To run the forums, host the website, and travel, I charge a universal service fee for my reviews. This in-depth review was sponsored by AddMotoR. My goal is to be transparent and unbiased with you, this video and writeup are not meant to be an endorsement of AddMotoR products. I welcome your corrections, additions, and feedback in the comments below and the AddMotoR electric bike forums.
Pros:
- Available in two frame colors with a one-year comprehensive warranty, and you get the option of buying directly from AddMotoR or visiting one of their dealers to test ride before purchasing
- The M-66 R7 is a fun and exciting bike to ride with a distinct moped feel, the Bafang motor is powerful and responsive, and the fat tires can tackle any terrain. I appreciate that AddMotoR configures this Ebike to have full-throttle power available from any assist level, this is useful (and fun) if you are cruising slowly in a low assist level and suddenly need or want to accelerate
- The motor is integrated inside the rear wheel which helps to reduce volume, and it really is quiet – I found I could hear the tires on the pavement more easily than I could hear the motor! It is rated for 750 watts which is the maximum in California, with a hefty 80 newton-meters of torque, and you can definitely feel the power as soon as you twist the throttle
- The 20″ wheels are cast alloy which makes them very sturdy, not to mention never needing any spoke adjustments! The 20″ size also lends a mechanical advantage to both the brakes and the motor, making for easier stopping as well as faster acceleration
- Good quality Panasonic cells in the 48 volts 11.6 amp-hour battery, which means a total capacity of 556 watt-hours. This provides good range that I estimate at 25-50 miles depending on terrain and assist level, and the battery mounting position under the seat helps to protect it from moisture if you get caught out in the rain
- Nice bright lights are included on the front and rear, the Trendo by Spanninga headlight is integrated and draws power from the main battery and is operated from the main display. The rear light isn’t integrated which is less convenient, but it’s highly visible and I’m glad it is included
- I love the Promax stem, it can be adjusted across a huge range in just a few seconds thanks to the tool-free design, just lift the clamp, reposition, and clamp it back down! This is a huge plus since you may want to adjust the handlebar positioning if you’re carrying a passenger (more on that ability later), or if you share this bike among differently-sized riders
- The M-66 R7 ships as a Class 2 electric bike which means throttle or pedal-assist with a top speed of 20mph. However, the motor is more than powerful enough to handle Class 3 speeds of 28mph, and this can be configured in the settings – just make sure this is legal in your area first, and check with AddMotoR for help with the display settings since they can be a bit cryptic
- I didn’t find myself pedaling and shifting gears a great deal, but when I did the experience was smooth and comfortable. The Shimano Altus derailleur is a bit higher tier than Shimano’s entry-level Tourney, the thumb shifters are easy to interact with even if you’re wearing heavy gloves, and I appreciate the guards on both ends: an alloy derailleur guard to protect against impacts and tip-over damage, and an alloy bash guard to protect the chain as well as prevent it from bouncing off
- The ride comfort is excellent! The banana-style seat is soft and large so you can slide back and forth on it to find a comfortable seating position, you can use the tool-free adjustment clamp to position the handlebars wherever you want, and the suspension fork + the fat tires do a great job of smoothing out bumps. The Addshox suspension fork has 80mm of travel and is adjustable for compression and preload, I’m a big fan of the triple-clamp design for sturdiness as well as aesthetics
- Kenda Krusade Sport tires have great traction and performance, you can drop them down as low as 5 PSI to tackle snow, sand, and other soft terrain
- Included front and rear fenders constructed from aluminum alloy, which keeps them lightweight and durable as well as resisting the dings and rust that can accumulate on steel fenders
- I think AddMotoR did a great job with their control cable management, wrapping up cables in a heavy-duty plastic shield to keep them consolidated and providing plenty of cable length up front so that the cables never restrict how you can adjust the stem and handlebars. Cabling on the rest of the bike is either internally routed or hidden well
- The brakes here do a great job, they are Tektro Aries mechanical disc brakes with 180mm rotors, and they’re fairly easy to actuate thanks to the combined mechanical advantages of 4-finger brake levers and the smaller 20″ wheels. Motor inhibitors are included and cut power to the motor as soon as you squeeze either lever, a good and necessary feature on such a heavy cadence-sensor-based Ebike
- AddMotoR has added some new comfort features that were not on previous versions of this bike, the first of which is a plastic footrest on the downtube, allowing you to rest your feet there instead of leaving them on the pedals if you are riding on just the throttle. The second feature is rear footpegs that fold down so that you can carry a passenger! With a weight limit of 350 pounds you can pretty easily fit two people on the large banana seat, but as the “driver” you have to scoot pretty far forward which can make pedaling difficult, so you’ll certainly appreciate that front footrest when riding double
- The twist throttle includes a kill switch toggle, definitely appreciated on such a powerful Ebike, make sure you use it to disable the motor when moving the bike around in the garage or at a bike rack
- The display includes a USB type-A port on the bottom, great for charging mobile devices on the go! Unfortunately, it only provides power at 0.5 amps, which means it can charge Android devices but not Apple
- You can charge the battery on the bike or off, and when on the bike the charge port is located up high and well out of reach of the crank arms, which prevents accidental damage if the bike gets moved around while charging. Similarly, the kickstand is rear-mounted and out of the way of the cranks, so you can easily maneuver the bike with the kickstand down without it getting locked against the cranks
Cons:
- Only available in one frame size, the large banana seat and adjustable stem means it can accommodate a wide range of riders, but tall people (like me) will still find pedaling uncomfortable. On the other end of the spectrum, small riders will be able to sit comfortably but may struggle with the size and weight of the bike
- The M-66 R7 is one heavy Ebike at 74 pounds, there are a lot of heavy components here including the cast alloy wheels, big banana seat, and of course that hefty 750-watt motor. This weight makes it a difficult Ebike to maneuver in tight spaces, and if you ever run out of battery power when you’re away from home… be prepared for a workout pedaling back! Of course, the positive trade-off here is that the M-66 R7 is very sturdy and feels powerful and stable, even at high speeds on rough terrain
- The frame geometry makes for an awkward and uncomfortable pedaling experience, particularly for us long-legged humans. I’m 6’3″ tall, and I could get a comfortable seating position by scooting all the way back on the seat, but still wasn’t able to get close to full leg extensions on the pedals. It was adequate when riding with pedal assist, but pedaling without assistance became unpleasant fairly quickly
- The gearing range of 14-28 teeth is pretty limited which also affects pedaling comfort, making it harder to start when you are completely stopped, and limiting how fast you can get going on the high end. Of course, the powerful motor and on-demand throttle effectively negates both of these issues… as long as you have battery capacity remaining! You’re probably sensing a trend here, which is “don’t run out of battery far away from home!”
- The tires don’t include any puncture protection which is always a bummer to me, but I do live in an area with a lot of natural puncture hazards. Fortunately, you can add puncture protection fairly cheaply, although if you opt for adding liners that can be a bit of a pain on the rear tire thanks to the integrated motor
- I’m glad that fenders are included and they do a great job of protecting the bike itself, but only a moderate job of protecting the rider. I would love to see both of them be just a bit longer to provide some extra coverage
- The rear light is not integrated which means that you must remember to turn it on and off manually, and change out the AA batteries periodically… but hey, it’s still better than no rear light!
- Mechanical brakes require more frequent maintenance compared to hydraulic, which mostly means regularly tightening them as the cables stretch over time. There is also a bit of a delay when braking particularly for the rear wheel, and they require more grip strength to actuate. This grip strength factor is mostly mitigated on the M-66 R7 thanks to the large four-finger levers and smaller 20″ wheels which provide a mechanical advantage
- The cadence sensor is high resolution with 12 magnets, but it is unsealed, which leaves it vulnerable to damage and magnets getting knocked out. If you start to notice any strange behavior from pedal assistance, check your cadence sensor first!
- I mentioned how much I love the Promax stem, just keep in mind that these tool-free stems do tend to loosen a bit over time so check and tighten it with the appropriate tools every few months
John says
how big of a rider will this bike handle
Tyson Roehrkasse says
The official weight limit is 350 pounds. I was able to sit comfortably on it and I’m pretty tall at 6’3″. Sitting was great, but pedaling was pretty difficult – definitely easier to ride like a moped if you are tall!
John says
I weigh 280 lbs I’m 5’10” I should be ok then. Its a large battery and can purchase another one.
John says
There is a larger battery and what would be the largest.
AddMotoR sells spare batteries but I don’t think that they have any that are higher capacity, but the one the M-66 R7 comes with is pretty high capacity so you would probably be fine with it. If you have to ride a long ways you could always carry a spare battery, you can check those out here: https://www.addmotor.com/c/electric-bike-battery_0364
shaine pendergraft says
im about 6foot and one inches could this bike be good for me ?
It would be a pretty good fit, the seating would be comfortable especially if you ride it more like a moped. Pedaling wouldn’t be as comfortable as you probably wouldn’t get full leg extensions, but if you’re planning to use the battery most of the time it would be great!
tmh says
Thank you Tyson for doing some very thorough reviews, which are both informative and enjoyable to watch. You are definitely an asset to the EBR review team. I appreciate your perspectives as a taller rider.
Watching this review makes me more excited about receiving the Juiced HyperScorpion I have pre-ordered for my wife, although now it looks like delivery on those won’t be at least until June.
Thank you! Happy to do it, I’m having a blast :) Juiced HyperScorpion looks awesome too! We’re hoping to get our hands on some of their bikes soon.
Andrew Busch says
If it went faster, I would buy it.
Court says
Fair enough! Thanks for the comment, Andrew :)
peter nichols says
Hold On!! I have been very pleased with this bike until I have had to deal with addmotor support. I have had the M66 R7 for a little over a year before I needed support. The kick stand just froze and refused to function. I contacted addmotor and they said that would be $35 for a new kickstand. I disassembled the kickstand and found out that the problem was a plastic part had broken. This small plastic part is about the size of my thumb nail. I contacted addmotor support looking for the part and was told to contact sales at addmotor. Neither has been any help and [email protected] never responded. Makes me dread to think of some serious trouble. A bit of irony is that the kickstand that addmotor parts wants $35 for is available on Amazon for $13. So much for customer after sales SUPPORT.
Court says
Hmm, that’s kind of frustrating. Good job figuring out the problem and trying to avoid waste by fixing the little plastic piece vs. the entire stand. I realize that’s not always an option, glad you found one on Amazon for less…
derbusa says
Decided to repair the failed part with metal innards like it should have been from the factory. Addmotor is not being helpful in my efforts to find out who designed and manufactured the part. I get the distinct impression that after the one year warranty that you are on your own and they won’t help.
Court says
Hmm, that’s a bummer. It sounds like you’re pretty handy. Great job developing a solution… I hope it lasts for you :)
