To run the forums, host the website, and travel, I charge a universal service fee for my reviews. This review was sponsored by Fullerton Bicycles. My goal is to be transparent and unbiased, this video and written review are not meant to be an endorsement of Giant products.
Brand new for 2020 is the Giant Explore E+ 4 GTS, an all purpose mountain ebike with a list of possibilities that can be matched only by the syllables in its name. I say possibilities because this could feel at home during light trail riding or even in the street as a commuter because it comes with rear rack bosses, fender bosses, kickstand provisions, and even extra threaded eyelets in the back for a cafe lock. The bike comes in 4 frame sizes and each is pretty lightweight for an ebike… for example, the medium size frame we are testing today came in at just 49lbs. To round off that all purpose feel, it has these 700c x 45 studded tires, so kind of a good balance between efficiency and capability. I did notice a quick release in both the front and the rear, this is awesome for not just maintenance or flat tire repair, but also if you need to take the wheel off to move it around in a trunk or truck, really cool. A bit of comfort here too, like the 60mm of travel RST fork with preload adjust. I also see these large sized locking ergonomic grips which are Giant branded. A lot of really high quality parts over all, and I love that everything matches and is well balanced weight wise. Another great feature of this bike is that it doesn’t scream “Hey, look at me! I am an electric bike!”. Mostly because of the sleek frame integrated battery and the very minimalist display that you might miss if you even blink for a moment. Other features include bottle cage bosses for adding accessories of your own and a clear sticker slap guard.
Driving the bike is a Yamaha PW series motor that has been rebranded by Giant as SyncDrive Sport. This is a 250 watt mid-drive motor with 80nm of torque that measures both pedal torque and pedal cadence. It uses square spindles and while it may not be as high performance as some of the other motors in the Yamaha lineup, it is still very quiet, efficient, and best of all, reliable. It is ever-so-slightly heavier and offers 350% pedal support vs the pro version which has 360% support. Mechanically, it has a really nice 9 speed Shimano Deore setup with 11-36 tooth cassette and a 42 tooth chain ring in the front with an aluminum alloy guard. Stopping the bike is a nice set of hydraulic disc brakes. These are Tektro brakes and you get a 180mm disc brake rotor in the front combined with a 160mm rotor disc brake in the rear. Don’t let the staggered setup fool you, this is pretty common, even in some high end mountain bikes. The reason for this is that the front wheel takes most of the brunt force of breaking due to weight dynamics, so having a larger rotor in the front is a good thing.
Powering the bike is a 36v 11.3ah battery. Not the largest capacity I have seen, but for a mid-drive without a throttle, it gets the job done with no real problems. I love that it tips out from the side when removing, that way you don’t bump or scratch the frame as easily as some other battery setups. It is secured via lock and key and even has an LED charge level indicator. The battery weighs about 7.7lbs, so not too bad, and the charger itself weighs about 2lbs. I noticed that charging while on the bike is done near the crank arm, so do be careful not to snag that cable by rotating the pedals when parked. I love that they included a 3amp charger, typically, I see 2amp chargers on bikes like this, so the 3amp should get you out of the house a bit faster than the slower 2amp. To really care for this and other lithium-ion packs, I have heard that storing in a cool dry location vs. extreme heat or cold will extend the life and try to keep it about 50% full when not using for long periods so you won’t stress the cells. Try not to let it run down to zero, because that’s really hard on the cell chemistry.
Controlling the bike is super simple and straight forward. That is because the bike is using a minimalist display that really only tells you 1 of 3 things. It is an intuitive rubberized pad with 5 series of dots on the right and on the left. The 5 dots on the right indicate battery charge level, while the 5 dots on the left indicate what mode of assist you are in. Oh, there is also a middle light that indicates if your lights are on (however, this bike doesn’t have any) if applicable. The display can be swiveled, but it lacks USB device charging and also is not removable. However, it does have a walk mode, and even an integrated smartphone app. The app syncs up nicely, and you could even mount your phone on the handlebar to use it as a more detailed display. They have things like route planning and even settings to optimize the drive system. Normally, I would be a little harder on such a basic display, but I really think its good they hid the electric aspects and you can still get extra functionality through a smartphone app, pretty slick.
The Giant Explore E+ 4 GTS is a great all around “do anything” kind of bike. I also think the high quality components (Yamaha mid-drive, Shimano Deore derailleur, etc) are an awesome deal for a $2,500 bike. But no bike is without tradeoffs. In the case of the Giant here, I would have to say not having shift detection is kind of a missed opportunity. Granted, that is more of a Bosch motor thing, but it works good on applications like this. There are no battery integrated lights in either the front and rear, something that the minimal display reminded me of now and then. And that display itself, may not be for everyone. It lacks some detailed information and cannot be removed. However, the smartphone app pairing may be able to give you some of the extra features you crave. All in all, the bike seems great and I love that you get a 2 year warranty and dealer support. After all, Giant is one of the big 3 (Trek, Giant, and Specialized), so you know you are getting quality product. I want to thank Fullerton Bicycles for letting me check it out and I look forward to you guys sharing your experiences with it.
As always, I welcome questions and feedback in the comment section below. Whether you own the bike, have taken a test ride, or are brand new to the space, my goal is to provide an objective and honest resource. You can also join the Giant ebike forums and share your own photos, videos, and review updates to help others! Have fun out there, and ride safe :)
Pros:
- A great all around “do anything” all purpose mountain ebike with possibilities for not only light trail riding and off-roading, but as a commuter setup as well
- Can double as a commuter because it comes with rear rack bosses, fender bosses, kickstand provisions, bottle cage bosses, and even extra threaded eyelets in the back for a cafe lock
- Uses a heavier Yamaha motor and front suspension, but it still a lightweight bike, for example, the medium size frame we are testing today came in at just 49lbs
- To facilitate that all purpose feel, it has these 700c x 45 studded tires, so kind of a good balance between efficiency and capability
- I did notice a quick release in both the front and the rear, this is awesome for not just maintenance or flat tire repair, but also if you need to take the wheel off to move it around in a trunk or truck, really cool
- Good comfort from the 60mm of travel RST fork with preload adjust, also these large sized Giant branded locking ergonomic grips
- Another great feature of this bike is that it doesn’t scream “Hey, look at me! I am an electric bike!”, due to the sleek frame integrated battery and the very minimalist display that you might miss if you even blink for a moment
- Uses a Yamaha PW series motor that has been rebranded by Giant as SyncDrive Sport, 250 watts with 80nm of torque that measures both pedal torque and pedal cadence, very quiet, efficient, and best of all, reliable
- Comes with a nice 9 speed Shimano Deore setup with hydraulic disc brakes with 180mm rotor in the front combined with a 160mm rotor in the rear
- 36v 11.3ah battery tips out from the side for easy loading/unloading, has an LED charge level indicator, and is secured via lock and key, comes with a 3amp charger which is faster than the 2amp you see often
- Minimalist display is very straight forward and easy to use, can be paired with a smartphone to do things like plan a route or even settings to optimize the drive system
- High quality components backed by some of the best names in the business (Giant, Yamaha, Shimano), a 2 year warranty, dealer network, and is a great value at $2,500
Cons:
- I noticed that charging while on the bike is done near the crank arm, so do be careful not to snag that cable by rotating the pedals when parked and charging, something to be aware of
- I would have to say not having shift detection is kind of something I miss here, granted, that is more of a Bosch motor thing, but it works good on applications like this
- There are no battery integrated lights in either the front and rear, something that the minimal display reminded me of now and then
- The minimal display may not be for everyone, it lacks some detailed information and cannot be removed, however, the smartphone app pairing may be able to give you some of the extra features you crave
- Minor gripe here, and you see it a lot with high brand name bikes like this, but there is no kickstand included, just kickstand provisions, so make sure to source on if that is something you want on your bike
Resources:
- Official Site: https://www.giant-bicycles.com/
Rosa M says
Hi Court, if you were to run this bike as on road only, commuter only, what tires do you like? Stock 700 x 45mm is good but I’m pretty sure it can take wider, so I’m also thinking 700 x 50mm, or 29er (for the comfort). And would you go e-bike specific?
Court says
Hi Rosa! You’re on a good path there thinking about slightly wider tires and ebike specific… but I’d probably just target anything with puncture protection that has reflective sidewalls and is a similar width. If you go too wide, sometimes the tires can touch the bike frame, but it looks like there is plenty of room on this particular frame both at the fork and the rear seat stay and chain stay arms. Here’s a good example of a tire that comes close to the official 700x45c stock tire size. It’s a bit narrower but has some of the nice upgrades ;)
Browneye says
Just ordered the last 2019 – think its going to be a great bike! I’m adding SCHWALBE Marathons, a suspension seatpost, a riser stem, and a phone holder.
Court says
Fantastic, those are some great accessories! Hope the bike works well for you and I’d love to hear your comments and feedback over the years of use here or in the Giant ebike forums we setup :D
JIm Conboy says
What suspension seatpost, and riser stem did you order?
Browneye says
I got a Satori Harmony post – it’s a cheapo but works well enough for me. It doesn’t move much and is pretty firm, but does soak up some of the hard jolts. Other options work better but cost more. $250 wasn’t in my realm. LOL
The stem riser I got on amazon, but you could search for other sources online, or your lbs may be able to order: Wake MTB Stem 45 Degree 31.8 90mm Bike Stem Mountain Bike Stem Short Handlebar Stem Riser for Most Bicycle, Road Bike, MTB, BMX, Fixie Gear, Cycling (Aluminum Alloy, Black)
$15 and works great. Put the bars up just prefect for me. If I’m leaned over too much it stresses wrists and back.
Dick Thomson says
I just found out that my LBS has taken on the GIANT line. The owner knows that I’m looking to purchase an ebike. The Explore E+ looks like the perfect choice for my riding needs (rails to trails) but my biggest concern is the bike’s maximum range. In your review you indicate a maximum range of 55 miles. On many of my rides I’m looking at 60+ miles. Does anyone out there have any real world experience with the Explore E+ regarding what this bike is predictably capable of achieving in maximum range on a charge?
Court says
Hi Dick! Wow, this is a tough question because range varies so much depending on rider weight, tire pressure, terrain and terrain incline, wind, ambient outside temperature (colder may shorten range but extreme heat can damage lithium-ion cells) and the level of assist. In my experience (as a 135lb guy who is pretty fit), I can get 50+ miles if I use the second and third levels of assist… but it drops a lot when you go to the highest. I keep an eye on the battery and range estimator features (when they’re available) and I switch gears proactively. I also bring my charger a long so I can stop at a cafe or take the battery into work for a fill up. You may be able to get a double-battery ebike from a company like Riese & Müller or the new one coming out from DOST Bikes, but they tend to cost a bit more.
Dick Thomson says
Court… Thanks for the timely feedback. I really like the Riese & Mueller bikes, and yes they cost more than most other ebikes, but what I’ve seen they’re not overpriced for what one gets. Because winter is rapidly approaching I won’t be making a purchase until early next spring, so I’ll also take a look at the DOST Bikes and am also anxious to see what the BULLS 2020 Lacuba EVO Lite looks like as it’s specced out with a 750kwh battery… Again thanks for your feedback and all your terrific reviews.
JP says
After watching a bunch of your reviews you seem to like them all. Is there a place where you have compared them against each other and declared what your favorite ebike is or at least the best of 2019?
Court says
Hi JP, I have created this page which lists out my favorite recent ebikes (some 2019 and some 2020) to help narrow it down. I do not like every ebike, but I approach each with an open mind and describe what I see. I then leave the comments open so people can express their real-world experiences. Same with the EBR Forums. I hope this helps guide you a bit more!
Michael says
An e-bike with NO integrated lights at this price point? Deal breaker for me.
Court says
It would be nice to see some lights on this bike, I think they were positioning it as a hybrid that could take on some trails… and most of the time, trail and mountain bikes don’t have lights. Still, a lot of customers might buy this for town and paths, so integrated lights would be great :)
Michael says
Got it. For me an e-bike is not really a hybrid w/out integrated lights. What would you recommend for commuting/gravel light off-trail hybrid bike? I like the Bulls EVO line, but looking for something around $3k or under.
Court says
I see, thanks for the feedback. Have you seen the Trek Verve+ 2? We just covered it but haven’t fully published the video on YouTube. This ebike fits your description, but doesn’t come with a suspension fork… is that a deal killer? I really like the OHM Quest, which does have suspension, but it’s over $3k. You could drop down to their Discover model, but it doesn’t have suspension again. If you’re okay with a hub motor setup vs. mid-drive, Magnum has some great options. I suggest scrolling through the commuting ebike category of the site because all of those bikes will have fenders, a rear rack, and lights ;) I’d love to hear what you end up choosing!
Luke says
Hi Court. I’m looking for a versatile e-bike that will primarily be used for commuting and gravel riding, but would also like to occasionally hit some light trails. I was looking at this bike as well as the Trek Allant +7 and Specialized Turbo Vado SL 4.0. Which of those do you think would fit that role the best? (assuming cost is not a factor)
Court says
Hmm, my personal favorite has been Specialized because of the light weight and unique bottle battery range extenders. Trek is hard to beat, the Allant +7 is awesome and with all of their dealers and Bosch hardware, that’s an easy win. Giant has been a little tougher to reach and seems to use non-standard batteries. They would be my last choice, personally. So, if you care about suspension and bigger tires, Trek might be the answer… especially for gravel and maybe having more power? The new Specialized SL models are incredible, so if you are okay with a carbon fiber fork and the Future Shock 1.5 suspension stem, then it would be my choice (again, the rack carries less weight, the motor is a bit weaker but still very satisfying, the fenders are also awesome).
Steve says
I like the style of this bike for a mix of on and off road, but Giant is the least convenient to me of the major brands. What would be a good alternative to this bike preferably with Bosch components?
Court says
Hmm, I really like Trek. Felt can also be good, but they seem to have even fewer dealers. Specialized has some amazing products now (though not with Bosch). Their SL drive system is light but highly performant. Perhaps you could just scan through the city and hardtail categories here to see if anything else jumps out. Bosch also works with Moustache, which has some awesome products :)
