Review Overview
Throughout this review, I repeatedly highlight the Juiced Core as an ideal choice for teenagers and first-time riders looking for a moto-style e-bike. It perfectly serves a demographic that overwhelmingly prefers this style of e-bike.
However, the Core isn’t strictly a ‘teen bike’ – it’s an excellent option for riders of any age wanting a sleek cafe cruiser at a highly competitive price point.
Note: If you have a slightly bigger budget, then I recommend also considering the Juiced Scrambler FS or HT, which feature a slightly more powerful 750W motor, better suspension, and better brakes.
My Experience Riding the Juiced Core
Ride Quality Score: 8 / 10
Before diving into the technical details, let me be clear: the Juiced Core is incredibly fun to ride. I spent the past week neighborhood cruising with my 10-year-old on the back, commuting to work, and even successfully pranking my 15-year-old son by swapping the Core for his usual full-suspension Scrambler (both are white and look identical at a glance).
The feedback:
- Me: Loved it. The only thing I found myself missing was full suspension, mostly due to 46 years of wear and tear on my own body.
- My 10 year old: Zero complaints cruising to and from soccer practice; he didn’t even notice the lack of rear suspension.
- My 15 year old: He was confused when heading to basketball practice, briefly worrying he brought the wrong bike home. Once he realized the swap, his feedback was twofold: first, being spoiled by the Scrambler FS, he missed the rear suspension. Second, he didn’t notice any drop in power output and was thrilled that I accidentally left the Core’s top speed at 25 mph (I strictly limit his daily rider to 20 mph per Utah e-bike laws).
The Core is undeniably fun. Technically speaking, I love that Juiced used the structural ‘bones’ of their premium Scramblers as the baseline for this more affordable model. The frame, seat, geometry, and overall ride feel are virtually identical to their higher-end bikes, which is a massive plus.
The exceptionally stiff frame, paired with a robust dual-crown fork, inspires immediate confidence. I noticed zero frame flex through corners and felt entirely secure during 35 mph downhill brake tests.
Juiced uniquely offers the Core in two sizes: ‘Core’ (large) and ‘Core Mid’ (medium/smaller). While the naming is slightly counterintuitive, providing a smaller frame for a teenage demographic makes the bike significantly easier for smaller riders to handle. The listed rider height range of 4’10” to 6’3″ across both sizes is reasonable, but with one caveat: prioritize rider ability over physical size. A 5’2″ rider might fit the bike, but they must still possess the skills to handle a 75 lb e-bike safely.
Power / Motor
Hill Score: 8.5 / 10
Speed
The Core features a 500W rear hub motor peaking at 1,164W and 80Nm of torque. On paper, this is a step down from the 750W Scramblers (which peak at 1,764W and 90Nm). However, without knowing the specs or comparing them side-by-side, I would have easily guessed this was a 750W motor based strictly on its riding power.
The surrounding system prevents the Core from feeling like a budget 500W bike. It pairs a 52V battery with a 20-amp controller, allowing the motor to surge well past its nominal rating. Many competing 500W bikes max out around 750–800 watts, and the performance gap is noticeable.
You’ll have no issue reaching the 25 mph top speed. On flats, the bike feels peppy yet highly controlled and predictable – crucial features for parents buying for a teen.
Torque and Hill Climbing
Our hill test is the Black Hill, and the Core did better than I expected.
- Throttle results: 1:37 | 12.9 MPH (average speed)
- Pedal results: 1:32 | 13.6 MPH (average speed)
These are the fastest times we’ve ever recorded for a 500W motor, easily beating lighter, large-wheeled commuter bikes.
Given these results, nobody should overlook the Core simply because it ‘only’ has a 500W motor.
Unless you weigh over 220 lbs, you likely won’t feel starved for power. My son couldn’t even detect the difference in power between the 500W and 750W models. While experienced testers can spot the difference, the vast majority of riders won’t.
Range / Battery
Range Score: 7 / 10
Min Assist: n/a
Max Assist: 29.5 Miles
Note: We tested the Core using the 15.2Ah/780Wh long-range battery, riding exclusively on the throttle in turbo mode.
Getting just under 30 miles out of it that way is a strong result, and it’s farther than most people will want to ride a moped-style bike in one go.
Achieving just under 30 miles under maximum load is an impressive result—far longer than most riders will want to sit on a moped-style saddle in one trip.
Is the standard 10.2Ah battery sufficient? Based on our data, we estimate it will deliver around 20 miles of throttle-only range in max assist, which is plenty for average daily use. However, with roughly 33% less capacity, you’ll need to be more diligent about charging the bike frequently.
Battery Technical Details:
The 52V battery features LG cells and UL 2271 certification. It is securely housed under the saddle but remains easy to remove. The included 2-amp charger replenishes the 10.2Ah battery in about 5 hours, while the 15.2Ah battery takes roughly 7.5 hours.
Components
Components Score: 7 / 10
At $1,399 to $1,599 for a moped-style bike, the Juiced Core surpasses expectations across the board, especially if compared to an entry-level Super73.
While there are some components that are pretty standard (dual piston hydraulic disc brakes, aluminum frame, and single speed drivetrain), there two components that stand out and which I don’t typically see in this price range:
- Triple crown aluminum suspension fork with 100mm of travel. The Exsho Muscle Fork is the same fork available on the Super73 A-Series (for an additional $400). It’s a through-axle fork that is very rigid and helps keep the front tire gripping the ground while also making the bike very comfortable.
- 180 x 2.3mm rotors on Star Union 602 brakes. While dual piston brakes are standard at this point on most e-bikes, it’s not standard (yet) to pair that with 2.3mm thick rotors. The thicker rotors make it more likely to have slight brake rub (there isn’t much space between the brake pads). More importantly, thicker rotors help improve stopping power on heavier bikes.
Combining above average suspension and brakes with a rigid frame and powerful motor make for an above average value bike. Once again, it’s pretty clear that Juiced is targeting Super73 directly on pricepoint and Macfox on components.
Juiced Core vs Juiced Scrambler FS vs Juiced Scrambler HT
For those debating between the three Juiced e-bikes, here is a quick summary table of the key components:
| Juiced Core | Scrambler HT | Scrambler FS | |
| Price | $1,399 (10.2Ah) / $1,599 (15.2Ah) | $1,699, down from $2,044 | $1,899, down from $2,244 |
| Motor | 500W nominal rear hub, 1,164W peak, 80Nm | 750W nominal hub, 1,764W peak, 90Nm | 750W nominal hub, 1,764W peak, 90Nm |
| Battery Capacity | 52V, 10.2Ah / 530Wh or 15.2Ah / 780Wh | 52V, 19.2Ah (998Wh). Dual-battery version $1,999 | 52V, 19.2Ah (998Wh) |
| Suspension | 100mm triple crown aluminum fork, threaded through axle, compression and preload adjustment. Hardtail rear. | KKE inverted fork, 140mm travel. Hardtail rear. | KKE inverted front fork with 140mm of travel plus a matching adjustable KKE rear shock |
| Brakes | Star Union Talon P2, 2-piston, 180mm rotors, 2.3mm thick | Talon 4-piston [MISSING: rotor size and thickness] | Talon 4-piston [MISSING: rotor size and thickness] |
| Drivetrain | Single speed | Single speed | Single speed |
| Standard Accessories | Integrated headlight, tail light, brake light, turn signals. 2A charger. No fenders or racks. Pre-order adds nameplate, bar pad, sticker pack, headplate, fenders. | Headlight, tail light, brake light, turn signals. In the box: pedals, handlebar pad, sticker pack, battery and manual, handlebar bag, headplate, front and rear fenders, and a 5 amp charger | Same as HT |
Screen / User Interface / App
Screen / App Score: 7 / 10
The display is a full-color display integrated into the top tube, which makes the bike look sleek in addition to protecting it in case of crashes – and from whatever teenagers somehow do to brake them even without crashing.
The readouts are basic but cover what you need. You get a battery percentage plus a bar graph, speed, the wattage the motor is pulling, your odometer, and your assist level laid out so you can see where you are in the four levels. Hit the left or right arrow and the turn signals come on, and the display doesn’t show that, which makes sense since you shouldn’t be staring at the frame while you turn.
Hold the plus and minus buttons and you’re into settings, and there’s more in here than I expected. Units, brightness, auto-off, tire size, light modes, walk mode, trip stats, battery voltage and current, and error codes for service.
The two settings that matter most are class speed and the speed lock. Class speed lets you set the bike to Class 1, Class 2, or Class 3 at 25 mph, with a custom option that lets California riders cap it at 20 and stay legal.
The speed lock is the one parents are going to care about. You can set a top speed anywhere from 1 to 25 mph and lock it behind a 4-digit PIN. Start a new rider at 15, drop them to 10 if they’re not paying attention, open it up as they earn it.
There’s no companion app, so every adjustment happens on the bike. The menus are plain enough that I don’t think that’s a real problem, and I’d rather have a simple display that works than an app that doesn’t. That said, an app would let Juiced add over-the-air updates and remote parental controls, and that’s what I’d like to see in a future version.
Bike Model Options
There are two different frame sizes on the Juiced Core:
Juiced Core (regular size frame)
- 45.5″ Wheelbase
- 31.5″ Seat Height
- Bike Measurements: 66 x 43.5 x 29.5 in
- Color options: Black Lemon, White Grape, Sour Grape, or Fruit Punch
Juiced Core Mid (smaller size frame)
- 43″ Wheelbase
- 31.5″ Seat Height
- Bike Measurements: 66 x 42 x 29.5 in
- Color options: Black Lemon, White Grape, Berry Freeze, or Blood Orange
I think it makes sense for Juiced to offer several different color options, especially for targeting the teenage crowd. However, I have a feeling there will be comments from people who want a specific color in the different sizes.
There are also two different battery options, both of which are available with either frame size:
- 10.2 Ah | 530Wh | $1,399
- 15.2 Ah | 790Wh | $1,599
Is the Juiced Core Worth Buying?
Juiced engineered this bike for a highly specific demographic and absolutely nailed the execution. A parent shopping for a teenager requires three things:
- Moto-styling cool enough that the kid actually wants to ride it.
- Enough power to be genuinely fun.
- Parental controls to ensure it doesn’t cause sleepless nights.
The Core delivers on all three fronts. The fact that four teenagers stopped me during filming confirms point one. The 52V system’s hill-climbing prowess secures point two. And the PIN speed lock paired with heavy-duty brakes ensures point three.
For an adult buying for themselves, I’d probably still go to the 750W Scrambler. I’m 195 lbs and I’d want the extra torque if I were going to put my 10 year old on the back and ride up a hill. But that’s a preference, not a knock on the Core. Buying for my own 15 year old, I’d pick this bike without much thought. I’m not giving up the power he needs, you’re saving several hundred dollars, and the longest ride he goes on is less than 5 miles.
Beyond the raw specs, the hidden details make the Core easy to recommend. It features UL 2271 and 2849 certifications, a 3-year warranty, and an IP-65 rated, potted controller ready to survive muddy teenage joyrides. Factor in durable brakes and an easily accessible wiring bay (which saves money on shop labor), and it’s a remarkably smart buy.
My desired changes are minor: larger, better-placed turn signals; standard passenger foot pegs; and an app for remote parental controls.
Starting at just $1,399, the Juiced Core is a steal and easily my top pick for parents shopping for a teenage rider.
Review Unit Disclosure
Juiced provided a pre-launch review unit of the Core (large frame, 15.2Ah long range battery, White Grape). Testing was done independently at EBR, not at a brand media event. Because the bike is pre-launch, the velcro issue noted in the components section may not carry over to production units, and we’ll confirm that with Juiced.
Reader Interactions
