Urtopia burst onto the e-bike scene with a bold mission: proving that electric bikes don’t have to be heavy, clunky beasts. This innovative company has turned a few heads by crafting some of the world’s lightest carbon fiber e-bikes, packed with tech that feels more like riding a smartphone than a traditional bicycle.
Meet the Carbon 1 StepThrough – a bike that’s about to make you forget everything you thought you knew about step-through e-bikes. At just 36 pounds, this carbon fiber marvel delivers a jaw-dropping 80-mile range while packing more smart tech than most cars.
The Carbon 1 StepThrough takes everything that made Urtopia famous and wraps it in an accessible, easy-to-mount package that doesn’t sacrifice an ounce of performance or style. It’s the kind of bike that makes other riders do double-takes and ask “wait, that’s electric?”
My Experience Riding The Urtopia Carbon 1 ST E-Bike
I was sent the stealthy matte black version for testing, and it’s genuinely striking in person. Urtopia offers four colorways – matte black, grey, creme white, and glacier blue – all with that premium matte finish that photographs beautifully and hides fingerprints well. The Carbon 1 StepThrough has serious curb appeal with its flowing carbon fiber lines and integrated components creating a cohesive, modern aesthetic that stands out from typical step-through designs.
The low step-through height immediately proves its worth during daily use. Getting on and off is smooth and natural thanks to that 18.77-inch clearance, making stops at traffic lights or quick dismounts genuinely convenient. Urtopia markets this as a “one size fits most” design covering riders from 5’1″ to 6’1″, and as someone at 5’11” sitting near the upper end of that range, I found the fit comfortable with proper leg extension. However, I can see how riders much over 6’1″ would start feeling cramped – the geometry really is optimized for that stated range.
The 350W motor delivers performance that’s more impressive than the numbers suggest. At just 36 pounds total weight, this bike doesn’t need the massive 750W, 100Nm systems found on heavier e-bikes. The 45Nm of torque might look modest on paper, but it provides solid acceleration and respectable hill climbing capability precisely because there’s so little mass to move. The torque sensor deserves particular praise – power delivery feels smooth and natural, ramping up proportionally to your pedaling effort rather than delivering jarring bursts of assistance.
The voice command system proved to be a mixed bag during testing. Basic commands like “turn up the volume” or “turn off the headlight” worked about 50-60% of the time on the first attempt. When it didn’t catch my voice properly, I had to speak more clearly and deliberately, which somewhat defeated the hands-free convenience. When it worked, though, it was genuinely useful for keeping my attention on the road rather than fumbling with buttons.
GPS navigation provided a pleasant surprise during my testing route to a local bike shop. Not only did it calculate the correct path, but it intelligently routed me along dedicated bike paths rather than forcing me onto busy city streets – a thoughtful touch that shows Urtopia understands their target audience. The turn-by-turn directions appeared clearly on the display without overwhelming the interface.
One quirky detail I found was that every button press and menu selection triggers an audible confirmation sound by default. I found this annoying during quiet morning rides, but fortunately you can disable it through the app and rely on subtle haptic feedback instead. Even the bike’s bell is digital, playing various sounds you can customize through the app – everything from traditional bell chimes to a dog bark or what they amusingly call a “horse bark” in the menu. It’s the kind of playful feature that either delights or annoys, depending on your personality.
Range
Estimated Range (from Urtopia)
- Eco Mode (MIN PAS): Up To 80 miles
- MAX PAS: 26 miles
Urtopia’s 80-mile range claim comes with the important caveat that it’s achieved in Eco mode with a 180-pound rider under ideal conditions. Since I weigh about the same, I decided to put the Carbon 1 StepThrough through a more demanding test to see how it performs when you’re actually using all that available power.
Running the bike on its highest pedal assist setting for the entire ride, I managed 26 miles before the 352Wh battery called it quits. That’s actually a solid result when you consider the relatively small battery capacity and the fact that I was drawing maximum power throughout the test. The torque sensor deserves credit here – it’s constantly reading your pedaling effort and adjusting power delivery in real time, which helps squeeze more efficiency out of every watt-hour.
The lightweight carbon construction plays a bigger role in range than you might expect. At just 36 pounds, the motor doesn’t have to work as hard to move the bike, especially when accelerating from stops or climbing hills. This translates directly into better battery efficiency compared to heavier e-bikes with similar battery capacities.
In real-world riding, most people will land somewhere between my 26-mile blast and Urtopia’s 80-mile eco estimate. Mix in some moderate assist levels, throw in a bit of actual pedaling effort, and you’re looking at a practical range of 40-60 miles for typical riding. That’s more than enough for most daily commutes and weekend adventures, with the flexibility to dial up the power when you need it or stretch the range when you don’t.
Power (Motor & Battery)
The Carbon 1 StepThrough packs a custom-designed rear hub motor rated at 350W continuous with 750W peak power output. It delivers 45Nm of torque through the rear wheel, controlled by an intelligent torque sensor that reads your pedaling input and adjusts power delivery accordingly. The motor offers four distinct assist levels – Eco, Comfort, Sport, and Turbo – each customizable through the Urtopia smartphone app to match your riding preferences and terrain demands.
For a 36-pound step-through bike, this motor setup hits a sweet spot between performance and efficiency. The 350W nominal rating keeps things smooth while that 750W peak power provides enough punch for hills and quick acceleration when needed. The 45Nm torque figure might seem modest compared to mid-drive systems pushing 80-90Nm, but in a rear hub configuration on such a lightweight frame, it translates to responsive, smooth power delivery that doesn’t overwhelm the ride feel.
The torque sensor integration makes a noticeable difference – power feels natural and proportional to your effort rather than the abrupt on/off sensation you get with basic cadence sensors.
Power comes from a removable 352.8Wh Samsung lithium-ion battery that integrates cleanly into the down tube. The battery features UL certification for safety, charges completely in 2.5 hours with the included 4-amp charger, and includes waterproof design for all-weather riding. Urtopia’s battery management system works with the motor’s torque sensor to optimize power delivery and extend range through intelligent power distribution.
The 352.8Wh capacity is on the smaller side by current e-bike standards, but it makes sense for this bike’s intended use and design philosophy. A larger battery would add significant weight and bulk to what’s meant to be a lightweight, nimble urban commuter. For the Carbon 1 StepThrough’s target demographic – city commuters, casual riders, and those prioritizing easy handling over maximum range – this battery size provides adequate capacity without compromising the bike’s core strengths.
The quick 2.5-hour charge time is genuinely practical for daily use, and the removable design means you can bring it inside for charging or security. The real-world performance backs up the engineering choices – getting 26 miles on full blast or potentially upwards of 80 miles with moderate assistance is perfectly adequate for most step-through riders’ needs.
Components
The Carbon 1 StepThrough keeps things straightforward with a Shimano 8-speed rear derailleur system that covers the essential gear range for mixed urban and light trail riding. The wide gear ratios work in harmony with the motor’s four assist levels, allowing you to find the right combination of human and electric power for any terrain. Shift quality is reliable and predictable – exactly what you want when you’re focused on navigating traffic or enjoying a leisurely ride rather than fiddling with finicky components.
Stopping power comes from 160mm hydraulic disc brakes front and rear, featuring dual-piston calipers that provide strong, consistent braking performance. The brake levers offer reach adjustment to accommodate different hand sizes, and the hydraulic system delivers smooth modulation with plenty of power in reserve. For a bike this light with this level of performance, the braking system feels well-matched – strong enough to handle the bike’s 25mph top speed and potential cargo loads without feeling grabby or oversized.
The star of the show is Urtopia’s custom Smartbar – an aluminum alloy handlebar that integrates all the bike’s smart functions into one sleek package. At 720mm wide with adjustable height settings (0/15/30mm), it puts you in that comfortable upright position while housing the LED display, control buttons, GPS, 4G connectivity, and even a Bluetooth speaker. The swept-back design reduces strain on wrists and shoulders during longer rides.
Rolling on 700c wheels, the bike comes equipped with Kenda 700x40C gravel tires that strike a good balance for mixed-surface riding, and the Carbon 1 has clearance for up to a 45c tire. The tire choice makes sense for the bike’s intended versatility – wide enough for comfort and light gravel duty, but not so knobby that they create unnecessary rolling resistance on pavement. The frame can accommodate up to 45mm wide tires if you want to push further into gravel territory.
For a step-through e-bike at this price point, the component selection shows thoughtful curation rather than premium overkill. Everything works together cohesively without any obvious weak links, and the choices support the bike’s core mission of being an accessible, reliable urban transport tool with light adventure capability.
Screen / User Interface / App
The brains behind the Urtopia Carbon 1 start at the cockpit where you’ll find the centrally mounted “Smartbar System” sporting a large LED dot-matrix display that, while having a retro-cool vibe, works surprisingly better than most displays out there these days. The display data is all front and center as you’d expect – the usual basic suspects like speed, battery level, PAS level, and headlight indicators. But beyond the basics, that’s where the Urtopia Carbon 1 starts to flex its tech muscles.
We’re talking ride-contextualized data like turn-by-turn navigation arrows in real time when using the bike’s navigation, voice control features for hands-free rides to play your favorite tracks through the built-in Bluetooth speaker, and other small data perks like calories burned along with power and cadence numbers from your ride. Going a step further, the Urtopia Carbon 1 is equipped with a 4G eSIM card that lets the bike communicate with the bike’s AI-focused integration to ChatGPT. Yes, you read that right – this bike talks to ChatGPT to improve your rides.
Need a more optimized route to your destination? Want to hear your favorite playlist through the bike’s built-in Bluetooth speakers? Maybe you want to adjust speeds or simply lock the bike at your destination? All of these are as easy as they sound, thanks to the bike’s ability to receive your voice commands via natural language phrases like “lock my bike” or “play my e-bike playlist.”
The system’s ability to provide “logical riding advice” proves genuinely helpful for optimizing performance. Ask about the most efficient assist level for your current terrain, and it considers factors like your cadence, remaining battery, and route profile to make intelligent recommendations. It’s not just executing preset responses – there’s actual reasoning happening behind the scenes.
That said, voice recognition does have its limitations. Wind noise above 15mph can interfere with command recognition, and complex multi-part instructions sometimes require repetition. The system works best for quick, specific commands rather than extended conversations, though the AI’s responses are impressively natural when conditions allow clear communication.
Is The Urtopia Carbon 1 ST Worth Buying?
The word ‘smart’ gets thrown around with every product these days, but most of the time when you actually use them, they don’t feel that smart at all. The Urtopia Carbon 1 is different – the ‘smart’ factor goes way beyond just slapping ChatGPT on a bike and calling it a day.
It starts with being smart about weight. At 36 pounds, this carbon fiber bike is genius for anyone who’s tired of wrestling with 80-pound e-bike beasts that need their own special ecosystem of heavy-duty racks and accessories. Then there’s the route planning that actually helps with your specific situation – factoring in traffic, your remaining battery, and giving you optimized routes with real-time data that actually matter.
The 4G tech creates geofencing barriers around your bike that’ll sound alarms if it moves without permission. If bike theft is a concern in your area, that starts feeling pretty smart real quick. Voice commands handle the simple stuff like playing your favorite playlist without forcing you to fumble with your phone while riding – the built-in Bluetooth speaker means no headphones required and your hands stay on the bars.
All these features feel genuinely smart beyond the marketing hype. It’s not just smart, it’s practical everyday smart that goes beyond gimmicky AI tech. These are features that help you get more done in a day while staying a little safer doing it.
But, even beyond the hoopla of ‘smart’ anything, the Urtopia Carbon 1 is excellent at the basics, being a bike. Getting you from point a to point b on the Carbon 1 is smooth, quiet and surprisingly capable. That 750W motor and torque sensor combo feels natural and responsive – it amplifies your pedaling rather than fighting it. Getting 26 miles on full blast is solid for the battery size, and if you dial it back, that 80-mile range becomes totally realistic.
Bottomline, if you want an e-bike that feels like it was designed in 2025 instead of 2015, this is it. It’s perfect for commuting, weekend rides, and anyone who wants their bike to be as smart as their phone. Just don’t expect it to haul lumber or tackle mountain bike trails – that’s not what this is for.
Pros
- Weighing in at just 36 lbs, the Urtopia Carbon 1 ST is a surprisingly lightweight commuter
- Smart features like 4G connectivity, geofencing radius alarms, route planning and voice commands make this bike stand out.
- One size frames fit a wide range from 5’ 1” to 6’ 1”
- ‘Game Mode’ is a first for me on e-bikes, but I must admit, it was kind of fun to play a video game on the bike’s display when I got bored waiting around.
- The included bluetooth speaker and voice commands make for safer, easier rides that just so happen to play the music you love, on Demand.
Cons
- $9 a month for the ChatGPT subscription can add up quickly, that’s nearly $120 a year for the extra smart features.
- No throttle on this one, leaving your legs and the torque sensor to do the heavy lifting when its time to get moving.
Reader Interactions
