The Puckipuppy Labrador Pro ST is a full-suspension in the fat-tire e-bike category (https://electricbikereview.com/category/fat/) that really surprised me. Puckipuppy is not a household name yet, and if you are scrolling through this category online, they might not be the first brand you consider. But they are doing something you don’t often see at this price point: packaging full suspension, dual UL certifications, water resistant bike and battery, and a bundle of accessories into a bike most competitors can’t match.
There are a few areas where the Labrador Pro ST shows its budget price. I will give you all the details from riding the puppy below.
My Experience Riding the Bike
Ride Quality Score: 6 / 10
Fitwise, the Labrador Pro ST worked really well for me. I am 5’11” with a 32″ inseam, and this bike just fits. I like the reach, I like the leg extension, and the geometry feels pretty natural.
Puckipuppy claims a fit range of 5’3″ to 6’4″, but honestly, I think they go a little too far on the high end. If you are 6’2″ or above, you probably are not going to get the full leg extension you want. The challenge is that this is a full suspension bike that has the shock and the linkage design which limits how long the seatpost tube can be. You cannot just drop in a longer seatpost and call it done. If Puckipuppy wanted to open up the top end of their fit range, they would need to offer a second size.
Comfort wise, the 27″ wide flat handlebars sit me in a nice upright position, and the locking rubber butterfly grips feel really good in my hands. The wide cushion saddle is one I am actually a pretty big fan of. It is wide where my sitbones land but tapers up front so I do not get any leg rub when I am pedaling. I would not personally swap it out. The suspension is not top-tier by any means (you would need to spend several thousand more for that), but between the front fork and the rear shock, it does a decent job of taking the edge off bumps on paved roads and trails. Overall, I really do like how this bike rides.
The one thing that took away from the ride for me was a slight front-end tracking issue. And I want to be really clear about this one; I am pretty sure it is just our test bike. We’ve had about 5 Puckipuppies come through recently and none of them had this problem. On our bike, the front wheel is a little off center, which I notice slightly when I am going straight, but I notice it considerably when I’m turning. If you buy the bike and run into the same thing, reach out to Puckipuppy for a replacement.
Taking it off-road was better than I expected. The torque and cadence sensor combo kept the motor smooth and enough that it never lurched me forward in loose or bumpy terrain. I spent more of my dirt time in PAS 4, which caps right around 17.5 mph and kept me a lot more controlled than busting out to 28 mph on PAS 5. This is not a classic electric mountain bike but it is great for off-road HOV trails, dirt roads, and paved roads around the city.
Power / Motor
Hill Climbing Score: 7.5 / 10
The Labrador Pro ST runs a 750 rear hub motor that peaks at 1,350W with 85Nm of torque. Those numbers are right in line with what I would expect for this type of bike, especially at this price point.
Where this bike impressed me is the sensor setup. It is a combo torque and cadence sensor, and I think Puckipuppy did a really good job tuning the power across the assist levels. PAS 1 through 4 run on the torque sensor and step up pretty evenly. PAS 2 settled around 11 to 12 mph for me, PAS 3 at about 15 mph, PAS 4 right around 17.5 mph. Then I kicked it into PAS 5 and the cadence sensor took over. The bike just takes off up to 28 mph. Natural, predictable. This is what you want to see and feel when you are shifting assist levels without having to think about it.
Motor engagement takes about half a turn of the crank before the power kicks in, which is a little slower than average. And when I stopped pedaling, the motor cut off right away. No overrun to speak of. I prefer that on the back end because it keeps things controllable and safer, especially on loose terrain.
On our Black Hill test, which is a steep climb, the bike held up:
- Throttle: 1:55 | 11.3 mph (average speed)
- Pedal: 1:30 | 13.9 mph (average speed)
On throttle only, it is a little less powerful than some of its peers. Not going to sugarcoat that. But when I kicked it over to pedal, it put down enough juice to increase the speed all the way to 28mph, which averages everything out in my opinion. It’s not a rocket, but it will get you up the hill without any drama.
Range / Battery
Range Score: 8 / 10
We took the Labrador Pro ST out for our range test and were pretty happy with what we got.
Min Assist (Eco PAS 1): 61.18 miles
Max Assist (Turbo PAS 5): 45.31 miles
Now, Puckipuppy claims up to 80 miles or range, and there is a reason we did not quite hit that number. We tested min is PAS 2 instead of PAS 1. PAS 1 is very light. Yes, you could probably squeeze 80 miles out of it, but no one usually rides it on this level. It kind of feels like a heavy, sluggish bike at that point.
The battery is a 48V 20Ah pack, giving it a total 960Wh capacity. It’s a big battery! It is also UL 2271 certified and IPX7 rated, which is exactly what you want from a ratings perspective on a fat-tire e-bike. Given how hefty this bike is, it’s a nice touch that the battery is easily removable.
Puckipuppy ships this e-bike with a 48V 2 amp charger that takes about 10 hours to fully charge the battery from empty. You probably need to charge this one overnight. Would I like to see a 3 or 4 amp charger? Yes. But at this price, I don’t think that is a fair expectation on my part.
Components
Components Score: 7.5 / 10
The Labrador Pro ST full suspension fat-tire bike has hydraulic disc brakes, a frame that doesn’t flex, a big battery, and a drivetrain that keeps up with the top speed, though some of these could use some tuning.
- Drivetrain: The Shimano Acera 8-speed drivetrain is one of the better calls Puckipuppy made here. 46T chainrings up front, 13-32T rear cassette, which is about a 240% total gear range. Even at 28 mph, I had no ghost pedaling. Two thumbs up on the gearing. One mechanical note though: the Acera derailleur is not clutched, which means the chain can slap the chainstay off-road. If you spring for the camouflage paint, add a protective strip there so the paint does not chip over time.
- Brakes: The Logan 2-piston hydraulic disc brakes are the weak link. You get 180mm rotors front and rear at 1.8mm thickness, which is a solid setup. I put them through seven hard consecutive stops down a steep descent, and there was no fade. I will say it is safe, for sure, but when I really hit them, they are a little softer than higher-end brands like Tektro, and I could feel the front fork dive a bit. Two changes would take care of it: bump the front rotor to 203mm and increase the thickness from 1.8mm to 2.3mm. Bigger, thicker rotors would give more stopping power and would likely make it so there isn’t a need to jump to a 4-piston setup.
- Suspension: You get a front fork with 110mm of travel on 32mm stanchions and a rear shock. The one nitpick is the fork. It uses a dropout instead of a thru-axle, which would be more stiff and make me feel more confident when riding it around. But at this price I might be asking for too much on that one.
- Tires and wheels: The 26″ x 4″ knobby tires are built for mixed terrain. You can hear the tires on the ground a bit when riding.
The Shimano drivetrain and Logan brakes are the components you will most likely need serviced, and any bike shop can take care of both, although they might complain a bit more about the Logan brakes.
Screen / User Interface / App
Screen / App Score: 6 / 10
This Labrador has a full color screen mounted right in the middle of the handlebars, and it is a good size. Nice and easy to read. But my favorite thing about it? The whole display pops right off. Pop it off when you park the bike, toss it into your bag, and the bike basically becomes a brick to anyone who tries to use it, since the bike can’t be operated without it. I have to say, this is a cool and very nice security feature.
As for what you see on the display: speed, your assist level from 0 to 5, trip, total miles, time on the bike, and which riding mode you are in. The battery readout though? That is this 0 to 6 boomerang bar thing. Which is a little confusing at first, but once you learn your bike, it’s fine. You kind of just have to remember what the boomerang means for your battery level. A percentage readout would be way easier.
Advanced settings live behind holding down three of the buttons at the same time. Most of what is in there you should just leave alone, things like voltage level, wheel diameter, and techno magnets. But a few things are worth knowing. There are settings where you can toggle between Class 2 and Class 3. You can also set the number of assist levels, and if you hold down the minus button, the bike kicks into walk mode, which I think is handy.
Bike Model Options
It comes in one frame size (step-through) and five color options: Grey-Green, Metallic Gray, Dark Blue, Blue-White, and Camouflage. Five color choices is actually more than one usually gets, and I think Puckipuppy deserves credit for giving riders that kind of variety. Now, the Camouflage color does add $100 to the price. It is my favorite of the five. It looks pretty cool, but hey, that is up to you! If budget matters, any of the other colors gets you the same bike for less.
One frame size is what keeps costs down and the lineup simple. Trust me when I say, this works for me, and will probably for you too. Especially with the range of heights listed.
Is the Bike Worth Buying?
In a world where everything is going up in price, it’s nice to see something that doesn’t cut corners where it counts.
Puckipuppy set out to build a full suspension fat-tire bike at a price most riders in this category can actually sit comfortably in on multi-terrain. The frame is stiff, the motor is fairly smooth, and the battery is sized right for the bike. The current promo throws in a bundle of accessories so you do not have to make a bike shop run just to get out and ride. The dual UL certifications? Nice bonus too.
This is a good fit for the budget minded rider who wants a bike for cruising around town, commuting to and from work, and getting out on dirt roads, double track trails, or for a campout.
The biggest limitation of this bike is the front wheel issue. Again, I have a strong hunch that it’s a problem with our test bike, but I want to re-iterate again that if you do purchase the Labrador ST, make sure you check that. If you do have an issue, then return it to Puckipuppy for one that will ride straight.
This e-bike offers real value without feeling cheap. A few things could be improved, mainly the brakes and programming. But at this price? The Labrador Pro ST is a lot of bike for the money.
Reader Interactions
