The Riese & Müller Packster combines comfort with utility so you can haul large loads (or children) without the vibration and discomfort that some other e-cargo bikes are known for. It comes stock with an alloy frame only, no wooden deck planks or front box. There are several options to customize the front area but if you opt for the Basis-Boards (flat deck) only, it’s impressively narrow and maneuverable. I was able to squeeze between cars in the busy traffic areas of Brooklyn New York as I would with a traditional bicycle. Steering and turning the Packster felt stable but required more space because the front wheel does not pivot side to side all the way to 90 degrees… and the bike is just so so long. I tested the Packster Touring 80 model which has an 80 cm front load area vs. the Packster 60 with a 60 cm front loader. That’s a lot of space to work with but for those who need even more capacity, Riese & Müller sells a traditional rear rack with bungee clasp system that mounts over the wheel. Other owners have gone one step further, mounting trailers like the Surly Bill to the rear axle. Without any of the accessories (but including the battery and motor) the bike weighs around 80 lbs, which is a lot for any electric bicycle. But for that weight, you get a stiff, capable frame that can handle nearly 500 lbs of cargo load + passenger combination without enduring frame flex or wobbling. That’s saying a lot given the non-locking suspension fork and smaller 20″ front wheel. Sometimes small wheels can feel unstable because they are light and turn quickly, but they also tend to be stronger than wide wheels with longer spokes and position weight lower which is perfect for loading cargo. The large, heavy front loading area of this bike combined with rod steering seems to slow the steering down a bit and results in a natural stable feel. The rear wheel is 27.5″ which is a size usually reserved for mountain bikes. It does not have a suspension system but the larger volume of air in the 2.4″ tire smooths the bumps out. Both wheels have hydraulic disc brakes for powerful stopping and you get adjustable reach levers which can accommodate small hands or gloved hands. Between the adjustable brake levers, adjustable height stem (with six locking points for strength) and adjustable height seat, this one-size electric cargo bike is quite capable of handling a wide range of riders. And, if you need to get places quicker, the Packster is available with a Bosch Speed motor vs. the CX shown here. You’ll lose a bit of torque with the speed model, but that’s not so bad given the 10-speed drivetrain or infinitely variable transmission (the NuVinci CVT) option. You just need to shift properly and get to lower gears before coming to a complete stop. I especially like how the NuVinci drivetrain option can be shifted at standstill. The Bosch motor does offer shift sensing, but it’s not perfect and the 10-speed drivetrain could grind and mash if you force it. Shift consciously by letting off of the pedals a bit just before changing gears and the torque sensor will reduce motor torque as well. In short, the Packster platform is versatile and extremely capable, each bike is built to order which takes a month or so to deliver and it comes at a higher price point, but it’s well made.
Driving the Touring 80 model is a Bosch CX motor that’s capable of exerting 75 Newton meters of peak torque. I’ve ridden this same motor on full suspension mountain bikes, ascending steep technical terrain, and it’s quite impressive. Power is one thing but power delivery, when you need it, can be so much more important. The motor and controller system allow you to move slowly and smoothly but will jump in to help you immediately as pedal pressure is applied. The system measures your rear wheel speed, pedal cadence, and pedal torque 1,000 times per second. The smaller chainring spins about 2.5 times for every crank arm revolution and in my experience, it starts and stops faster than other systems. The chainring doesn’t take as long to spin up and spin down. This design gives the motor a mechanical advantage over the drivetrain and externalizes some of the gearing, keeping the drive unit compact. It’s attached to the frame on a custom curved alloy plate and does hang down a bit, but the internals are well protected by plastic covering. One complaint about the Bosch Performance Line motors is that they do produce an audible hum that increases with motor speed. One compliment I usually give is that is offers shift-sensing to automatically reduce power when you change gears. This system is not perfect, you can still grind gears if you’re pedaling hard and shifting rapidly, but it’s better than nothing. And this is where the NuVinci CVT option really shines. You aren’t really shifting gears there, more like sliding between gears, so you won’t be straining sprockets or a derailleur… and the chain is set to a fixed length. The NuVinci is heavier and more expensive but stays cleaner and can be more durable than sprockets.
Powering the bike is a new long-range Bosch Powerpack with ~500 watt-hours of capacity vs. the old 400. It’s mounted low on the frame for improved balance, just above the motor mount, but remains protected by a short top-tube bar. The pack locks securely to the frame and can be charged without removal using the lightweight Bosch charger that puts out four Amps vs. many others that just send two. Given the size and weight of this bike, you might want to charge and store the battery separately. Whether it’s on or off the frame, you can tell how full the battery is by pressing a button on the side, illuminating up to five green LEDs. I love that the battery is so light and easy to carry, it has a plastic loop handle at the top so you won’t drop it as easily. And, as mentioned earlier, you can purchase a second battery that mounts to the back left side of the box options. It’s a decision best made when purchasing the Packster however because it requires a separate interface and display setting. With two packs connected, the control system dynamically balanced power and displays both charge levels. In this way, it helps you avoid over-cycling one pack while leaving the other mostly unused. It’s a wonderful option for those who intend to go further and carry more but it will add ~$1k to the already expensive bike.
The display panel on this bike is excellent. It shows your speed, battery level, trip stats and assist level on a large, bright screen that can be removed or locked to the frame. In the video review above, you may have noticed that I tried to get it off but was unable to because Chris had locked it down for the customer. In this position, it still swivels forward and back to help you get a perfect viewing angle and reduce glare. Buttons on the display include reset, power on/off, information and lights. You can hold reset and i simultaneously to enter into the settings menu and adjust the clock, shift recommendation and units. Perhaps my favorite part of the display is a Micro-USB port built into the right edge. While it only puts out 500 mA at 5 Volts, which is not enough to charge iOS devices… just maintain them, it can charge Samsung and other products which can be useful if you use GPS to navigate. Just mount your portable electronics to the handlebar and turn the display on. Near the left grip, there’s a three-button control pad that replicates the i button and introduces an up and down arrow for navigating through Eco, Tour, Sport and Turbo pedal assist modes. I tend to ride in Tour to extend range but heavy loads might require Sport or Turbo. By pressing the i button several times, you can get to a “Range” menu which will compute an estimate for how far the bike thinks you can travel with the given battery charge level, selected assist level and last three miles of performance. This is a great feature that can save your legs if an unexpected trip comes up and you’re debating between speed and power or efficiency.
There’s a lot to say about the Packster series from Riese and Müller. It’s extremely versatile and very well made. You do notice that it’s a cargo bike when riding, it’s heavier and longer, but you don’t sacrifice as much in the way of maneuverability as I initially expected. Sure, we were riding with the cargo space completely empty… but the streets were busy and I was going over some rough terrain. It would have been easy to skip the suspension fork, but your kids and cargo would definitely notice. They could have offered a single frame length instead of two, but that would have excluded so many possibilities. It’s amazing to think about the customer who was ordering the 80 cm version with a rear rack and trailer… This bike is capable of pulling a lot, it’s probably the most capable mainstream electric cargo bike I’ve seen. It would be great to hear from some actual owners here who have loaded their Packsters up in different ways. Big thanks to the Riese and Müller team for partnering with me on this post and Propel Bikes in Brooklyn for taking me out to do back to back tests of the latest models. It really helped to accentuate the benefits of one design over another when testing them like that.
Pros:
- Offers a whopping 31.5″ (80 cm) of loading length on the front deck, that’s more space than almost any other electric cargo bike I’ve seen and it’s very versitile
- Heavy-duty Shimano Deore Shadow drivetrain, commonly found on mountain bikes, helps to support greater load forces
- Very few electric cargo bikes introduce suspension because it adds weight and can reduce stiffness, changing handling, but the Packster has successfully added a short-travel suspension fork to cushion the load and it works very well with the slightly fatter tires
- Extra-large hydraulic disc brakes provide the stopping power necessary for an 80 lb bike plus cargo… maximum load capacity is near 500 lbs!
- You get the larger 500 watt-hour battery from Bosch standard and can upgrade to a second battery for a combined rating of one kilowatt-hour of capacity, that’s perfect for extended use and hauling heavier loads (you need one of the box options to mount the second battery)
- If you decide to upgrade to a two-battery system, the Bosch Intuvia display panel will balance the packs automatically for prolonged use, also, you can charge both bikes at time if they’re mounted to the bike
- Optional Basis-Boards create a stable mounting platform in the front cargo area and you can upgrade further to a Basis-Box with tool-free removable sidewalls… the final option is a Kids-Box which has backrest, seat cushions and seatbelts for safety (seating children in front vs. back makes them easier to manage and communicate with)
- Optional tarpaulin can be added to cover the Basis-Box so your cargo doesn’t get wet, it’s made of waterproof Cordura and attaches sturdily without blocking your view… there’s also a cover for the Child-Box which is taller and has windows
- I love that they offer two drivetrains (the lightweight 10 speed with derailleur or flexible-shifting continuously variable transmission hub) as well as two motor types (the high torque 20 mph Bosch CX or high speed 28 mph Bosch Speed)
- This is one of the only electric cargo bikes I’ve seen with the option for high speed and given that it’s a two-wheel design and fairly narrow (if you don’t get a box) it’s nimble and can be ridden in tight spaces fairly easily
- Integrated lights, a highly visible light-grey paint option and extra reflectors,
help this ebike stand out (especially if you’re riding in low light conditions), I love how the headlight is mounted on the fork and points where you steer - Sturdy and stable double-leg kickstand keeps the bike upright when loading, it has an arm that you step on to lift the bike up and then you simply roll the bike forward to stow it
- The seat tube is angled back so the higher you position the saddle, the more reach you’ll be given (great for tall riders), notice the adjustable height stem too, it has six locking points and felt strong and reduce slop (side to side) so you don’t have to over-tighten the quick release collar
- Some of the shifter, brake, and electrical cables are exposed near the handlebars but are quickly routed into the frame which presents a clean aesthetic and reduces snags (important when loading/unloading cargo)
- Excellent use of a cafe lock, it comes standard with the bike and allows you to immobilize the rear wheel using the same key as the battery pack! since the bike is 80+ lbs,
it would be difficult to lift and run off with - Despite the length and weight, this cargo bike feels steady and doesn’t have as much front wheel shimmy or wobble at speed and under heavy load
- You can enable walk-assist so the bike will push itself forward at a slow speed while you walk next to it, this could be very useful in crowded areas or when getting the bike out from storage given its size and weight (press walk assist on top of the button pad then hold the up arrow key)
Cons:
- This thing is much heavier than traditional cargo bikes with rear rack designs, it weighs ~80 lbs with the standard open deck but can support nearly 500 lbs of weight (rider plus cargo area)
- You have to pay $110 extra just for the standard Basis-Boards on the front rack,
I guess it reduces weight and redundancy if you choose to upgrade to the box options but the bike is already pretty expensive… not to mention a $143 rear rack that looks pretty standard and holds 20 kg vs. a lot of aftermarket racks rated for 25 kg - No bottle cage bosses… I guess you’ll have plenty of space for a trunk bag with a bottle holster if you get the rear rack, or you could use saddle rail cages, but I feel like maybe they could have squeezed them in on the steering tube or top tube?
- This is a minor gripe, but given how long the bike is and the fact that it has a limited steering angle, you may need to do a multi-point turn… it requires more space to maneuver
Resources:
- Official Site: https://www.r-m.de/en-us/e-cargo/packster/packster-touring-80-us/#17P11US_010702
- More Pictures: https://goo.gl/photos/z4YQhxVMW7qRYhGz7
Gen says
I’ve been waiting to see you review this one. I’ve got one ordered (the long box with a rear rack, though no trailer, sorry!) and am anxiously awaiting it’s arrival. I’ll be using it to haul two kids + groceries and whatever else around Seattle so the high torque motor was a big seller for me. I’ll have to provide an update when I’ve had it for a little while.
One note: R&M does not make (and according to their site does not have plans to make) the child cover for the Packster 80. I’m planning to have one made by Blaq (who also make a lot of Bullitt covers) later on in the year. I’ve seen the R&M cover for the Packster 60 in person and it seems nice but is also relatively short, which can be a problem if you are putting older kids in the box.
Two questions: 1) Were you able to enable walk assist on the bike you tested? It wasn’t active on the R&M bikes I’ve test ridden. I sure wished it was when I had to push a R&M Load with two kids in it up one a pretty steep hill a few weeks ago! 2) Have you ridden the Load? We rented one for a few days and the box is too small for my needs but that bike is impressively fun to ride. It feels as smooth at 20+ mph as it does at 10.
Court Rye says
Hi Gen! That’s so exciting, I hope the Packster works well for you and your two children. It’s an amazing bike but I did not realize that the child cover only fits the 60. Would you mind sharing the name or website of the place that is making a custom cover for you so that others might seek them out as well?
I cannot confirm walk assist, we reviewed many Riese & Müller models over the course of several days and I thought it worked on some (you press walk assist then hold the + button but must be in one of the four assist levels for it to engage). Perhaps the demo models you looked at were using older firmware? Maybe this is something the shop can update for you, perhaps Chris Nolte will chime in here or you can contact him at his shop, Propel Bikes, to ask.
I have indeed ridden the Load and I loved it! The full suspension setup makes it fun regardless of carrying but I agree, it’s not as large as the Packster. Let’s stay in touch here, I’ll signal Chris to the comment so he can provide some feedback as well :)
Gen says
In the end it took 3 weeks longer than anticipated for my bike to arrive, which was a bit frustrating. It would have only been 2 weeks longer than expected but it somehow got shipped to the wrong store at first so that caused an extra week of delays. Not my favorite part of the experience for sure.
I’ve now had it for a week and had the chance for things to start to settle in. I won’t have the rain cover for another few months but thankfully the weather has been exceedingly pleasant and I’ve put about 60 miles on the bike already. I can report that the walk assist is active, so probably a firmware update on the Load that I rented previously would activate it. So far the only problems I’ve experienced are minor. Overall the bike is solid, really well thought out, and has exceeded my expectation. My kids clearly find it comfortable and are very happy to go on rides. I’ve hauled 60lbs of kids + 30lbs of groceries up a variety of hills and can report that although there are some hills here that I’m pretty certain I couldn’t tackle even with the assist it’s generally more than enough. The bike is not making any tight turns but the extra space up front is worth it for me.
Court Rye says
Awesome! It sounds like the bike is working great… and that you have been pretty patient. I read your other comment too and agree that the Packster is best if you’ve got multiple kids plus cargo. These ebikes are amazing, I hope your cover arrives at the correct store (or directly to you) and works well, thanks Gen!
Kevin says
I’ve been having a tough time deciding between the Packster and Load, so I’m really excited for the Load review to be posted. I’ve managed to test ride both, but only briefly.
http://blaqpaks.com are the folks who make the custom canopies that are popular up here in the rainy NW.
Court Rye says
Cool, thanks for the link Kevin! I’ll have the Load review soon… I hope, getting ready to drive to Arizon and then San Francisco so the editing/posting is limited. I really appreciate you sharing the link for the custom canopy!
Kevin says
I was really frustrated to learn that according to Riese and Muller, the warranty on the bike won’t be honored if the bike is serviced by anyone other than an authorized dealer.
I already own a couple of cargo bikes and the only way that they get to a bike shop is either on their own two wheels, or one towing the other. This apparently leaves my options as spending an entire day to rent a truck to transport a bike 100+ miles to a dealer, or spending $400 to have a bike shipped to the dealer and back.
Court Rye says
Hmm, thanks for the update on this detail Kevin. I hadn’t heard that before. It makes sense that the fancy drive systems would need a certified or authorized dealer but I figured a regular shop could still do a chain or derailleur fix… or a tire replacement etc.
Gen says
If you’ve got a car with a hitch (or access to one) you can also use a Uhaul motorcycle trailer for transport. Still not particularly simple but maybe cheaper or easier than renting a truck at least for some folks.
I’ve ridden the Load and for sheer ride quality it is amazing. Going 20 mph felt slow to me on it because everything was so smooth. But for cargo capacity and kid hauling I don’t think it could be my only cargo bike. The box is small and you can’t really expand it since it’s part of the frame. At 19 months and 4 years my kids were willing to snuggle together in there but I feel like it would be really limiting really quickly as they got older. And it doesn’t leave any room at all for other cargo in the box. I’m dying to have one eventually but for now the Packster won out for practicality’s sake.
Have you gotten to ride both?
Court Rye says
Hi Gen! I agree with your thoughts on size and multiple kids plus cargo… I did test the load as well, the high-speed version in fact! but have not posted the video and review yet. It’s in the works and coming soon. Keep an eye out this week. Thanks for the tip about Uhaul motorcycle trailers, that’s a great idea :D
Harald says
I’ve just tested the Packster 80, really considering buying one. I also tested the Load, which feels much more stabile and pleasant to bike compared to the Packster 80. When you tested the Packster 80, did you notice how wiggly the steering felt during the bike ride? The steering on the Packster didn’t really give any feedback and it felt like it was “loose”, something I didn’t experience on the Load. I know the Packster 80 is a much bigger bike than the Load, but still ..
Court Rye says
Hi Herald! I should have done more riding and loaded the Packster with cargo to really get a feel for it… but I do agree that the Load is more stable feeling and fun to ride. Where did you test ride the Packster? I wonder if maybe the steering needed to be adjusted or something? How did my video of the steering look compared to how it felt on your test ride?
Harald (pronounced Harold in english) says
Hi Rye. I tested the Packster 80 (though without the Nuvinci) in Tromsø at this local dealership. It was properly vicious that day I tested the bike, with lots and lots of rain, but still the bike was fun to ride.
Anyway. I’ve read a blogpost from a family in San Francisco where they bought themselves a Packster 80, though with one modification: They changed the steering to something that seems more ideal for the Packster and you can read about it here.
I noticed you did the same “wobbling” as I experienced with the Packster. And I think it has something to do with the fact that the steering is too far off and you need to stretch your arms. I don’t exactly have arms like a monkey, so the distance affects the steering stability. If you watch carefully, you can see in your review the wheel goes quickly left and right, and you adjust your left hand a lot to keep the bike straight. I’m quite aware that you are holding a camera, so therefore you don’t have both of your hands on the bike, but you’ll get that wobbling soon enough as you speed up (with out without the camera).
The reason for the wobbling is due to your arms being stretched so far that you can’t hold the steering in position as you pedal. That’s what I think. I don’t think it’s all about adjusting the seat and the steering in this case. I’m going borrow the Packster 80 again from my dealer and figure out if I’m nut or not about this.
Court Rye says
Very interesting, thanks for sharing these details… you articulate the concern very well and are making me think of some bikes which experience “speed wobble” where the front wheel jitters and resonates as you go faster. Smaller wheels tend to be twitchier anyway, lighter and quick to turn vs. bit wheels with fat tires. I’d love to hear your further thoughts as you visit your dealer again. Thanks for sharing those links!
Harald (again pronounced Harold) says
I forgot to mention about the stability overall. I got to test the bike fully loaded with boxes and stuff. The bike is really stabile, but I had a few “woah woah woah” moments since the bike felt heavier and I wasn’t sure how it handled yet. It was weird to use the whole road when I was turning right at a intersection, I’m sure I could have cut the corner more but my confidence pretty much screamed “Shit shit shit ..”. Breaking was also interesting, since the breaks sounded like a freight train passing by each time I used them.
Your review was very accurate about perfomance in general. I’ve previously bought an Cube Hybrid SL 27.5 based on your review on it which was spot on (I love the automatic shifter, not to mention the belt drive!). What I would added into the review for the Packster, is showing how the bike performs with a heavy load, because this bike is stabile and it’s worth showing that with tight corners and other situations. If I buy the Packster 80, I’ll most likely get the basis-box, it would be interesting to see something like that tested. The Packster 80 basis box is huge compared to the Load.
One thing that you probably can’t replicate: Winter. In Tromsø we have snow, that’s either slippery or wet (we call it slaps, it feels like you are going through mud) plus we got a lot of hills. You can perhaps look at Tromsø as an arctic version of San Francisco. I have had a hard time finding review of a Packster being tested in the artic. There’s a guy in Canada who has also tested the bike, he even threw in a camera angle where you can watch the steering here, you can see the same wobbling there.
Court Rye says
Excellent, I enjoyed the video you linked to Harald! I haven’t seen the whole thing yet but he did create that sense of perspective and the comments about not being able to see where you steer were very interesting.
Harald says
I’ve just borrowed the same Packster 80 Touring which I tested a few weeks ago, I waited a bit for the dealer to get the Tarpaulin for the Basis-Box so I could get a basic idea of how I’d use the bike if I ordered one myself.
This is the second time I test the bike, so I made sure the ride height was comfortable, otherwise I’d be wobbly and the bike in general will not feel comfortable. The turn radius is not great but doable.
One major issue with the version of the bike I’m testing, is the Performance line engine, it struggles for its life on steep hills (which there are a few of in Tromsø). The bike comes with the Shimano 10-speed deore gear, so in comparison to a Nuvinci setup, the bike should have enough umph to get 100 kg (just me and the bike) up a hill. The engine basicly dies on the steepest hills, even walk-assist had issues. I can only imagine how this bike setup performs during winter time.
I didn’t get to go up hills the last time I tested the bike, so that’s why I didn’t notice the lack of performance in the engine. Hopefully a CX engine is a lot better.
Court Rye says
Interesting, I’m surprised to hear that… and I’m assuming you were trying to climb while using the low gears to help empower the motor? The specs from Bosch do say that the Performance Line Speed produces up to 60 Nm of torque vs. the Performance Line CX produces up to 75 Nm. I haven’t had much of an issue with any of the Bosch motors climbing unless I was in a medium or high gear while starting out or going very slow. I weigh about 61 kg.
Gen says
Harald, Probably a bit late for you but in case anyone else has the same concern, I can definitely say with confidence that the CX motor is much better on hills than the regular Performance Line. I’ve met very few hills in Seattle that the bike can’t handle, even with a full load of kids + cargo. I am planning to switch the cassette out for one with a bit lower range when the time comes for a new one, but just to make it easier to pedal without assist if needed and to make starts on steep hills easier. I haven’t ridden a Packster with the regular Performance Line motor but I have ridden several other cargo bikes with it and the difference is definitely noticeable. You just don’t get the same push out of the regular Performance Line that you do out of the CX when you drop a few gears and ask it for more power.
As for the wobbliness in the steering, R&M have added a dampener in the headset on the current generation of bikes that I think helps that issue. It’s more noticeable with more weight in the front of the box. Once you’ve been on the bike a while you learn to not let your hands wiggle during turns and it becomes less of a problem. I’ve never had it actually cause any sort of dangerous situation but it’s definitely my least favorite aspect of the handling of the bike and I’m hopeful that they’ll be able to reduce the problem as they refine the bike.
court says
Wonderful and insightful comment Gen, thank you so much for taking the time to share with us and help Herald :)
David says
We have had our Packster 80 HS for almost 3 months now. We got the version with the Nuvici drive, which makes life easier when cycling a lot downtown Lund (Sweden). The bike takes our two kids, a 7-year old and a 4-year old to school and goes on to work into town from the countryside, on the way home it picks up the kids and sometimes groceries. It a road which starts with gravel roads and potholes and ends with cobblestones in central downtown. All in all it is a daily trip of about 20-25 km. So far the bicycle has performed very well and we have traveled 1700 km so far. We have ordered a tailored rain canopy from our dealer i Copenhagen but it will be another few weeks before we have it. Nevertheless, the children love it, rain or no, and are very disappointed if we for some reason opt to go by car.
It a strange feeling to almost fly given the weight and size of this thing when fully loaded. We tried the Load version but it was too small for our children. The Packster is a bit more like a cruiser, not as fun to ride but feels secure and solid even at high speed. All in all we are very happy with it but a bit worried about how it will handle a Swedish winter.
Court Rye says
Hi David, what a wonderful comment to read. Your rides with kids sound very fun, a highlight in their day and special memory to be sure. Perhaps one day, they will be riding their own bicycles together with you. I agree that a snowy winter could put a limit on riding some days, but I used to ride my own bike to school in the wet slush and even packed snow as I grew up in Colorado. My ancestors are from Norway, Germany, and Russia so I guess I am adapted for snow to a degree. Thanks again for sharing your experience with the Packster and why you chose it over the Load for your kids :)
