The BULLS Lacuba EVO E45 is the kind of electric bicycle I’d choose in place of a car. It can go far, it can go fast (28 mph vs. 20 mph on most electric bikes) and it’s fairly comfortable. With full length integrated fenders, a slim chain guard, twenty gears to shift through and integrated lights with a brake mode that goes extra bright anytime you pull the levers… this ebike is fully capable and safe feeling, adding to the LED lights is reflective tire paint that is visible from the sides so you are less likely to get blindsided. Given the longer distances and faster performance from this bike I think it’s important to also feel comfortable and tho that end you get name brand locking ergonomic grips from Ergon, a sturdy adjustable angle stem and a vented comfort saddle from Selle Royale. The battery pack offers 37 volts and a whopping 17.5 amp hours of capacity for extended range and I think that makes it a contender for trekking and touring rides as well as commuting. One feature that really stood out to me when testing this bike was the large display panel that communicates your leg power and the motor power with charts on either side of the dash so you can lear to ride more in sync with the bike and perhaps shift more efficiently. At $4,400 this is not the worlds cheapest electric bike but the Shimano Deore XT drivetrain, multiple size offering and two frame builds (high-step and mid-step) don’t come free. You do get a two year comprehensive warranty and BULLS is an international brand going on its second year in the USA as of 2017 with positive feedback from the consumers I’ve chatted with.
Some things I do not like as much about this bike include the kickstand, which springs back up automatically and makes the frame easier to tip accidentally. The battery can be charged on or off the bike but the rubber flap that covers the charging port on the downtube doesn’t fit into the slot very easily and might let dust and water in over time. The keyhole, where you unlock the pack, is also positioned in a sort of vulnerable spot right where the left crank arm rotates by… so it could get bent or even broken if you’re not careful. And while I love the aesthetic of this and other BULLS models, the battery pack mounts up into the downtube so getting it out requires a bit of extra care and coordination so that it doesn’t drop down and hit the ground. Note that the battery can be left on the bike without being locked on as well, this just adds one more consideration and process to forget or skip. I’m more a fan of other systems like Bosch and Yamaha that automatically lock the pack in once it’s seated. Finally, as with all current gen Brose drive systems, there is no shift sensing so you’ll want to be extra careful when riding and shifting… plan ahead so you don’t mash those gears and chain, just ease off the pedals to de-activate the torque sensor and then shift while spinning more gently.
So coming back to what works on this bike and where it would fit in terms of use. I think there are three big considerations when purchasing an electric bike for daily use and transportation. The reliability is important, the balance and handling and the fit. There are always ways to improve comfort with accessories or adjustments to the existing hardware but the Lacuba E45 already has that nailed down with the adjustable stem and range of sizes. I think I’d strongly consider the step-thru frame here vs. the more traditional “male” diamond high-step because I’d put the rack to use with a trunk bag or panniers and really hate knocking my knee on those things when swinging it over. One thing that impressed me with the frame designs was how stiff and solid they felt, even the mid-step, because of the triangular multi-tube designs. Yes, the low-step isn’t as low as some wave frames but it offers better performance. I was delighted to see that they even managed to squeeze a bottle cage in the triangle and added a second pair of bosses to the top tube! Again, excellent almost necessary additions if you want to ride long distance.
At the end of the day, I see this ebike as true transportation. You don’t have the speed limitations, the safety concerns or the quality questions that some other cheaper bikes present. It was very comfortable and built solid. Even if you did really push this thing and run out of juice before arriving at your destination, the 20 speed drivetrain ensures you could still lug this 61.5 lb bike up a hill without too much effort (though it would be slow). On the flip side, pedaling at full speed also felt comfortable and the frame handled well… no speed wobble here. The motor and battery blend in perfectly with the gray/black color scheme and keep weight super low and centered. The charger is a little larger and heavier than some others I’ve seen but it’s not the worst and you could easily toss it into a trunk bag for charging on the go. The carry rack has excellent pannier blockers on the side and is made by iRack so you can fit their branded accessories (kind of like Topeak does) or you could get something like this for $17 which has a zip-out pannier flaps and a shoulder strap for easy transport when you get off the bike… taking your gear along to keep it safe. The nice thing is, you don’t have to worry about taking the lights with you, the display is removable to reduce exposure and vandalism and the battery locks securely. It’s a great setup in my opinion. Big thanks to Bulls for partnering with me for this review.
Pros:
- Not only does the bike come in a high-step and a mid-step frame style but there are four frame sizes to choose from and all of them have two pairs of bottle cage bosses! Many times I see electric bikes that don’t have these extra mounting points and that makes accessing water or accessories less convenient
- This e-bike would make for an excellent commuting or trekking platform because of the premium rack (with pannier guards and clasp point) and full-length fenders… not to mention integrated lights front and rear and nice bell
- The rear light is setup to get brighter when you activate the brakes, this make you even more visible when riding in low-light conditions and specifically when changing speeds
- Massive 203 mm hydraulic disc brakes for smooth but powerful stopping, they’re designed to reduce the effort needed to brake and stand up to heavier loads if you’re trekking and carrying a lot of gear
- Slim, light weight chain guard keeps your pants or dress from getting greasy and dirty, the kickstand is positioned far back on the frame to stay clear of your crank arms
- Comfortable Selle Royal saddle, slim adjustable suspension fork, ergonomic grips and adjustable angle stem help you ride longer, even the handle bar (which is raised a bit) improves comfort and control
- In addition to the lights, which help you see and be seen, are reflective striping marks on the tires, these increase your visual footprint so cars and other cyclists notice you coming from the side
- The Schwalbe Energizer Plus tires are designed to be puncture resistant, they feature a Kevlar lining that resists thorns, tacks, glass and other sharp objects
- The display panel is bright, easy to read and understand and its casing is sturdy, I love that it can be completely removed from the mount for safe keeping, I also like that they included two power graphs that show you real-time how much energy you are exerting and how much the bike is spending… it might change how you ride and shift the gears and ultimately help you conserve electricity on longer rides
- Both wheels offer quick release making service and transport easier, the battery pack also comes off the frame fairly easily and can be charged separately
- The Lacuba EVO E45 is one of the stealthiest electric bikes I’ve seen thanks to its completely integrated battery and compact mid-drive motor… it’s also very quiet
- I love that the bike can go above 20 mph! This is useful for commuting, keeping up with traffic and just cutting down on the time it takes
- You get an extra large battery pack here that’s designed to make trekking and touring possible or offset the air resistance drag of riding at higher speeds
- Excellent two year comprehensive warranty provides some peace of mind, also, BULLS has been operating in Europe and other countries for years and seems to have a good reputation for quality
- You get 20 gears on this bike so you can really dial in how you pedal, making it comfortable and capable for climbing or riding at high speed… it’s nice having those extra gears if you ride super far and run out of battery just short of your destination because the bike does weigh 60+ lbs, most mid-drive bikes are limited to 11 gears and don’t have a front derailleur like this so that’s one big advantage of the Brose motor system
- The short travel suspension fork and medium width tires offer a good balance of comfort to efficiency and performance but if you’re riding far and hitting bumpy rattly terrain consider a 31.6 mm seat post suspension, SR Suntour (the same people who make the fork for this bike) make a good one called the NCX here
Cons:
- If the bike hasn’t been used for a while the battery enters sleep mode and you have to press the power button on top of the pack as well as on the control pad, this confused me at first when going directly to the display pad as I thought maybe the bike needed to be charged or had an issues
- The rubber charging cover for the battery didn’t fit easily and made me wonder if dust and water might get in over time… I like that the interface is magnetic so the plug doesn’t get bent or tip the bike if you trip over it however
- Be sure to lock the battery to the bike as you can simply connect it without locking (many other bikes activate the lock when the battery clicks in?) also note that if the key is left in it could get bent by the left crank arm which rotates close past the keyhole
- No shift sensing technology on this bike… considering you get 20 speeds to shift through I’d recommend being careful and learning how to ease off pressure when shifting to avoid mashing of the chain and sprockets, the motor uses torque sensing so it’s easy to pedal up to speed then back off while still rotating in order to reduce strain when shifting
- I dislike the Hebie spring activated kickstand, yes it’s mounted in the correct place but the fact that it automatically swivels up makes the bike less stable and this thing is expensive, I don’t want it to tip and in my experience normal fixed kickstands work just fine :(
- At roughly 2.2 lbs the battery charger is a little heavy and large, though I love that it uses the EnergyBus standard (sending data and electricity) because I believe it makes updates easier
- Since the battery mounts up into the downtube vs. sitting on top of it I found that you have to use more care when removing it (so that it doesn’t just drop out and hit the ground)
Resources:
- Official Site: http://www.bullsebikes.com/
- More Pictures: https://goo.gl/photos/VqjaZazNcz8YxyJB9
BULLSreadTHIS says
Bulls, I bought this bike and it arrives this week. I’m a bit peeved that the bike doesn’t come stock with an IGH. Now I have to buy a rim an IGH and have it laced up, expensive and a pain. Why not offer a service called myBull? Which allows a user to customize their bike?
Court Rye says
Hmm, that’s a cool idea, kind of like what Dell did with PC Computers years ago. I think there’s a long wait time between manufacturing and shipping from Asia and Europe before the bikes could be delivered as specced but maybe in the future we will see more manufacturing in North America and customization like this could make sense, I’d love that kind of service! I hope you enjoy your bike and welcome your comments once you’ve had a chance to use it some ;)
bullsreadthis says
I received my new e45 and have about 90 miles on it so far. As an update to the article, there is now a new firmware on the Bulls bike, and from what my dealer said, every Bulls bike gets it. It now has 5 power modes, off + 1-4 levels of assist. I mostly ride the bike in level 3 and it ranges from 9-10 miles per battery bar (5 bars total). I have done several 20 mile round trips using 2 bars of battery. I’m averaging about 20 miles per hour. As Court states in the review, you have to work for 28mph, but staying in the 22-24mph range is pretty easy. I have noticed a decrease in power at temperatures over 100 degrees outside (may be protection sensors). If you want to buzz around fast in the mid 20’s at level 3 of 4 assist, you can expect about 45-50 miles of real range.
One bummer is that the Specialized Levo chargers do not work on the Bulls bike, seems kind of silly to me. They are probably all made in China at the same factory. This bike comes with a whopping 5amp charger!
Final verdict, I think this bike is the best commuter bike on the market. The serious contenders are the Giant (loud motor) and the Integrale 11 (noisy and creaky). I have rode all 3 and the Lacuba wins, hands down. The brakes, quiet ride, and the capacity put it over the top. I can’t overstate how nice it is to have 203mm (8 inch) rotors when you are in a jam at 28mph. I bought mine at Great Western Ebike.
Court Rye says
Awesome comment, thanks for sharing your experience with the Lacuba and other models… it’s great to hear from an owner and yeah, it’s too bad that the charger doesn’t work with the Turbo. I think the bigger ebike companies are being super careful so that their batteries don’t have any issues (like the Samsung phones did). It sounds like you’re quite the ebike connoisseur given that you also have a Turbo Levo?!
bullsreadthis says
I have too many ebikes…but the Levo FSR Comp is my favorite. My only complaints on the Levo’s are the crappy brakes and no initial option on the battery upgrade. I do a lot of long, steep descents and the stock brakes are just junk. I eventually switched them out for Shimano Zee’s. The bad brakes are the reason I passed on the Vado for my commuter, which comes stock with 180/160mm. So in addition to paying nearly a grand more for the Vado, I would have to pay another $500 for decent brakes.
Way to go Bulls on putting some really nice stock components on the Lacuba. In fact, I was initially bummed about the lack of IGH, but the XTs have shifted pretty smoothly. We’ll see after 1,000 miles though. The Lacuba is soo smooth, feels like a BMW 7 series or something. btw, I went with your suggestion on the XCR suspension seat, I like it, thank you!
Court Rye says
Nice! It’s interesting to hear your feedback on the brakes. I feel that Specialized could have just made two Vado models with optional battery sizes and accessories or none to keep it simple… but that doesn’t address the brake concern you had. Bulls has done a great job with the Lacuba and I’m glad you are enjoying it. The suspension seat posts can make a big difference, at least for me, so I’m glad you’re also enjoying it :)
BULLSREADTHIS says
I did a leisure ride today of 28 miles averaging 16mph. I was able to get 18.1 miles per 1 battery bar on level 2 of 4 assist, that puts the range at about 85-90 miles in level 2. After the 28 mile ride, I still had 4 bars remaining.
Here’s my guess on range at this point, based on my rides:
I’m super impressed with the battery and motor efficiency. I’ll post some high-speed numbers in the next week or so.
Court Rye says
This is very useful, thanks for sharing your experience with the bike since you’ve had a chance to really use it. There may be a drop over time but you should get 1,000+ solid cycles of high output before the Lithium-ion batteries begin to fade.
Greg says
I bought the Lacuba Evo E45 a few months ago, partly because of your review. I LOVE this bike! It’s smooth, quiet, powerful, has good range, and I love all the touches. The lights, the brake light, the rack, the fenders, the shifters, the bell, the display the water bottle bosses…. all of it adds up to greatness. The brakes work. What I mean by that is, I’m not really into what size they are, or how they’re mechanized, I only care about the result, and the result is perfect. I weighed 270 pounds when I bought the bike, and have panniers on it, so it’s well over 300 pounds total, and it stops easily and smoothly, without me thinking about it other than to put on the brake.
Also, I have a Giant LA Free (very old, I know) and it also has the motor in the bottom bracket. It CAN be ridden without motor assist, but it tires me out in about 2 blocks. Functionally, it doesn’t really work. The E45, however, rides amazingly well for such a big and heavy bike. I actually have repeatedly ridden several blocks before I remember to turn on the assist. Admittedly it’s a slight downhill slope coming out of my home, but the bike can truly be ridden without assist.
I keep the bike on level 3 assist all the time (when I remember) and it probably does only have 50-60 mile range going above 20MPH most of the time with a 260lb rider, but that’s still pretty impressive. The integration of power is so smooth, it makes me literally smile. The LaFree used to surge when you applied torque. It was fun to feel, but I’d subjectively describe the way this bike rides differently. You can tell the bike is helping, particularly when you change assist levels, but if you just leave it, and don’t think about it, the feeling you get is just that you’re riding a bike, and you’re just stronger and faster and have more endurance than you thought. It’s so seamless, you can forget it’s helping. Don’t think that means it’s not helping or underpowered because nothing’s further from the truth. It’s just perfectly matched to you so it amplifies what you do.
My only complaint has already been noted – saying it’s a 28MPH top speed is technically true, but you have to seriously work to get there. If you think you’re going to commute at 28MPH, forget it. I’m not sure whether the motor doesn’t have the power, or if the firmware just drops it’s assist, but anything above 25 is mostly the rider, even at the highest assist. That said, I can pretty easily sustain speeds between 20 and 25 on level ground.
It’s expensive. Once you get past that, it’s close to perfect.
Court Rye says
Hey Greg! I loved reading your comment, so glad you found my review helpful and thank you for giving back and sharing your weight and ride experiences… that seriously helps others and that’s what EBR is all about! Ride safe out there man :D
BULLSREADTHIS says
Greg, did you get the new firmware update? The new firmware has 4 Assist levels. Mine came with the new firmware, but mine is only a week old.
Greg says
I bought the bike online, since the closest Bulls dealer is an hour away, and I can’t transport the bike anyway. I contacted Bulls about the upgrade, as well as the closest dealer, but neither has responded to me (it’s been a week). I’ll try again. I want the upgrade, but I’m worried it’ll be tough to get it, after reading other people’s comments.
Court Rye says
Hmm… thanks for chiming in on this Greg, any progress? I feel like these ebike companies should provide the updates online to customers vs. just shops. I could see it taking a lot of time for the shops and yet it’s not that complicated to do. Who is your nearest shop? Maybe you can get the update yourself if you ask Bulls? Keep us updated.
Gert says
Hi Court, I am confused. A lot of websites (mainly in USA) claim that this bike has a Brose 350W motor. But most European websites write it has a Brose 250W motor. Also the official Bulls website.
Today I did a test ride at a bike shop here in Belgium with an Bulls E-STREAM EVO 45 FS. The reason I did the test ride with this bike is that the shop owner told me it has the same build (motor, …) as the Lacuba Evo E45, but just an other frame and tires. I asked him if he knew how much the motor power was. He claimed it had 350W.
Do you know more? I am planning to by the Lacuba for commuting and selling my car but I like to be sure of all the specs this bike has. And if it would be a 250W motor, wouldn’t that be to low for a 45km/h bike, meaning also that I have to work harder to drive at higher speeds compared to a 350W? Sorry for all these questions.
BTW, nice reviews of all these ebikes. Keep up the good work. They explain a lot. Best regards, Gert
Court Rye says
Great question Gert! It’s confusing for me too sometimes… There’s the reality (Bosch and Brose hardware is the same regardless of country) and the marketing (Europe says 250 watts to be legal there and the US says 350 because people want more power). The truth as I understand it is that the motors offer 90 Nm of torque and that, along with the smoothness and responsiveness of the controller, is what makes it a good system. You have to shift gears to hit the top speed but with that torque, the nominal wattage is not an issue… most of these motors peak above 500 watts (the Bosch CX above 600 watts) but they don’t focus on that as much for legal reasons. They don’t want people like you to feel confused but they do also want to seem competitive against these hub motors that say 1,000 watts (which is illegal but not really enforced unless there’s an accident). I would say, don’t worry about the watts. Look at the rated top speed, think about how it rode, assume it’s the same (especially since this is the speed pedelec so not tuned down to 25 km/h (15.5 mph) for Euro standards. Does this help? I’m happy to clarify or answer more questions :)
Gert says
Thanks, Court, for the very fast reply. You definitely helped me out here. Things are more clear on wattage and peaks values and so. Still, I am a bit unsure about the 250W Brose motor because it seemed to have had some overheating issues in the past on these speed pedelecs. Maybe Brose wanted to jump on the train too fast with these speed pedelecs, not having developed a 350W motor yet. In 2018, they will have 3 new motors coming out. Here in Belgium a 350W motor is legal for a speed pedelec. Yesterday, I also contacted Bulls via FB with the question how powerful the motor was. They answered it was a 250W motor.
Today I did a test drive with a Stromer ST1 (500W hub motor). I could definitely feel the difference. The Stromer was much easier to keep the +40 km/h range. But what I don’t like is the seating position on the Stromer. The Lacuba is more my way of riding, ie more upright. Well, my search continues. Thank you very much for your help. Gert
John Wiseman says
Court: It would be helpful when talking about hills to actually provide the % grade. Easy and cheap to measure and provides a number to use in someone’s analysis rather than an adjective like steep or big. Thanks for your great reviews, I am relying on these heavily in my decision making.
court says
Thanks for the feedback, John. How would you suggest measuring the grade? It’s not something I’ve done before and I do like your idea and see how it could help people by being more objective vs. qualitative. Is there a special tool or something?
John Wiseman says
Court: I downloaded a free app on my phone, that is probably the easiest/least expensive method. One can also find inexpensive inclinometers on the web. I was thinking that it would also be of use if you could estimate the distance of the slope, not precisely but just an approximation would be helpful. Keep up the good work!
court says
Cool! Which app are you using? I’m capable of searching out but if you’ve found one that works well I’d love to know it so I can test it out too :)
John Wiseman says
I use Bubble Level. I did not do a lot of research but this one seems to work fine for my purposes.
MSB says
After 8 months of loving our bikes EXCEPT for that darn kickstand I just discovered the foot is adjustable. They arrived at full extension which make the parked position extremely precarious, even on level flat ground. From the max length indicated, there is about another 25mm of adjustment by turning the foot in. By adjusting (shortening) that kickstand the bikes are much more leaned over and far less precarious to be knocked over. With this discovery, I see no issue with the folding kick stand. I guess we live and learn.
Court says
Fantastic! Based on your feedback here I’ve updated the bike details to mention that the kickstand is adjustable ;) thanks for taking the time to chime in, glad the Lacuba EVO E45 is working so well for you :D
Paul in Philly says
I bought this bike (in 2019) for an 8 mile commute with 420 feet of elevation change one way. It has been the perfect commuter, but of course you get what you pay for! A few comments:
This is exactly what I was looking for, and the EBR review was spot on (although a little dated now). I got the diamond frame. For me, Class 3 was a must. Truth is, most of the time on flats I’m cruising around 22 mph, and I wouldn’t want the motor cutting out at 20 (which in reality would probably be more like 19. The rear rack is perfect for my Arkel Bug convertible backpack/panier bag. The rear light is great, although I found the front needed supplementation with a cygolite metro. Yes, the bike is heavy, but with this motor/battery, it doesn’t matter. The weight is well spent, as the bike is such a comfortable to ride. I installed a Kinect 2.1 seatpost further adding to the ride’s cushion.
The lack of shift sensing, which I had a little concern about, ended up being a minor issue- one just needs, as Court notes in the review, to briefly let up on the petal pressure/torque prior to each shift, analagous to letting up on the gas prior to shifting in a manual transmission car. I will say that I never shift to the smaller front chain ring- all that I need is available in the rear sprockets with the large chain ring.
Overall it’s a well made bike, a blast and comfort to ride, and the quality shows in the details.
Court says
Hi Paul! Very astute comment here, I especially like how you recognized that a 20mph ebike will realistically cut out closer to 18 or 19mph and that your Class 3 speed pedelec runs around 22 (for me it’s like 22-25mph depending on terrain, wind, and how hard I’m pedaling etc.)
Good call on the Cygolite Metro and Kinect suspension seatpost upgrades. It’s so nice to hear that my review felt on-point with the shifting and the additional chainrings being less-useful. I feel like most ebikes would be fine with a one-by setup, but for a speed pedelec, I can see how a wider range could benefit those who cycle on steeps and also want to keep up going faster. Great comment Paul, thanks for taking the time to share with us!
