The 2016 IZIP E3 Zuma retains all of the things I loved about prior iterations and improves the display panel by making it smaller and tougher but still easy to reach and read. Instead of using a plastic box with LED dots strewn across, the new display ring has rubberized buttons (that are backlit) and a smaller LED console with a battery graphic and number readouts. The other upgrade for 2016 is a smart sleep-mode built into the battery to extend its life. This mode goes into effect when you’ve left the bike alone for 30 days, at this point the battery hibernates and requires the charger to be re-activated (basically, just plug the battery or the bike in and the display should wake up).
My favorite parts about this electric bike are the upright comfortable riding position it offers and the fact that it comes in two high-step sizes, to accommodate a wider range of riders, as well as an easy-to-mount step-thru. The motor is powerful and zippy, especially in assist level four or when using the throttle. I had no problem climbing hills or reaching the 20 mph top speed quickly but did hear the distinct whirring sounds often accompanying planetary geared motors. I also love how beautiful the frame looks with its matching chain guard and optional rack and fenders. You can even get integrated LED lights which would be nice and frankly, I wish you got all of these things for the $2,500 price point but it’s actually $50 cheaper than 2015 and you still get a lifetime frame, two year battery and one year “everything else” warranty including the motor.
The Zuma is a great bike for zipping around the neighborhood and is the only model for 2016 from IZIP that offers the twist throttle with full power up to 20 mph vs. partial requiring pedal assist. There’s no suspension but the tires are relatively large, the saddle is medium-firmness and the swept back bar and padded grips are great. You get 160 mm mechanical disc brakes with cheaper levers and calipers but they get the job done and include motor inhibitors. Because this is a cadence-sensing pedal assist ebike you don’t have to push hard for the motor to start, only pedal consistently. For me, it hits the mark as a cruiser and I appreciate the little extras like a plastic chain guide to reduce drops while navigating bumps and a nice sturdy kickstand that’s black to blend in. Even the spokes on the rear wheel have been upgraded to 13 Gauge vs. 14 on the front, to stand up to heavier loads and the peak output of the motor (40 Nm of torque and 650 watts)
Pros:
- Unique quick release system for the battery and seat post (which are mated together for easier carrying), I love the plastic handle moulded into the saddle and appreciate the optional hex-screw and bolt to secure the battery for those who want to leave it on while parked in public spaces
- Bountiful color choices ranging from traditional black or white to lime green, bright blue, turquoise, salmon orange or red and the chain guard matches
- Seven speed cassette has an extra large ring for climbing and the derailleur is mid-level quality so it should perform well and stay in true longer
- Electronic wires, brake cables and shifter cables are all integrated through the frame for a beautiful aesthetic, though it does make shifting a bit more firm
- Plenty of mounting options including fenders, front and rear racks or baskets and a traditional pair of bottle cage braze-ons
- The oversized saddle offers good support and pairs nicely with the padded leather grips, vibration dampening steel fork and large 2.3″ Kenda tires, I like that the tires are pre-Slimed to slow punctures
- Quality oversized kickstand with length-adjustment screw, the plastic chain guide should help you avoid chain drops, quick disconnect point on the motor power cable makes maintenance easier and the front wheel has a quick release skewer for easy maintenance or lighter transport
Cons:
- The charger can be used to fill the battery on or off the bike but requires a special little dongle to work with off-bike charging that could get lost easily so consider zip tying it to the cable coming out of the charger
- I noticed that the down shift trigger required extra effort and was told that the cable is longer on this bike (since it wraps through the frame) and this creates more friction
- I wish the throttle had an option to override pedal assist, as it stands you have to click down to level zero before the throttle will operate
- The price tag is decent considering the 500 watt motor and 48 volt battery but some of the other cruiser style ebikes come stock with fenders, a rack and lights while those cost extra for the Zuma
Resources:
- Official Site: https://izipelectric.com/electric-bikes/leisure#desc-bottom
- More Pictures: https://goo.gl/photos/KYLL1ynb4R2SLWNJ6
Donny says
Do you have any idea which rear racks will work with this bike? I own one and just tried installing a rack that doesn’t even come close to working (and it is supposed to be disc brake compatible and all of that).
Court Rye says
Hmm… This would be a great question for a shop that carries ebike and has had some of the IZIP models. Try contacting the Electric Bicycle Center and ask for Sam. He might have some ideas for you or direction. My advice would be to look closely at each of these disc brake compatible racks online that look like they might fit (just given that the one you have does not fit), some have more adjustment in their support leg length, height, angle etc. and up front with the arms that connect to the seat stay bosses. Hope this helps :/
Alex says
Where would you possibly get a replacement battery like this one? Also how much would they cost?
Court Rye says
Hi Alex! I’d recommend checking with Rechargeable Power Energy, they offer battery repacking services and actually do work for some of the big companies like IZIP. If you have the case, they just have you send it in with their special packing slip and then they work to put new cells in it for a reasonable price (it might be the only option if IZIP isn’t producing the same battery anymore).
jloeffelholz says
Need 40 mpg ….like some in EU!!!
