EBR charges a service fee to manufacturers to produce ebike reviews and videos, this began in 2018. It’s the same flat fee for each bike, and it helps us to keep the site going while limiting ad clutter. We appreciate the opportunity to serve you with our opinions and data but respect your right to know that we receive compensation :)
The E-Stream EVO AM 4 is a category leader in the Bulls ebike lineup. For all mountain riding, it offers longer 150 mm (~6 inch) suspension front and rear. Both air shocks offer pressure, rebound, and compression adjust to optimize performance for different rider weights and terrain; climbing or descending. As with many of the higher-end Bulls products, the E-Stream EVO comes in three sizes for optimal fit. As a medium sized, lighter weight rider myself (weighing ~135 lbs), I appreciate that the suspension can be sagged and mounting/dismounting is easier because of the seat post dropper and angled top tube. The Kind Shock Lev-Integra dropper post can be set at any height vs. 10 step increments, and it comes in handy when transitioning from climbs to descents. This electric mountain bike looks beautiful, you can hardly tell it has a motor because the Brose S mid-drive is so compact and quiet. The battery pack seats up into the downtube vs. being bolted onto the top, and most of the electrical wires, shifter cables, and brake lines are internally routed. Furthermore, the frame is painted dark grey with black accents, and this allows the black accessories, such as the display panel, to blend in. It’s one of my favorite e-mountain bike models to date, because it offers such efficient and responsive riding, allows you to go further with a high-capacity battery, and spares no expense on brakes, drivetrain, accessory options, grips, or tires. Yes, it costs a bit more than your average all mountain model, but the price is not excessive for what you get. Bulls is a German brand with global distribution, backed by a network of dealers in Europe which launched it as an “in house” brand. I have been reviewing their e-bikes since 2016, heard great things from dealers and customers, and always received quick support and follow up from their leadership team, which are based in Southern California. There are a few trade-offs and things to get used to with this bike, namely the compact Marquardt display panel, that I’ll get into later.
Driving this bike is one of my favorite new mid-drive motors, the Brose S. I have always appreciated how compact, lightweight, and quiet the Brose drive systems are, and apparently the S (for Sport) is 1.25% more efficient, to help extend range, while also being 15% more powerful! So what’s the catch? Perhaps it weighs slightly more than the original Brose T, but at ~6.61 lbs it is still quite a bit lighter than the competing Bosch Performance Line CX. I think the other trade-off from the Brose T is that it produces more noise. Inside all of the Brose mid-drives is a Gates carbon belt drive that reduces vibration between your cranks, the spindle, and the internal gearing. It’s quiet and very smooth, there’s less of a vibration feel, but it is still extremely powerful, offering up to 90 Newton meters of peak torque. Unlike a lot of competing systems, the Brose motor controller seems to rely heavily on pedal torque vs. cadence or any set level of pedal assist. I demoed this a bit in the video review above, but the short explanation is that you can be riding in the highest level of assist but still be riding slowly without the motor kicking on much at all… if you aren’t pushing very hard. It feels very natural and support is there almost instantly when you do exert pressure. One feature this motor controller does not offer is shift detection, but the power cuts out very quickly as you reduce pedal torque, so it’s best to ease back when shifting in order to reduce mashing (chain, sprocket, and derailleur stress and wear). You and the motor have access to an 11-speed drivetrain for climbing and descending. As you shift through the gears, you and the motor get an efficiency benefit… and the motor will support zero to ~20 miles per hour with 120+ pedal rotations per minute. This means that you can spin quickly verses having to shift to a higher gear in order to reach higher speeds. Some of the older motors, and even some of the newer Yamaha and Shimano motors don’t seem as capable at higher RPM’s and it’s something I personally care about, because I have a sensitive knee. I’d much rather spin at higher speeds with less pressure than lumber along, or have to shift gears frequently as terrain changes. The chainring is a standard 38 tooth, which could be swapped out easily, and the cassette offers 11 to 42 tooth sprockets. I was able to climb terrain so steep that the rear wheel began losing traction and then descend at upwards of 35 miles per hour comfortably. The derailleur is Shimano Deore XT with Shadow Plus, and that means it’s mounted below the right chain stay and tucked in while also having a one-way clutch to increase resistance and pressure that negates chain slap and drops. The standard chainring helps to elevate the chain to reduce chain slap anyway (compared to the smaller proprietary sprockets that Bosch uses), and it might not suffer from chain suck as much on the bottom because there’s extra space next to the motor casing. Mud and grassy debris should be cleared by the E-Thirteen TRS+ full-surround chain guide, which virtually eliminates drops and might also clear your pant leg (if you’re riding with loose pants for some reason). On that note, the left chain stay does have provisions for adding a kickstand if you so wish, perhaps for weekday use – riding around town.
Many of the Brose powered electric bikes from Bulls have higher-than-average battery capacities, and this is a highlight for me because they don’t actually weight that much more. Looking at 7.1 lbs for a 647.5 watt hour pack is impressive when you compare the 500 watt hour Bosch Powerpack at 5.8 lbs or their heavier Powertube at ~6.15 lbs. You’re getting 30% more capacity for a 22% increase in weight… and that’s comparing to the lighter Powerpack. You can do a lot with 150 extra watt hours, especially on an efficient mid-drive setup. The battery pack is not perfect however, seating up into the downtube vs. down from the top. It might just be the demo model I tested out, but the pack sort of flopped out when unlocked vs. having a two-step button like the Bosch Powertube. The pack is contained in plastic vs. tougher aluminum alloy but does have a thick rubber guard all the way along the bottom. I was told by Bulls that the pack itself is similar to 2017 models (which had a foam sticker vs. integrated rubber) and that the packs could be interchangeable, but might not look great. This is one area where Bosch has a lead, all of their packs have remained the same and are easier to find and swap out on-location. It can be difficult to fly with high capacity Lithium-ion batteries, and being able to rent or borrow on location is great if you want to bring your own personal bike. The charge port on this battery is fancier, and interfaces with a high-speed 5 amp charger for quicker fills… but I have read that this can stress the cells more than slower 2 or 4 amp charging. You can protect your packs from premature wear by storing them in cool, dry locations vs. extreme heat and cold. And, you don’t have to remove the pack from the bike at all to charge it, if you prefer. This could reduce the potential for accidental drops, because of the flop-out unlock situation and limited grip and handle design, the pack can be surprisingly heavy when the weight is instantly transferred into your hand or you’re even pulling it down from the downtube (working with gravity). Remember, by default there is no kickstand, so you might also be balancing the bike. It could be best to lay the bike onto its left side when working with the battery… just be careful with the larger 203 mm disc brake rotors, don’t touch them because the oil from your fingers can wreck the pads over time. A final not about the battery pack and charging interface is that it’s magnetic, and iron filings and other debris can stick to the end of the plug, just brush it off occasionally to ensure a good contact for charging.
Another exciting but mixed feature of the new Brose system featured on this ebike, is the compact Marquardt display panel. It’s compact, which allows it to blend in and possibly avoid damage if the bike is dropped or crashed. It offers lots of menus and settings (way more than the comparably sized Bosch Purion), but has an additional joystick button thing that could get worn out quicker. And, I’m told that it offers active Micro-USB charging through a port on the right side. This could be a huge win if you like to listen to music or use your phone for GPS navigation (as we did for the longer adventure ride in the video above). The actual LCD display is much smaller than the Purion and could be difficult to read at times, though it is brighter in terms of backlighting. I found that the location of the Marquardt on this particular ebike was difficult to reach because of the seat post dropper lever. I had to reach over and around the dropper lever, then across the brake lever mount. If I were setting the bike up, I might angle the dropper lever down or up more to create space. It might even be possible to mount on the right side, between the brake lever and trigger shifters. There’s a lot of room for experimentation here, and I want to call out the two-finger Magura brake levers, which have adjustable reach and can be spaced out to use with just one finger, if you prefer. Overall, the cockpit is clean and simple, I love the locking Ergon grips and appreciate the slightly raised handlebar and short stem for comfortable downhill riding. I guess, coming back to the display, there was some confusion about how to change units, and I was told that Bulls is releasing a Bluetooth app at some point. I wish I could say more about that now, but perhaps you can chime in with comments below if you have seen and used it. Apparently, it will also connect to a Bluetooth heart rate monitor? Though, many of the monitors I see have used from Garmin use Ant+ vs. Bluetooth. I wish that the Marquardt showed a greater number of batter bars or even a battery percentage vs. just for bars, and the range estimate menu seemed static vs. dynamic as we used the up and down keys to select more or less power. This is one area where the Bosch displays are really nice. Overall, if you have ridden a Bosch CX powered ebike and used the newer eMTB drive mode, I would say that it feels a lot like all of the Brose S drive modes. It’s just fluid and responsive, not too much work, but not as zippy and on/off as many of the other systems. It’s one of my favorites and one of the most natural. Using the joystick to navigate through menus, even having to be in the assist menu before the up and down keys worked, was sort of frustrating. I didn’t realize that you could use the joystick to go up and down in some areas until after a lot of riding. It’s amazing that they packed so much into this display, and I appreciate the dedicated light button (if you add lights to the magnetic MonkeyLink interface on the stem and seat post clamp). There’s also a walk mode if you hold the up arrow while already in one of the three or four assist levels. It went pretty slow at first, until I shifted gears up… but you’re probably always going to be starting in a lower gear when getting off to walk (assuming you couldn’t balance on a climb) so I wish it was faster and measured wheel speed vs. having a set rate. Think about the moment you finish walking and then hop back onto the bike… with the gear set high so walk mode would be faster, now you have to mash gears to shift low to pedal, it’s frustrating :/
Thankfully, there aren’t that many truly frustrating things about the BULLS E-Stream EVO AM 4 and the Brose S setup. Nor should there be for such a price, right? I had a blast riding this model, loved how blacked-out it looked with the muted color scheme and even the anodized black stanchions on both RockShox shocks. If you’re not interested in answering questions from fellow cyclists, this ebike is one of the stealthiest around (in terms of looks and noise) and the wider hubs and plus sized tires make it a blast to descend with, there’s very little deflection, weight is positioned well on the frame and it handles well. I love that there was room to squeeze in a bottle cage mount at the downtube, and that there’s a fancy magnetic MonkeyLink option there for easily reaching and re-attaching fluids as you ride. If price were no object, this would definitely be on my shortlist of leading electric mountain bikes. There’s a bit less trust of the Brose motor in my mind because I have seen Bosch for so much longer, but I do trust Bulls and it’s nice to know that this new Brose S model is a refinement of the earlier T that has worked so well. Bulls improved some of the rubber covers around the charging port and key hole from 2017, but it’s still not as seamless as some other companies. Weighing in at ~55 lbs, the bike is heavier than a hardtail but the larger 203 mm hydraulic disc brakes always felt good, even on longer descents for this ride. I felt secure with the tires, brakes, and weight, and it just felt good. Big thanks to the Bulls team for partnering with me on this post and providing a couple of bikes to compare back to back, it was awesome to see the Powertube and Purion from Bosch next to the Brose Marquardt and proprietary Bulls battery integration. As always, I’ll do my best to answer questions below and you can get other opinions directly in the Bulls Ebike Forums.
Pros:
- The Brose S (Sport) motor has become one of my favorite ebike mid-drive systems (right up there with the Bosch CX), it’s 15% more powerful and 1.25% more efficient than the Brose T while remaining compact, quiet, and relatively lightweight at 6.61 lbs
- Because the Brose mid-motor uses a traditionally sized chainrings (38 tooth in this case), it doesn’t require a reduction gear, won’t suffer from chain suck or chain slap as much, and can be swapped out with other chainrings more easily
- You should get excellent range on this bike, because the motor allows you to leverage 11 gears to climb easily and the battery capacity is way above average with 37 volts 17.5 amp hours for ~647.5 watt hours total
- This e-bike looks amazing because the motor is so compact and built into the frame, the battery actually seats up and into the downtube, and the frame color is dark grey and black – which blends everything together (including wires, which are internally routed across most of the frame)
- Most of the ebike chargers I see are 2 amps or 4 amps, but this one uses a 5 amp charger from BMZ, it plugs into the battery with a magnetic EnergyBus connector that will simply pop out if tripped over, I love how you can charge the pack on or off the bike and am happy that the battery is higher capacity because bringing the charger along would be less fun since it’s bulkier and weighs ~2.6 lbs vs. just 1.5 or ~2 lbs on most other chargers
- Relatively lightweight for an all mountain electric bike with longer travel 150 mm ~6″ suspension, thicker stanchions, sturdier joints, and a high capacity battery pack, it weighs ~55 lbs total and could be reduced slightly by running the tires tubeless (they are tubeless ready)
- Available in three frame sizes so you can improve fit, the air suspension is more highly adjustable than spring, you can sag it to match your body weight or ride style and both shocks are anodized with Titanium Nitrade coating to make the stanchions harder and slicker
- Boost hub spacing widens the spoke position and improves the bracing angle to support larger plus sized tires, both the front and rear axles are thru-axles for increased stiffness and strength on rough terrain and the front offers quick release for easier trail maintenance and transport
- Massive 203 mm hydraulic disc brakes with quad-piston calipers from Magura offer efficient cooling and more powerful, controlled, stops. You can adjust the reach on each two-finger brake lever and even use them with one finger if that’s your preferred hand position
- I love that Bulls managed to squeeze in a bottle cage mounting point on the downtube, and they partnered with MonkeyLink so you can use a magnetic bottle adapter here for easier stowing vs. a cage
- It’s neat to see innovation in the lighting and fenders space, the new MonkeyLink mounts at the stem and seat post collar allow for a range of accessories that will run off the main ebike battery! my only complaint is that the headlight I saw was not aimable and thus, depends on the head tube and stem angle for direction
- The Brose powered E-Stream bikes seemed to have a lower stand over height and shorter overall length than the Bosch powered models, I think the chain stays are shorter here because of how the motor is designed, which makes for a nimble snappy ride
- To me, the rear suspension design looks a lot like split pivot, it’s designed to isolate chain movement (reducing kickback) by providing vertical play vs. horizontal and this allows for effective braking but may suffer from bob when climbing, thankfully, both shocks have compression adjust with near-lockout
- Bulls added a nicer full-surround chain guide to eliminate drops and clear debris from the chain if you’re riding in muddy or tall grass conditions
- Minor prop here, I love that the left chain stay actually has mounting holes to add a kickstand! That’s kind of rare for a full suspension electric mountain bike, but could come in handy if you commute or ride around town during the week
- The motor provides high levels of power and support almost instantly, so you can start a climb in higher gears or just get the support needed to balance right off the bat, the controller is measuring wheel speed, pedal cadence, and pedal torque rapidly
- Extra sturdy Shimano shifter levers allow for two-way action on the high gear trigger and multi-shift on the low gear lever, it’s exactly the kind of setup you’d expect from a nicer mountain bike
- Bulls has a great reputation in the US, their dealer network is expanding and the 2+ year warranty offered on this and other models appears to be well supported, shops have told me that this company is easier to work with and that has been my personal experience as well
- I like that the display panel is compact to reduce the potential for bumps and scrapes, and that there are dedicated buttons to activate lights and explore menus, it’s pretty deep for such a compact display but you have to use the joystick to navigate left/right and up/down which might not be as sturdy with lots of use compared to simple press buttons (the early Specialized Turbo models used a joystick that eventually broke for a lot of people)
- The motor kept supporting me, even when I was spinning (pedaling) very quickly at or even above 120 RPM, this was a big limitation with some of the older mid-drive systems and the takeaway is that you can simply pedal faster vs. having to shift gears to hit higher speeds in a pinch, as someone with a sensitive knee, it’s great to be able to spin faster vs. pushing harder and pedaling slower
Cons:
- I had mixed experiences with the battery mount design on this bike, it seats up into the downtube and sort of just drops out when unlocked, be extra careful handling this thing because it weighs ~7.1 lbs but doesn’t have an obvious handle, it could drop out and hit the ground which could cause damage… and replacements are expensive $900+
- The battery charger is relatively large and heavy at ~2.6 lbs vs. just 1.5 or ~2 lbs, because it’s built into a tough alloy casing, the magnetic Rosenberger EnergyBus interface is cool but can pick up iron filings if set down in the dirt or sand
- The Brose S motor is extremely capable, offering up to 90 Newton meters of torque, but it does not have shift detection like Bosch or Impulse, so you want to ease off when changing gears so you don’t mash and bend your sprocket teeth
- I struggled to figure out how to switch from km/h to mph in the Marquardt display, it might be something that is setup at the factory and not open to adjustment? I was not able to experiment with the app but perhaps that adds some additional features
- The display is a bit bright, in terms of backlighting, it only shows four bars for battery level (five, ten, or a percentage would be more useful), and the range estimate isn’t as dynamic as Bosch and some other companies where it gives you an range for each level of assist
- By default, the seat post dropper lever is mounted near the left grip, and it sort of gets in the way of the display panel (which is mounted just to the side of it), I’m not sure how to overcome this because the dropper lever would be really tough to reach if it was setup behind the display, maybe putting it on the right portion of the handlebar vs. the left?
Resources:
- Official Site: http://www.bullsebikes.com/
- More Pictures: https://photos.app.goo.gl/1vz4T0liGizBtyAm1
Mike says
Will you be reviewing the 45kph version? I wonder how it compares and whether it has the power to go up as steep of a hill as this version
Court Rye says
Great question Mike, I’m hoping to cover all of the 2018 Bulls models at some point. I’ll do my best to test how powerfully it climbs, my guess is that it would still be very capable. Looking at the Bosch CX vs. Speed motors, there is a drop in peak torque output, but it is still very capable. I’m not sure on the differences with Bulls, it may be the exact same motor hardware with slightly different firmware… or it could be a different winding setup inside.
Dan Dialogue says
As always, I like your reviews. Regarding the dropper post lever, it’s actually installed incorrectly. If it were turned around, reaching the display wouldn’t a problem (I think). It’s a shame that Specialized has left some of their users stranded. Maybe you remember, but I damaged my controller in a crash and had no issue getting one from Bulls. That’s a good sign!
Thanks!
Court Rye says
Awesome! I’m glad Bulls is treating you right. Thanks for the seat post lever positioning tips Dan! I feel like these guys are producing great looking products at a reasonable price and getting the shop support and customer service right. Getting first hand feedback is important so thanks again for taking the time to share it here ;)
Oliver says
I watched a ton of your videos and finally decided on the Bulls E-Stream AM 4, however your measured stand over height of 30.5″ for the medium does not match Bulls’ measurement of 820mm or 32.28″. I am 6′ with a 32″ inseam (in pant sizes). Should I go with the medium or the large? or What are your measurement for comparison. Your videos really helped introduce me to EMTBs and to narrow down my search from dozens to one! Thanks
court says
Awesome! Glad the site helped you Oliver, I do my best to measure all of the stats independently but there are mistakes on here… I don’t know where, but I have found them before myself when doing updates. I feel that the specs listed here are accurate, but you might be able to check with a dealer or even email/call the folks at Bulls directly. It sounds like an important number for you to really know. My experience has been that my own measurements are often more accurate than the official company specs because I do them all myself by hand and don’t copy/paste year to year. That said, sometimes the company gives me a pre-production model with different tires or slightly different grips etc. and that can play in. I’d love to hear what you come back with, if my measurement “measures up” so to speak ;)
phidge says
What is it with Bulls and frame size? I’d buy this bike tomorrow, but I’m 5’4.5″, and the frames start at 44 – ridiculous. Don’t they want to sell bikes to women and shorter men? They have very few bikes like this in a size for shorter folks. They’re missing out on a huge section of the market, as many women like myself want to get an e mtn bike to keep up with the men we ride with.
court says
Hi Phridge… I feel ya. Have you seen their “ladies” mountain model called the Aminga TR 1? I reviewed it with a younger girl who was able to stand over and I try to record the “stand over height” for all of the products on the site to help give you an idea of what it takes to mount and stabilize. The Aminga has a 27″ stand over for the small 41 cm frame vs. 30.5″ stand over on the medium 49 cm E-Stream EVO AM 4 in this review.
Jesse S says
If you go to the Bulls international website here, they show a list of frame sizes starting at 41cm. They need to offer the smaller sizing in the US. I’m 5’6 male and just want to know if the frame size 44cm will fit me ok.
Forrest says
Is this bike even out yet? Super interested in this bike right now.
court says
Hi Forrest! I cannot say for sure, you might want to contact local Bulls dealers or maybe reach out directly to the company. It should be available soon if not now and you might benefit from getting onto a pre-order list to make sure they have the right size in stock for you :)
Forrest says
Thanks for the reply. Love your reviews and your passion for ebikes really comes through! I have decided to pre-order the Bulls AM4 because it ticks all the boxes I was looking for (stealthy looks, large battery, quiet motor). What really pushed me towards a Brose motor was riding the Turbo Levo (Brose) vs the Powerfly 8 (Bosch). The Bosch was super loud though it had plenty of power, but the Brose is much quieter, which is what I’m looking for when I’m out in the hills here in Idaho.
Since this review is now 4 or 5 months old and your bike was a pre-production bike, do you every revisit your reviews using a production model? Thanks!
court says
Hi Forrest! I may get a chance to ride a production mode at some point and will comment here if that happens. Occasionally I’ll do comparison or roundup videos but usually it’s more of a model year update. I felt comfortable reviewing sample bikes for Bulls because of their reputation and high quality. Was there something specific you were concerned about?
Timothy Morgan says
I just ordered the AM 4, US delivery is slated for end of July, next ones due in October.
court says
Wow, it sounds like they are selling pretty well… hope yours comes on time and you enjoy it! Thanks for the update Timothy :)
MikeBCO says
I ordered my E-Stream EVO AM 4 in mid-May and was quoted mid to late July delivery. It shipped from Bulls to the dealer in late July and is set to arrive at my home tomorrow. I read tons of reviews before making my decision. My initial thoughts was to go with a full suspension e-MTB at the lower end of the weight scale. In the end, the two key deciding factors were larger battery and hence range, and battery compatibility with the pair of LACUBA EVO E45’s we own. I am champing at the bit to get out and ride it. Naming her Wooly Bully – of course. I’m expecting it is going to take a while to figure out how to ride her and that it will be different to how I ride my other MTB’s. I have ridden MTB’s clipped in for 20+ years and have decided to set this one up with flats and don good 5.10 MTB shoes. I’m thinking to change it all from the get-go, and to persevere with learning a new type of ride. Time will tell. I will post ride impressions after about a month of riding. PS. Props to Bulls and Propel Bikes for meeting delivery promise and great customer service all round.
Court says
Hey Mike! I’m really excited for you, but sorry to hear that it took just a little bit longer to arrive than maybe hoped. Love the name you picked out :P
I’m definitely looking forward to your ride impressions and updates! Feel free to comment here or join the BULLS electric bike forums I setup to post some pictures of your pedals and other accessories or just cool ride shots. Glad that Propel has take care of you, I like the owner, Chris Nolte, and trust their support long term.
Phil Mc says
I’ve had my AM 4 for 2 weeks now and have ridden 10 familiar single track trails for about 120 miles total. The bike handles very similar to my Specialized FSR Stumpjumper Comp 29er. Stable at speed and descending, a bit awkward only in the tightest switchbacks. Motor assist climbing through rock gardens is impressive. You can stage pedals to avoid rock strikes or thread front wheel through obstacles, nearly stopping momentum, yet motor is immediate help as soon as you pedal. I mostly ride in assist level 2 but level 3 on steep rough climbs is amazing. Battery range is also impressive. Yesterday I rode 17 miles in assist 2 with over 1,400′ elevation gain but 4,000′ total of climb. Residual range shows 49 miles at full charge and after this ride it stills shows 22 miles range. Another full charge ride of 500’/mile for 4 miles up from full charge on level 3 assist showed only 12 miles residual range at top of climb but after descent had recomputed range to be 34 miles. Great brakes, good suspension and the very solid feel of this bike has me very pleased. There’s some fast and stiff competition out there but this one is worth your consideration if you’re buying a bike right now.
Court says
Awesome! Thanks for sharing your experience with us, Phil. I really like how integrated and responsive the Brose motor is on this bike… and the full suspension setup. It’s nice to hear your technical comparison between this and the FSR Stumpjumper Comp 29er (and that’s a non electric bike). I ride the FSR Stumpjumper Comp 650B and agree with your thoughts.
Phil Mc says
I’m impressed with the range of this bike. I had 18 miles with 800′ climb across town and back at assist level 3 from full charge showing 34 residual miles. Rode from 6,400′ to 9,000′ in 11.5 miles at assist level 2, actual climb in 6.5 miles, to show 6 miles residual at top. Once I descended for 15.5 miles residual had recalculated to 12 miles. This shows me my type of riding range, roughly 3,400′ ascent in 15 miles, 15 miles level + moderate up/down, and 15 miles downhill to be a total of 45 miles with a reserve margin of 6 – 12 miles. The motor assists from low cadence up to full spin and encourages puke inducing exertion to go up climbs you’d never achieve alone.
A few issues:
No complaints, 200+ miles have shown me this is a great bike.
Court says
Phil! Those are some amazing pro tips. Thanks for taking the time to explain your range (I wonder how tall you are and how much you weight?) and thanks for the tips on beveling disc brake rotor holes to reduce noise and the duct tape rattle-reducing. Just awesome! Sorry for the late reply, been at Interbike all week ;)
Phil says
I’m shrinking though about 5’11” and 185lbs. I have a little more length in torso and arms so 49 (large?) frame gets a little more reach from a 120mm stem. The Mary Bars I run have a lot of sweep giving a relaxed, efficient position sitting and standing, even aggressive climbing. Speaking of, at 3rd or 4th level assist I’m discovering I can climb pitches I don’t want to ride down. I let a bit of pressure out of the forks and shock, so now riding with more relaxed suspension. Bike is still rock solid, just more comfortable through the rough though I get more pedal strikes if not careful.
Court says
Great update, Phil! Thanks for sharing your height, weight, and ride settings for this ebike. Sounds like you’re having a great time out there! I really like this ebike, you picked a good one for comfort, performance, and style :D
Steve says
When do you plan to post your review of the 2019 E-Stream EVO 4 AM and E-Stream EVO 3 AM?
Court says
In the coming month or so. I’ve already filmed the E-Stream EVO 4 AM but working in a variety of brands so it’s not just BULLS constantly. Should be soon, keep an eye out in the coming week for that one.
Ralph says
Love your reviews and very interested to see your review of the 2019 E-Stream EVO 4 AM. There are a lot of questions out there about the new ‘Flex’ mode, how the dual batteries are implemented (when running one or both batteries), is there a cover for the empty side when running one battery, the performance of the new Mag motor… on and on. Very little information on these and other details. out there. Be cool to get some sort of notification when you post new reviews…
Again.. you do an awesome job!
Court says
Thanks for identifying these areas, Ralph. I’ll keep the notes and dig deep when I do get some time on the new E-Stream EVO 4 AM :)
Ralph says
Follow on note with more specific question details. I hope you can address some of these with your up-coming review of the 2109 AM 3 or 4. I talked to a few dealers who said they haven’t a clue:
Thanks for considering these questions when you release your review. Your reviews are always ‘Top Notch’
Ralph
Court says
These are EXCELENT questions, Ralph. Thanks for helping me zoom in, I’ll be sure to review this list when covering the new BULLS models ;)
Ralph says
Hi Court, love your reviews. Will you be updating the Top Rated bikes soon? Are these still your current picks or have they become stale with the intro of 2019 bikes?
Court says
Hi Ralph! Yes, the list is a bit out of date and should be looked at. Thank you for calling this out! I’ve been focusing on some programming tasks and just fallen behind on comments and some of the resources here :)
LISA WEBER says
Hi Court! Great reviews! Your Top Rated list needs updating and looks stale. It would be helpful to have this list updated at least 2x per year due to all the new bikes you review. Keep the reviews coming, we love your work.
Happy 4th of July.
Thanks
Court says
Hi Lisa, I agree with you. Been waiting for some content to get published and a few updates to be made to the site during a big platform transition. The top rated list has been a lower priority but it’s definitely an important page and I appreciate you reminding me and calling it out. I’ll get on that ;)
Dave says
My second Bulls E Stream bike had the 2016 27.5 + and I sold it this year because I fell in love with the AM4. It’s everything you say in your great review and more… you didn’t mention that it has Walk Assist. Yes, all you do is hold down the power up for the amount of assistance you want, and the bike will walk itself. Make sure you are off the bike as it was not intended to be used as a throttle.
I did not read all the comments… so if someone else has pointed this out, my bad. I live in Western Canada and have great mountain bike trails that you should use for your reviews.
Court says
That sounds awesome Dave! Thanks for the tip about walk assist. I also live in Western Canada now (Vancouver) so maybe we could go riding sometime! You can email me through the contact form here on the site ;)
Dave says
I’m in Kimberly BC, about nine hours east. If you ever pass this way… I’m not that hard to find… you can look me up, if you got the time.
Court says
Sweet, thanks so much Dave! I’ll keep an eye out for you and have your email here as a good starting point ;)
