The Haibike SDURO HardSeven SM is the most affordable model in the extensive Haibike lineup… and I’m going to help you understand why. While it still looks awesome thanks to an exciting paint scheme with matching fork, grips and saddle and the frame itself – still hydroformed with gravity cast mounting interface – is great, the components have been downgraded… pretty much across the board. The one exception might be the hydraulic disc brakes with 180 mm rotors, I’m glad they kept these vs. going mechanical because they perform much better on trail or mountain terrain and given the 30 to 60 mile range of this thing, you don’t want your hands to get tired.
Okay, so let’s list off the differences between this model and the more expensive SL and RC which are $300 and $700 more than the SM (which costs $2,499). Both of these models deliver a removable, backlit LCD display panel with tons of extra readouts (odometer, max speed, time, clock etc.) and an extra drive mode called Eco+. Additionally, you get a Micro USB port for charging lights and other portable electronics that’s located on the remote button pad. Moving on to comfort and portability… instead of a heavy oil-filled suspension fork on the SM you get an air fork with remote lockout and rebound adjust. The SM does have preload adjustment but it’s pretty basic and the lockout uses a crown-mounted plastic swivel (all forks offer 100 mm travel). While the SL and RC offer Schwalbe tires with puncture protection and precision mount Presta valves the SM has generic Kendas with old-fashioned Schrader stems. The saddle is more basic and doesn’t include a clip at the rear for adding a bag or lights and you only get nine speeds and a cheap SRAM X-4 derailleur (one step up from their lowest level offering) vs. 10 Shimano Deore or 20 Shimano SLX respectively (both solid mid-range components). The color scheme is also toned down with white accents on a flat gray background vs. blue and yellow accents on gray and white for the higher two models.
So are all of these trade-offs worth it?! Yes, definitely if you’re already stretching your budget from $2k just to get into a Haibike. I really enjoyed the simplicity of the LED console and didn’t mind the extra few pound on the suspension fork. The motor and battery used here are exactly the same as what you’d get on the SL and RC… and the missing “Eco+” drive mode isn’t something I used much while testing. If you can afford the $300 upgrade to SL I think that’s the best value because the nicer tires won’t get punctures as frequently and the air fork rides better. But hey, you can always swap forks out later (they might not match perfectly) and the tires are going to get replaced eventually anyway. I love that all of these models offer quick release wheelsets and am in love with the purpose-built frames, internal wire routing and tuff plastic skid plate protecting the motor. For riding to work or around the college campus the HardSeven is a real winner!
I touched on this a bit in the review but let’s dig into the motor a bit here. It’s mounted low and center, well protected and uses speed, cadence and torque to operate quickly and efficiently but the motor speed itself seems more limited than the Bosch systems. I simply prefer their technology over Yamaha at this stage. Bosch offers shift sensing which will reduce wear on your chain, sprockets and derailleur but for an urban rider that’s not a huge deal, just don’t mash the gears… ease off when shifting. I found myself pushing harder to maintain a 20 mph average speed and was almost always pedaling in the highest two gears because torque is the key ingredient in activating pedal assist with this ebike. My one ask to Yamaha would be to make their motor spin faster at times so I could shift down to lower gears and still hit 20 mph. All things considered, this is a winning electric bike and one that I’d feel comfortable locking up outside and seeing get banged up and worn out because it’s just more plain and less expensive. The first thing I’d add would be a beam rack and pannier blockers for use with bags so I wouldn’t have to constantly wear my backpack and yes… a bottle cage mounting point somewhere on the frame would be nice but I see that most of the downtube is taken up by the battery pack. It’s all about trade offs but I can appreciate the ones made to hit this lower price point and aside from some clicking heard in the review (from the chain guide) it operated quietly and eased my concerns about longevity given the two year comprehensive warranty and excellent dealer support.
Pros:
- Haibike is touting their Yamaha powered electric bikes as offering “uncompromising performance” geared for a younger demographic, zero cadence assist is meant to be more immediate (verses the Bosch Centerdrive which requires 20 rpm for the motor to kick in), in my experience both systems start extremely quickly and Yamaha’s primary advantage is that it costs less and is compatible with two chainrings vs. just one for a wider gear range 455% vs. 420%
- Even though this model uses the more basic LED console from Yamah, I like how it performed… the readout was visible and all of the most important menus were there (assist level, battery percentage, speed, range estimate)
- The Yamaha motor operates without producing much noise when pedaling at slow and medium cadence speeds (especially in Low and Normal mode), you hear it more when pedaling in lower gears in High mode
- You can charge the battery pack on or off the frame and since it slides on from the side vs. straight down like Bosch and other brands, it allows the top tube of the frame to drop lower for a decreased stand over height
- I like how easy it was to open and close the rubber cover that protects the charging port on the left side of the battery, on some ebikes this type of cover is difficult to seat and comes undone easily which could allow water/debris in
- Professional color scheme, the matte gray with white accents looks cool and even the saddle, grips and fork are color matched
- Decent suspension fork upgrades, you get preload adjust and a slider lockout… because this is an oil-based shock vs. air it weighs more and rattled a bit when riding during my tests
- Excellent weight distribution, the motor and battery are positioned low and center improving handling, both wheels have quick release for easier transport or trail maintenance and the motor is well protected with a replaceable plastic skid plate
- Available in five distinct frame sizes! This makes it much more accessible to short and tall bodied riders, improving comfort and making it easier to ride for long periods of time
Cons:
- The Yamaha motor seems to have a limited range of speeds compared to Bosch, in practice this meant that as I shifted down going into climbs my assisted-speed would drop, only the highest two gears would reach ~20 mph assisted and I had to strain my legs and knees more when climbing with mid-level gears or relent and drop all the way down to the lowest gears which reduces speed
- No shift sensing or shift detection built into the drive system, this could lead to more mashing, banging and premature wear on the chain, cassette and derailleur
- No bottle cage bosses on the frame though it appears that you could add fenders or at least mud guards and possibly a rear carry rack… definitely a rear beam rack like this and consider pannier blockers
- More generic parts here including Kenda tires with Schrader Valves vs. Schwalbe with puncture protection and Presta Valves on the higher level models, the saddle is no-name and the derailleur is lower level SRAM X-4, you also get one fewer levels of assist (just Eco, Standard and Power vs. Eco+ with the LCD display unit), the display panel is not removable and there’s no USB charging port
Resources:
- Official Site: http://www.haibike.de/microsites/sduro/us/#
- More Pictures: https://goo.gl/photos/Lvqus2MHgvVhpwXHA
steve pettyjohn says
Hey Court, Great review – as usual! Looking forward to your review of the new Haibikes with the new Bosch CX motor. I ordered one 5 weeks ago and no word yet if it has even left Germany. Can’t wait.
Thao says
Hey I love your reviews. But I am a little confused on your comments about the power range of the Yamaha system. If you are in the lowest gears for going up hill, i’m assuming the motor will only assist you as fast as you can pedal, which the mph shouldn’t be very fast considering you are in climbing gears. So my questions is how are the Bosch motors able to assist beyond the pedaling speed at low gears. That would almost make it like a full throttle since your pedaling at low gears isn’t fast enough to keep up with the speed. So even though you are pedaling but not putting any power into it because it’s beyond the speed of pedaling power, how would the Bosch motor propel you to above the pedaling speed. To me that would seem like a full throttle bike. Without the throttle of course. Or am I misunderstanding your comment? Because if I’m pedaling at the lowest gears, let say I can only reach 5-6 mph, and that’s the fastest I can pedal cause of the gearing. Now on the bosche motor, would it propel me above that, like a full throttle? If so, that would mean it’s all motor that pushing me since the gears wouldn’t allow me to pedal that fast. Is that what you mean by the power range? Thanks
Court Rye says
Hi Thao! I’m sorry I wasn’t more clear… I felt frustrated with my dialog when editing because I feared the comment would come off just like you described, that cadence is the limiter and not the motor. I’ll try to distill the feeling: as pedal RPM goes up the motor power drops significantly compared to Bosch so even though both systems might have a limited top RPM, I feel that Bosch is higher and that the power you get is more consistent across that range. For Yamaha it feels as though the best power is only at lower cadence and relies more on torque input so I end up pedaling slower and pushing harder than I’d like. This comes into play when climbing especially because as I shift down to spin and generate more power the motor RPM kicks up and its power drops out so in turn my cadence slows… and again I shift down… eventually I’m just going way slower than I’d like in order to get the motor support I need to get myself and the 50 lb bike up a trail :/
Pierre M Tremblay says
Court EBR Hi, Being retired, I always enjoyed riding bikes. However, things like WIND and HILLS were becoming more and more a good excuse for NOT GO Biking… Being completely “unfamiliar” with electric bikes, I went to a bike shop and started to watch your very informative reviews. I now have a Haibike SDuro Cross SL customized with rack, etc. and must say that it gave me back the pleasure of bike riding. I want to express my appreciation for all the very pertinent information which you provide.
Pierre M
Court Rye says
That’s awesome! Thank you so much for taking the time to share a compliment Pierre, and good for you getting out there and enjoying cycling again! Have a blast and ride safe :D
