The RadWagon is the second electric bicycle from Rad Power Bikes which started out with a fat ebike called the RadRover (crowdfunded through Indiegogo in early 2015) and has been working in the space since 2007. The Wagon emphasizes value and is one of the most affordable electric cargo bikes I’ve ever seen… To keep the price low a few components have been stepped down including the Shimano Tourney TX drivetrain, basic adjustable stem, independent rear light and cheap grips. But where it counts, things are done right and there’s a lot to appreciate including wood platforms on the rack and running boards, full length fenders, front and rear lights, oversized 180 mm disc brakes and a sturdy double legged kickstand. Compared with similar electric offerings from Yuba and Xtracycle the Rad Wagon is shorter in length and quite a bit heavier at ~75 lbs. It’s built on a steel frame that helps to dampen vibration and features large Kenda tires and a Velo Plush saddle to smooth things out further. The most impressive aspect to me is the price… which is enabled through the “online only” sales model that Rad Power Bikes uses. You will have to assemble parts of the bike on your own (or with the help of a shop) and cannot try it in person first which means the ~17″ frame may or may not fit your body perfectly (I’m ~5’9″ and it felt comfortable). You do get a one year warranty here and even though the company is relatively new I feel like they are well funded and operating in a professional manner.
Driving the bike is a quiet and smooth 500 watt gearless hub motor. Not having gears, this motor is able to offer regeneration as well as power but it also weighs more and isn’t as strong at low speeds. Many people ask “can you pedal an electric bike to charge it” but that’s not really the point here given the 10% to 15% efficiency. Basically, with a larger and heavier bike like this the regen feature just lets you save wear on your brake pads and extend range slightly if you’re coasting down hills for part of your ride. The top speed of the bike is ~20 mph and you can operate in either pedal assist or throttle mode. I love that there’s a throttle only setting (level zero) and that you can override assist at any time with full power using the twist throttle. You can also completely disable the throttle using the red on/off button near the right grip. I noticed a quick disconnect point in the wire running to the hub motor which will make tuneups and fixes easier but there’s no quick release back here… just in the front. The bike uses a sine wave controller that puts out up to 20 Amps and controls power in a smooth way.
Powering the motor and front light on the RadWagon is a high quality 48 volt 11.6 amp hour battery. Inside are Samsung 29E cells that use a Lithium-ion chemistry aimed at being light weight and long lasting. To extend their life, store the pack in a cool dry location (avoid extreme heat and cold) and if you’re not going to be riding for a while leave the pack at ~50% instead of plugging it in. Check in on the battery every few months and fill it back up if power has been draining. I like the mounting location of the battery here because it’s out of the way and somewhat protected by the frame. The pack weighs about seven pounds and that weight is kept low and center for improved handling and balance. I did notice that when braking the rear tire can skid more frequently than on shorter non-cargo bikes because there’s less weight over the rear wheel. Getting back to the battery, one of the downsides I noticed is that you have to turn the pack on independent from the display console (so that’s two on/off steps). It’s not a huge deal but there is more potential for accidentally leaving the battery on which could drain its power. Same deal for the rear light, it’s independent from the main battery and runs on separate cells… if you turn it on but forget to turn it off while parking overnight you may come back to a non-functioning light in the morning. I would prefer that all systems run off of one main battery and that there be only one on/off switch to make it fast and easy but this design still gets the job done and saves money. The battery casing is a generic “dolphin” style and the rear light doesn’t require extra wires as it would if it were integrated.
Operating the bike requires a couple of extra steps but also includes some nice extras. Once the battery is charged and locked to the downtube you press on and then on again at the button pad near the left grip. The LCD display comes to life and shows your power, assist level, speed and distance stats. At this point, you can hold mode to activate the headlight and then reach back to click the on/off switch for the tail light. At any point if you want to go, make sure the red button on the twist throttle is in and then twist! For improved range and a bit of exercise you can arrow up through five levels of assist and the 12 magnet cadence sensor (near the right crank arm) will sense movement and activate the motor. It’s great that they used a higher end cadence sensor because it’s very responsive but the brake levers are wired in to cut power to the motor so if you ever feel out of control just squeeze. Another benefit to cadence sensing vs. torque on an e-bike like this is that you don’t have to push hard to get the motor going, it just listens for movement and then puts out the specified power and speed (low for level 1 and higher for level 5). I tend to ride in level two or three and then use the twist throttle for a boost of power when passing fellow cyclists or topping hills.
In recent years, established electric bike companies have been investing more and more money into designs. Some bikes like the EdgeRunner have a smaller rear wheel for lower center of gravity when hauling and use a mid-drive motor for increased torque and efficiency. This is awesome but it also costs 2x to 3x as much money. The RadWago is a competent electric cargo bike that could empower you to haul groceries, bring kids along or completely eliminate your car or motorcycle. It’s a solid platform with thoughtful accessories, a good warranty and a lot of potential. It might not go as far as a mid-drive bike but the charger is small and light weight… in ~1 hour you could refill to ~70% and easily get home. If you’ve been considering a utility oriented bicycle but weren’t sure about the added weight and size, this bike addresses those concerns by adding electric power and being a bit shorter. It feels sturdy and stiff and also comfortable but you could add something like a Thudbuster to smooth things out even more. Just remember to turn that battery and light off when you’ve reached your destination ;)
Pros:
- Compatible with many of the leading cargo bike accessories from companies like Yuba and ExtraCycle, add a child seat, sidecar, extra set of handlebars and many other utility-oriented extras
- Shorter wheelbase than traditional cargo bikes, makes it stiffer to ride and somewhat easier to store if you have limited space
- Durable gearless motor operates quietly and offers regeneration to help recoup energy when coasting down large hills (and save wear on your brake pads)
- Quick release on the front wheel and removable battery pack (makes bike lighter for transport) there’s also a quick disconnect in the power cable going to the motor but taking it off requires a wrench because it uses standard nuts
- Very stable when parked thanks to the oversized double legged kickstand, there’s also a deflopilator spring running from the fork to the downtube to keep it straight when loading gear
- Protective clear plastic guards are mounted to both sides of the rear wheel, this should keep strapping from packs away from spokes and the tire (reduced rubbing and snagging potential)
- Useful accessories including full length plastic fenders with mudguards, front and rear lights (though the rear light runs off of independent batteries and not the main pack) and reflectors
- Comfortable saddle with integrated handle for easy lifting when repositioning the bike, larger tires smooth out bumps, ergonomic grips relax hands a bit and the adjustable stem helps to optimize body position when riding
- Offers throttle only mode as well as throttle override offering full power that overrides assist, five levels of pedal assist help to conserve power and extend range
- Responsive pedal assist uses 12 magnets vs. 5 or 6 on more basic ebikes, this helps it get going quicker and stop when you discontinue pedaling, I like that the brake levers have motor inhibitors and also activate regeneration mode
- The steel frame helps to reduce vibration but you could add even more comfort by adding a seat post suspension like the Thudbuster (just make sure you get the 27.2 mm diameter to fit or use a shim if you buy a smaller post)
- Two integrated USB charging ports! One is located on the right side of the battery pack but can get in the way if you’re pedaling so the second one is right up on the display (right side) so you can charge your phone or other portable electronic devices
Cons:
- Adjustable angle stems like the one used here can come loose over time if you go off-road or ride off of curbs… consider checking it regularly
- Only available in one medium ~17″ frame size, the mid-step frame and low seat post makes it accessible to shorter riders but some larger people could feel cramped
- Currently only available online so it may be difficult to test out in person, the warranty is solid and Rad Power Bikes has been in business for many years
- In order to start the Rad Wagon you first have to activate the battery pack and then press power again on the button pad, this adds time and makes it easier to forget to de-activate the battery after a ride
- The battery pack takes up most of the space where a bottle cage might mount and the controller box is already fastened to the seat tube so no bottle cages… consider a saddle rail adapter or something like a Camelbak
Resources:
- Official Site: http://www.radpowerbikes.com/pages/radwagon
- More Pictures: https://goo.gl/photos/5ZqBQ2rLBHF7d2QN7
Kelley says
Thanks for your review. You mention the bike should be compatible with some Yuba and ExtraCycle components. Do you know if specific components are compatible or if there is a resource for this information?
Court Rye says
Hi Kelley, I got the impression that all or most accessories would be compatible (at least with the rear rack tubing portion of the bike) but I’ve reached out to Rad Power Bikes to get more info and will chime in again once they respond :)
Mandy says
Thanks for all the great review on your site, they are extremely helpful! I am interested to hear the reply about the accessories, in particular the Hooptie and/or Monkey Bars. I will purchase this bike if one of those options work. With a three year old I’ve been very interested in the “family style” options of cargo bikes with the rear decks, but have been put off by the price point of the assisted Xtracycle and Yuba. The RadWagon seems like it may be a great choice, but would love the added piece of mind the inner and outer rails of the Hooptie and Monkey Bars provide for kids on the back.
Sharon says
http://cambriabike.com
I ordered my Rad Wagon accessories on line from the link above. I ordered the handlebars, breadbasket and padded seat. Hope this helps.
Sharon says
I just googled accessories for Yuba Mundo and several sites appeared….Merry Christmas!!!!
Court Rye says
Cool, thanks Sharon!
Mohcine Chaouki says
Do you know if anyone was able to retrofit the Monkey bars on this bike? ~Thanks!
I bought the bars from the cambria site, but they are a bit longer than the back seat dimensions.
Mike says
Hi Mohcine,
We will have a great solution for this listed on our website for sale within the next 30 days. The length and mounting hole locations of the other accessories on the market make it challenging to install on the RadWagon, but we expect that you will really like what we will be offering, stay tuned, and thanks for the support!
-Mike from Rad Power Bikes
George says
Radwagon owners, how is the bike holding up? Also, to the company–how long have you been in business? Are parts readily available? Tech support offered? Thanks.
Rad Power Bikes says
Hi George,
We have been in business since 2007 and replacement parts are readily available and stocked in our Seattle warehouse. We have an experienced tech support team ready to help as needed and we strive to provide same day responses as well as same day replacement part shipments if anything is needed on your end!
– Mike from Rad Power Bikes
N. KANTH says
How to buy please send the details, about price and buying
Court Rye says
This bike is sold through their website here. You can buy it and other models and they will ship them directly to your house :)
TenBlinkers says
My RadWagon experience so far. I have 1,500 miles on it since February, and I like it a lot.
Pros:
Cons:
On balance though, for my first ebike it’s been a lot of fun and I don’t regret the choice. Now to convince the wife I need a speed pedelec for ‘backup’…
Court Rye says
Excellent points, I enjoyed reading your cons and can relate to some of the difficulty working with shops (either for parts or just outside of their specialty). Most of the bikes I test are new so spokes aren’t loose but I have asked about this sort of thing before and heard that Loctite Blue can help to keep them secure. I hope the 13 and 14 gauge spokes hold up for you!
Lyn says
I’m seriously considering the rad wagon as my first e-bike. Tested the spicy curry and a couple front boxes and loved them, big am balking at their price tag. On the other hand, I’m reading a few reviews that indicate that quality may be list due to the lower price. Given that I’m not an experienced bike person, how much maintenance will I be doing in this bike? How much more did you spend on the upgrades? I currently commute to work by bike and will now be adding a stop to drop off my son at preschool. It’s a total commute of four miles one way. In a perfect world, I don’t drive at all when in town. Thanks for any guidance you can provide. I’m really trying to make the right choice here. Oh yes, and finally, do you find it easy to keep the bike safe from theft?
George J says
Purchased my bike 3 months ago and already logged in over 700 miles. Runs well and no issues yet. I was worried about the non standard spokes so purchased a few –just in case. Last week I was caught in a very heavy down pour 10 miles from home, soaked when I got home but bike ran without difficulty. I would buy it again. No regrets.
Court Rye says
That’s awesome feedback George! Ride safe in the rain, glad the spokes are holding up and the bike hasn’t had any issues even with the weather :D
bill says
Eventually, the electronics will fail. The company Rad may not exist by then. Will I end up having a non functional e-Bike? Are there any third party electronic controllers?
-bill
Court Rye says
Hey Bill, sure! There are companies that repack batteries and others that sell controllers. Rad Power Bikes uses less proprietary stuff and the controller box is separate. Given their success and the thousands of people that own the product I’m guessing a third party after market solution would pop up. There might already be options you could find on Ebay. I’m not much of a hacker when it comes to ebikes but you can check out Endless Sphere forums and ask for tips in the event that you need technical help… also the forums here to some extent :)
Antia says
I have now had my Radwagon for over a year. Overall I am pretty happy with the bike but as a learned more about e-bikes and about my own use, I have modified the bike to better fit my needs.
I use the bike for commuting and for taking my kids (2 and 4) to daycare, a total distance of 7 miles each way. I also live on a very steep hill. I bought the aluminium accessory deck and the caboose to transport the kiddos. The bike works great as stock but it is limited in the amount of torque it can provide at low speeds, which meant that I could not get up the hill I live on with the two kids on board and I could just about manage with one and pedaling furiously. I have to say that the hill is beyond the specified capabilities of the bike, so this is not a ding on rad but rather a reality of where I live. Once on the not so hilly areas, the bike worked great and my kids absolutely loved riding in the back. This issue with the hill made me look into possible modifications and I ended up mounting a mid drive motor (BBSHD) onto the frame, which was straightforward. I took out the rear wheel with motor and associated electronics and moved them only another bike. With the mid-drive motor, the radwagon frame is fantastic and works perfectly for my application. I like that it is just slightly longer than a normal bike and behaves in a very natural way. I use the motor as an assist and pedal all the time, so I appreciate that the bike behaves “normally”. The battery was plenty for my commute and back with either the original motor or the middrive, I never had any issue. As someone mentioned in one of the other comments, rad uses non-proprietary batteries so I was able to use my original battery with the new motor without any issues. Recently I also upgraded the stock handlebar to a Jones loop handlebar. Again, there was nothing fundamentally wrong with the original, I just find that I don’t particularly like straight handlebars and prefer a different geometry. I originally bought the Ballard cargo bags and I have to say they are just ok. One of them had 2 of the holding straps break off within the first few months. The way to mount them to the bike is also not very convenient if the deck is installed (which typically would be). I would not buy the bags again if given the opportunity. The caboose is very nice for carrying the kids. I just changed the nuts they provided with butterfly nuts so that it is easier to take on and off.
Overall, I really like the frame of the bike and the fact that it is fundamentally a non-proprietary design, just a very sensible selection of parts that work well together. This meant that I started with a reasonably priced bike that works great and was able to slowly upgrade bits and pieces to customize it to my use case. It is a shame rad does not offer this bike as a pure frameset as it makes for a great platform for a custom ebike.
Court Rye says
Hey Antia, great overview… thanks for checking in after a year of use with this bike. I’m glad the frame is holding up for you and that you took a risk and tried modifying it to fit your needs better. Sounds like you and your kids are enjoying it :)
John says
I’m 6’2″ — will the Radwagon be too small to ride comfortably?
Court Rye says
High John, you might be at the upper end but with a raised saddle slid back on the rails and maybe a longer solid stem it could work well. There aren’t many cargo ebikes that come in multiple sizes, especially at this price. You’d be well served to look at different bars, different stems and even a longer seat post to make this work. I like suspension seat posts and Thudbuster makes longer ones. Hope this helps… you didn’t mention your weight but there are a number of mid-drive cargo bikes now from Xtracycle and Yuba that would climb better if your budget permits. I’m about to review the Bosch powered Yuba today so it’s kind of top of mind :)
Robert W Green says
Court, I love this bike, it’s like a two wheel pickup truck! Those mtb handlebars have to go though. I’d rather have cruiser handlebars so I can ride sitting up straight. Next year when I get my tax refund I’m going to get one of these and cruiserize it. Only kink in the plan is I don’t see any slack in the wires and that will make populating the extra real estate on the longer bars very difficult. Can they add extra long wires and cables to accommodate different handle bars?
Court Rye says
That’s a great question, Robert… Now that Rad Power Bikes has a retail outlet in Seattle Washington, I bet you could call and ask for some feedback and maybe even a customized version. I can’t say for sure, but maybe they would be able to adjust yours before shipping it out?
Aaron G says
The caboose on the radpower site has been out of stock for a while. Does anyone know if the Yuba Mini Monkey Bars would mount on the radwagon?
Court Rye says
Great question Aaron, maybe this is something the folks at Yuba could help answer for you? They sell an ebike too, called the Spicy Curry, and might be familiar with the RadWagon. I’m just going to go out on a limb here and say that I think they would be interchangeable, and you could probably return them if not… if you try it, please let us know!
