Velotric continues to grow and with each new release, their standards, specs and features seems to get better when considering bang for buck
New Summit 2 is positioned as Velotirics everyday, do anything SUV style ebike for those who want their two wheeled adventures to be as capable on the 9 to 5 commute as it is on the weekend off-road exploring.
While the price only increased by only $100, the increased spec for dollar is shockingly good with a bump in nearly every corner of the bike and were not talking little things, we are talking new frame design/geometry that improves the seat tube angle and adds an adjustable stem with a rise in the handlebar giving a much more balanced riding position thats ultimately more comfortable. Plus, with more power, more battery, an air fork, more range, more security and tech. The spec-for-dollar value feels like some sort of unseen value in 2026, but hey I’ll take it.
In my time with the Summit 2 over the past couple weeks, I was able to really stretch its legs and see where the bike shines and where it might see some limitations. So, with over 200 miles under our belt, here are our full thoughts on the all-new Velotric Summit 2.
My Experience Riding The Velotric Summit 2 E-Bike
Hopping on the Velotric Summit 2, a few things become immediately clear. You can really see the progression Velotric is making as a brand, especially when you look at the measurable improvements they’ve made over the original Summit 1.
It starts with better frame construction using triple-butted aluminum and a new, balanced posture. I could really feel the even weight distribution between my upper body on the ergo grips and my lower body on the saddle. Between the frame geometry and the addition of an adjustable stem with a slight rise in the bars, my weight felt perfectly balanced throughout my rides.
But it’s not just about frame geometry, a stat usually reserved for bike snobs. We’re talking meaningful upgrades in almost every category. Power has been bumped from 90Nm to 100Nm of hill-crushing torque. I’m not exaggerating when I say the Summit 2 now holds the fastest climbing speed on my local test hill across every e-bike we’ve ever tested, regardless of type or power rating.
Moving past the muscle, let’s talk about components. They upgraded from an 8-speed Shimano Altus to a 9-speed Shimano CUES. The CUES system has much better chain tension in the rear derailleur, which means you can actually take this drivetrain off-road without the chain flopping off at the first bounce. It might seem like a small detail on paper, but good chain retention and smooth shifting are a huge deal when you’re trying to enjoy a trail instead of hopping off to fix your chain every 30 minutes.
Ride comfort has also taken a big leap. Velotric ditched the old coil spring and added a genuine air fork, an RST Vibe with 120mm of travel. It features adjustable air chambers and rebound settings you can tune to your weight. If that sounds like technical jumbo-mumbo, just know this: coil forks are limited. If you’re a 225lb rider, you won’t get the same benefit as a 150lb rider. With an air fork, you just add or remove air pressure to match your body weight. Whether you’re 120lbs or 300lbs, you get a smooth ride with the correct compression without either rider having to sacrifice performance.
The list of upgrades goes way beyond these few paragraphs, but when I step back and see everything Velotric brought to the table for a price increase of only $100, it’s pretty dang impressive.
Spec-hunting aside, the Summit 2 stays true to its roots as an “SUV style” e-bike. It’s just as good as a daily commuter as it is an off-road explorer on the weekends. It still features the popular “SensorSwap” tech, so you can choose between a torque or cadence sensor without having to do a bunch of homework before you buy.
It also comes “trail-ready” with full-coverage fenders, a complete LED lighting suite with brake lights and turn signals, and a tech package that might be the coolest we’ve seen to date. For example, they’ve added “Pulse Mode.” You can connect a heart rate monitor to the bike, and it will dynamically change the power delivery to keep you in your target heart rate zone. If you want an easy “Zone 2” day, you just let the bike figure it out for you while you ride.
Finally, they didn’t cut any corners on safety. The bike is armed with UL 2271 and UL 2849 electrical certifications, plus IPX6 and IPX7 water resistance ratings for the bike and battery. The Summit 2 represents more than Velotric trying to compete with the SUV segment; they’re here to make a statement.
In my time riding the Summit 2, I spent a good amount of time mixing it up both on and off pavement. The bike feels equally at home doing either task and it never feels like I’m pushing beyond what it’s capable of doing.
I did have one small issue in my rides, which is mostly my fault. When off road, I aired down a few PSI past the recommended rating and after a few drops of some smaller obstacles, I managed to cause a pinch flat on the rear tire. If you are not familiar, a pinch flat isn’t the result of the tires puncture protection not working, but rather the result of being too low on air pressure and when landing hard, the extra weight from the motor in the rear end along with my body weight cause the tire rubber to ‘pinch’ the inner-tube and that extreme pressure causes the tube to tear and ultimately go flat. I tell you this for two reasons, one to remind you all not to be like me and air down too far, but the not-so-fun reminder of trying to change a flat tire in rear hub motors with a few trail tools in my kit. It’s only fair that I share it.
With that said, the Summit 2 is an absolute blast to ride, it has the power that will make any rider happy, the comfort to tackle longer rides without breaking your back thanks to the improved geometry in the seat tube angle and adjustable stem and the grit to get rowdy off road. It balances the act of being an ‘SUV’ e-bike better than nearly I’ve tested to date. It’;s safe to say I walked away impressed with the new Velotric Summit 2.
Range
Estimated Range (from Velotric):
- Pedal Assist Range: 95 miles
- Throttle Range: 70 miles
- Eco Mode Range Test: 81 miles
- Boost Mode Range Test: 36 miles
The Summit 2 already had a good reputation from the first model, which was rated for about 70 miles. This new version has a larger 48V battery (801.6 watt-hours), and Velotric says it can now hit up to 70 miles using just the throttle or 95 miles if you’re pedaling. Since the bike also lost 5 pounds compared to the last one, those claims seem pretty realistic.
To see if those numbers hold up, we did two different range tests. We try to keep things real: our riders weigh between 180 and 220 lbs, and we ride on city bike paths where you have to slow down for joggers and stop at intersections. We also make sure to include plenty of hills, usually between 800 and 1,000 feet of climbing.
On the first run using the lowest assistance level, we went a solid 81 miles before the battery died. After charging it back up, we did a second run on the highest setting. Even going full blast, we still got 36 miles out of it.
These results show what you can actually expect to get in the real world. If you stick to the middle settings (PAS 2 or 3), you can count on getting somewhere between 60 and 80 miles on a typical day.
Power (Motor & Battery)
When it comes to the motor, Velotric didn’t just give the Summit 2 a tiny spec bump; they completely swapped out the tech. They moved from the old 90Nm outer hub motor to a new 750W motor that peaks at a massive 1300W and pushes a burley 100Nm of torque. If you’re wondering how that translates to a felt ride, well, let’s just say it has some serious “get up and go.” Whether you’re trying to beat a traffic light or tackle a steep trail, the extra grunt is noticeable, making it one of the strongest climbers I’ve tested to date, across any e-bike segment.
What’s even cooler is how you control that power with the new “SensorSwap” system. On the old model, you were stuck with a standard torque sensor. Now, you can toggle between Torque Mode for that natural, intuitive feel on trails, or Cadence Mode when you just want the bike to do the heavy lifting on flat roads. They also added a “One-Touch” class toggle, so switching between Class 1, 2, or 3 is way easier than digging through app menus like you had to do before. Plus, if you’re a real geek for stats, the new “Ride Tuning” in the app lets you personalize how the motor kicks in for each PAS level.
On the battery side, we’re looking at a jump from the old 14.7Ah pack to a beefier 16.7Ah (801.6Wh) setup using high-quality Samsung or LG cells. That extra capacity is a big reason why the max range jumped from 70 miles up to a whopping 95 miles. It’s also got an IPX7 waterproof rating, which basically means it’s built to handle a serious soaking. You don’t have to panic if you get caught in a downpour or need to spray some mud off the frame after a ride.
To keep that battery life optimized, the Summit 2 now features four distinct riding modes plus a “Smart Recommendations” system that suggests the best mode based on how you ride. And I have to mention “Pulse Mode” again here, because the bike can sync with a heart rate band to adjust power based on your effort, it’s actually working to make sure you aren’t wasting battery (or your own energy) when you don’t need to. It’s a smart, efficient setup that feels like a huge leap forward from the first generation.
Components
If you haven’t noticed a theme yet with the Summit 2, I’ll remind you here again as we peruse the component lineup, because once again, it’s all about improvements in nearly every single area.
Starting with some of the more eyebrow-raising changes, the front suspension fork on the Summit 2 got a massive upgrade, ditching the coil spring for an RST Vibe air fork. It’s complete with 120mm of travel, 34mm stanchions, rebound and lockout features, and best of all, adjustable air chambers that correspond to the rider’s weight for a tailored suspension system that works for everyone, regardless of body weight. I could go on and on about the felt ride difference of an air fork over a coil fork, but you likely get the point by now; and if not, don’t take my word for it, just go try one, it sells itself.
When it comes to the drivetrain and gearing, we get another welcome improvement by swapping the old Shimano Altus 8-speed for a Shimano CUES 9-speed, complete with a wider range 11-46T cassette and a 40T narrow-wide chainring. This wider range allows for more precise control and pedal feedback based on the inclines and terrain you face. Plus, moving to the Shimano CUES U4000 rear derailleur gives riders the Shimano Shadow RD system, which has better spring tension for more aggressive riding and fewer dropped chains, an area where the previous Altus RD fell short.
The Summit 2 still rolls on 27.5” double-walled alloy wheels. These are not tubeless-ready or compatible, so keep that in mind. Tires wrapped around those wheels are Kenda off-road tires with puncture protection sized at 27.5×2.4”. Just keep my pinch flat in the back of your head should you choose to air down the rear tire.
Braking stayed the same with the popular workhorse from Shimano, the MT200 hydraulic disc brakes, set up with 2-piston calipers and 180mm rotors front and back. It’s a setup that just worked on the Summit 1 and continues that trend with the Summit 2.
Up in the cockpit, there are a few small yet important improvements. First, Velotric brought the handlebar down in size from 780mm to a slightly more manageable 740mm with a 10° sweep-back; this still enables better rider control even in sketchier terrain. On the left side is the new display control pad and a push throttle, and over on the right are the Shimano CUES index shifter and an included bell, which can also covertly house a GPS tracking tag.
Centered on the handlebar is the new 60mm adjustable stem that keeps the stubby length of a proper trail bike but with just enough length and adjustability to really improve rider comfort based on how far they feel like leaning forward.
Contact points are all present with the usual suspects: lock-on grips, flat composite pedals, and a Velotric-branded ergonomic saddle. The seatpost is a 31.6mm alloy post that extends a total distance of about 350mm with about a 6-inch adjustability range.
The maximum payload for the Summit 2 is a hefty 440 lbs and, in terms of included accessories, it ships with full-coverage fenders, a 500-lumen (130 Lux) headlight, turn signals, and a brake light.
Screen / User Interface / App
Next up is the tech side of things, and Velotric really leaned into making the Summit 2 feel more modern. They moved away from that big 2.8-inch central screen on the original and went with a 2.0-inch full-color display mounted on the left. It’s a cleaner look that stays out of the way, but it’s still easy to read. Plus, it’s got a USB-C charging port right there, which is a lifesaver if your phone starts to die while you’re using it for navigation.
The security and “quality of life” features got a massive overhaul too. On the first model, you just had Apple Find My. Now, they’ve added Android Find Hub support, so no matter what phone you use, you’ve got a better chance of tracking your bike down if it ever goes missing. They also made getting on and going way faster, you’re no longer limited to just a physical key or digging through an app. You can now use a keyless NFC card or even just your smartphone to unlock the bike.
One feature I didn’t know I needed until I tried it is the new “Hill Hold Assist” in walk mode. On most bikes, walk mode just helps you push it forward. But if you’re on a steep incline and have to stop, the Summit 2 will actually hold its place so it doesn’t roll back on you. It’s one of those small touches that makes a big difference when you’re maneuvering a heavy rig on a hill.
Finally, the connectivity is as solid as it gets. Everything, the battery, controller, and display, can be updated over Bluetooth through the app. This is also where that “Pulse Mode” fitness tech lives, allowing you to sync your heart rate for a tailored workout. When you compare it to the original Summit 1, which didn’t really have any of these fitness or advanced security features, it’s clear that the Summit 2 is playing in a completely different league.
Velotric Summit 2 Model Options
Frame sizes for the Velotric Summit 2 remain the same: regular and large options, although Velotric did alter the recommended sizing ranges a bit. The regular is marked for riders between 5’2” and 5’10”, while the large is targeting the 5’7” to 6’5” crowd. I was sent a large for testing and this review, and at 5’11”, I found the fit to be great and likely could have been fine on either size.
The Summit 2 sports some new colors; this time around, owners can pick from three different shades: Galaxy Purple (which I’ve affectionately named ‘Purple Rain’ around the office here), Ocean Blue, or Glacial Silver.
Included accessories include the usuals, like pedals, a kickstand, and full-coverage fenders (front and back), as well as front-to-back LED lighting, turn signals, and a tail light/brake light combo. You also get an NFC proximity card you can keep handy downtown to just tap and unlock or lock your ride should you step away.
Should you want to really put your Summit 2 to work, owners can opt for the rear rack that is optionally available, and the frame comes pre-fabbed for a quick and easy installation.
Velotric gives the Summit a standard 2-year warranty with the purchase that covers all the electrical components as well as the bike, and a 14-day trial period for those still on the fence. Plus, for those concerned about local service when buying direct online, Velotric has partnered with over 1200+ bike shops across the USA and you can locate the nearest with just a tap in the App or on the Velotric site.
Is The Velotric Summit 2 Worth Buying?
I’ll be honest: if you’ve made it this far, kudos to you. We covered a lot of ground with the Velotric Summit 2, and it’s for a good reason. Velotric took a good bike, added a small army’s worth of upgrades at nearly every stop, and then, in some sort of act of voodoo, raised the price by a margin of only $100.
Go ahead and add up the differences on your own; they packed a ton of value onto the Summit 2. They didn’t blindly throw ‘specs’ at a bike and hope for the best; they took the time to see what riders needed and what they wanted. Heck, in the case of the ‘Pulse mode’ heart-rate-based assistance, they gave me things I didn’t even realize I wanted and now really appreciate.
But let’s dial back the praise for a minute and be honest about a few things. Is the Velotric Summit 2 ‘perfect’? Nope. I’d love to see the brakes have e-cutoff sensors to kill power to the motor in the event of a hurried or unexpected stop. Is it the ultimate ‘eMTB’ ready to rip from Bentonville to B.C.? Nope, it’s just not made for that, and taking it to those places would be a bad idea.
So, what makes the Velotric Summit 2 so great, and who exactly is it for? It’s for the person who doesn’t want a dedicated bike for each activity filling their garage walls (ask my wife why that’s so annoying, aside from just the cost). It’s for the person who wants to have the power and speed to carry their gear to and from work, and then equally let their hair down on the weekend and go explore some remote gravel roads beyond the city limits.
The Velotric Summit 2 delivers a ride that punches above its weight class in terms of ‘dollar-for-spec’ value and has the chops to be a pavement princess as much as a weekend warrior. And that, my friends, is the beauty of an SUV-style e-bike.
Pros
- Bumping the motor to push 100Nm’s of torque and peaking at 1300W’s makes the Velotric Summit a hill-crushing rig with speed on flats to match.
- Stepping back, Velotric really pushed the limits of what value can be in e-bikes, updating and upgrading nearly every aspect yet only increasing the MSRP by $100. Feels unheard of in 2026.
- Versatility makes up the DNA of the Summit 2, its kitted front to back with LED lighting and turn signals, comes with fenders, an air fork, and pre-fabbed for an optional rear rack, making it a commuter, a weekend warrior or even a legit bikepacking e-bike.
- Updating the drivetrain from the loosy-goosy Shimano Altus to the stronger Shimano CUES with a wider 11-46 gear range was a solid option and will certainly help with those pesky chain drops.
- If you’re a fan of smart tech, security and customization, Velotric is quietly becoming an industry leader, packing the Summit with NFC security, GPS Tracking, Apple Find my & Android Find Hub support.
- Service options are plentiful as Velotric has partnered with over 1200 shops across the USA as well as sending OTA updates to the bike for shop-free updates.
Cons
- Shimano MT 200 brakes perform great, but I’d like to see the integration of braking with e-cutoff sensors to kill motor power in a hurried stop.
Reader Interactions
