque sensor
- The power cable running to the rear hub motor is tucked in behind the quick release arm and disc brake rotor which is much better than coming out the end of the axle… this is important if the bike tips or is parked close to other bikes at a rack
- Efficient 700x38c tires are smooth and quiet, they help to extend range but are firm so it’s nice that the saddle is an upgraded gel model from Selle Royal and the grips are ergonomic, I also like that the stem is adjustable to improve fit and body position, consider a 31.6 mm Thudbuster or Body Float for even greater comfort
- Hydraulic disc brakes offer smooth, powerful stopping performance and the 180 / 160 mm rotors and integrated motor inhibitors give you control over the drive system and mechanical systems of the bike
- With 24 gear combinations to choose from, this bike is easy to pedal at low speed when climbing or at higher speeds when traveling long distances, it easily reaches 20+ mph in pedal assist mode… I’ve taken it up to ~23 mph in testing
- The battery uses high end 18650 Lithium Manganese cells from Samsung that are light weight and long lasting, excellent energy density here (lower weight, more power)
- Solid warranty offering two years of comprehensive coverage and the option to upgrade to five if you simply register, good network of dealers and lots of compatible batteries out there if yours dies eventually (since most of the EVO models share the same design… but not necessarily the same color)
Cons:
- Not super light weight… with the larger frame and all of the extra accessories (fenders, rack, dynamo hub and lights) the bike is ~59 lbs
- Only available in one large frame size, high-step style and one frame color… this keeps costs lower but might exclude some riders with shorter legs, be careful mounting if you swing your leg around the back as the rack can be easy to clip with your leg
- I love that you can charge the battery pack on or off the bike with the EVO series but it requires a special dongle adapter because the plugs are different and the bike-frame plug is positioned very close to the left crank arm which can collide with it and break it off if you back the bike up while charging BE CAREFUL!
- If you purchase the optional Bluetooth module it completely replaces the LCD display but doesn’t have a display of its own so you have to use your phone… and that’s okay but there’s no charging port to keep your phone from draining rapidly as you use it for GPS etc.
- No bottle cage mounting points on the downtube or seat tube which means you’ll need to add one to the seat post or saddle rails, wear a CamelBak
- The controller on this bike lets the motor run a second or two long after you’ve stopped pedaling, this reduces “surge” (the jerky feeling of power going up and down with each pedal stroke) but makes the bike feel unresponsive at times, thankfully the motor inhibitors in the brake levers are near-instant
Resources:
- Official Site: http://www.emotionbikesusa.com/en/bicycles/ebikes/evo-city-uv406-us.html
- More Pictures: https://goo.gl/photos/7yHXhSKwJNPN6xQZ9
Nirmala says
Another option for mounting a water bottle is this bottle holder that fits very well on the upright portion of the stem on my Magnum Ui5.
I love having the water bottle right there within easy reach, and it is easier to grab the water bottle than any frame mounted bottle holder I have used. It does not seem to affect the steering since the weight is centered, and it attaches firmly with the velcro strap. Using this, I do not miss a frame mounted holder at all.
Court Rye says
Awesome! Great tip Nirmala, thanks for sharing this. Has it stayed pretty straight? It looks like it uses velcro so I’m wondering if there’s a rubber strip on the back to keep it up or if it sags a bit, maybe even if it does it’s not an issue?
James says
This should really have been labeled a Preview vs a “Review” since it is a pre-production model and you didn’t even get to ride it powered on. It was really a big let-down for someone interested in this bike. There is nothing in this review that helps anyone make an informed decision when comparing the 2015 with the 2016 models. Or even how this model performs as an electric bike. This *is* ELECTRICbikereview.com, right? Hate to be harsh, but compared to most all of your other reviews, this just seemed rushed and more like you’re reading us a brochure. Hope you get to actually ride a production version of this bike and do one of your legendary good reviews.
Court Rye says
Thanks for the feedback James, I was disappointed that the bike wasn’t working but wanted to show the latest version and take higher resolution photos/videos than I had of the older version (which is still online). Not a lot has changed besides the more powerful motor and higher capacity higher voltage battery. More actual reviews are on the way but I’d tend to agree that most of my content is “overview” vs. true in-depth review. I do my best and speak independently but it is what it is :)
James says
Thanks. You’ve just worked up a reputation of having some of the best and most detailed reviews on bikes like these. It just wasn’t what I learned to expect from this site. Stinks BH wasn’t more helpful. Don’t they realize this is where their customer’s go before buying a bike? Alas. Thanks for the reply.
Court Rye says
I appreciate critical feedback and strive to offer great information. I know how much money and time can get spent trying to find the right thing and sometimes even though my reviews fall short of where I’d like, I figure some information is better than none and I try to acknowledge when I missed things or am wrong. I do make money doing this but I also care about readers and make that my North Star.
Daniel S says
Loving the BH Easy Motion Evo City Pro so far. After riding about 120 miles, I have done mixed throttle only, pedal assist and riding with no motor assistance (riding with the family). The fit and finish of this bike is really nice! My favorite part is the sturdiness of the overall bike. This bike just feels like it can endure any stress. After going downhill at about 40mph I felt 100% secure on the bike. I will say that throttle only will not get me up an aggressive hill, with pedal assist that same hill is zero challenge at about 8 mph. I was able to ride the same hill with zero assist and I like having the gears to do that. The bike is so quite even with motor assist, I am able to carry on full conversations with my family without it interrupting us. The rack is suitable for any pannier on the market. I would like a bottle cage holder but their are many solutions for this. I like the 20mph pedal assist, maybe more would be nice but on a non E bike I would never be 20mph + for a full ride. So far I purchased a single Pannier and a cell phone holder. I am looking for a water bottle solution for this bike.
I do like the ability to shut of the motor and just ride like a regular bike. I constantly forget how heavy it is until I try to pick it up. It presents so much lighter then its reality.
Court says
Thanks for the feedback, Daniel! I haven’t covered the BH products in a while, but it’s great to hear that they’re still out there being enjoyed. The battery integration is so beautiful, they really helped to jumpstart the movement in North America… and yeah, most ebikes feel a bit heavy once the power is shut off. It really helps me appreciate just how great the electric assist is :D Hope you have a wonderful Spring, riding.
Michael mills says
I purchased a easy motion evo by and it didn’t have a manual with the bike how can I get one
Court says
Hi Michael! Perhaps you can find someone who has a manual that will post it in the forums? I have two sections for Easy Motion (which is owned by BH). I hope this helps! I do not have a strong connection at BH or access to their manuals. Good luck!
